ABS light on-Wheel Speed Sensor Problem - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 05-18-2011, 08:44 PM   #1
fordfocus2000
Fan#: 73534
What I Drive: 2000, white, SE wagon
FF Reputation: 1 fordfocus2000 Good Standing Member
Hi,
Immediately after a mechanic changed the left rear bearing a got ABS light on.
This is how the problem manifests:
First, when I start engine ABS light is on.
Second, when I start to drive the car the light is on until I reach 12mph (20km/h), then it shuts down.
Finally, when the car reach 30mph (~50km/h) the light is on again and it stays whole the way.
What I noticed is that the breaking system is working strange before reaching 30mph, and it works fine after 30mph.
I returned my car back to the mechanic, he scanned the car but wasn't able to diagnose the problem . He told me that my breaks are fine (although ABS light is on), and that I can drive the car.
Do you have any idea what could be the problem?
fordfocus2000 is offline
Old 05-18-2011, 09:16 PM   #2
wrc_fan
slow
wrc_fan's Avatar
Fan#: 11913
What I Drive: 03 ZX3 Duratec 08 WRX Hatch
Points 3,584, Level 37
Points: 3,584, Level: 37 Points: 3,584, Level: 37 Points: 3,584, Level: 37
Level Up 56% Completed
FF Reputation: 23 wrc_fan Great Standing Member
Sounds like the rear sensor that mounts in the spindle could have been damaged or the speed ring thingie damaged when the wheel bearing was replaced. The mechanic will be interfacing with some abs components when changing a wheel bearing, as the bearing is intergrated into the rear drum. The mechanic should fix this.
Parking Lot Hero
2008 WRX daily driver
2003 ZX3 23D Autox Car 42 FSP
"Hella Functional - Raced, Not Hard Parked"
wrc_fan is offline
Old 05-19-2011, 11:19 AM   #3
fordfocus2000
Fan#: 73534
Tone ring is damaged. It's ~$55.00 just for a part but I don't know where can I change it, since it is pressed.
Old 05-19-2011, 11:50 AM   #4
wrc_fan
slow
wrc_fan's Avatar
Fan#: 11913
Last time I changed my drums, I pried it off and the old drum and installed it on the new drum with a block and mallet. Not sure if that's the propper way to do that though. Maybe someone else can chime in here.
Parking Lot Hero
wrc_fan is offline
Old 11-27-2012, 10:01 PM   #5
coldbear
Fan#: 78292
What I Drive: 2014 Race Red 6/spd. SE
Points 1,358, Level 20
Points: 1,358, Level: 20 Points: 1,358, Level: 20 Points: 1,358, Level: 20
Level Up 58% Completed
FF Reputation: 1 coldbear Good Standing Member
I replaced a frt. right axle and I'm getting the ABS light occasionally. New axle was supposed to have everything ready to put in. I never saw any tone ring when dissasembleing unit.? Advice any machanic?
coldbear is offline
Old 12-06-2012, 09:40 PM   #6
alexrckid
Fan#: 107001
What I Drive: 2005,red,zx5
Points 38, Level 1
Points: 38, Level: 1 Points: 38, Level: 1 Points: 38, Level: 1
Level Up 76% Completed
Level up: 76% Level up: 76% Level up: 76%
FF Reputation: 1 alexrckid Good Standing Member
the tone "ring" is a part of the (fron, in this case) hub....
check this out...look at the 17th and 18th picture down...
http://www.focusfanatics.com/forum/showthread.php?t=119824
alexrckid is offline
