In cabin Air filter 2012 Focus - Page 4 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 09-17-2012, 07:13 PM   #31
Joeywhat
Strichmädchen & Koks
Joeywhat's Avatar
Fan#: 85247
What I Drive: 2014 Mustang 3.7L SGM
Points 8,143, Level 60
Points: 8,143, Level: 60 Points: 8,143, Level: 60 Points: 8,143, Level: 60
Level Up 97% Completed
Level up: 97% Level up: 97% Level up: 97%
Forum Activity 8%
FF Reputation: 11 Joeywhat Great Standing Member
Originally Posted by slowmazda3 View Post
Unclip all wires, and remove fusebox. There are only positive lever lock clips back there so nothing will be that terrible to remove.
Copy. I couldn't see the top of the block very well so I didn't bother to see how they unclipped. I'll take a closer look tomorrow.
Hatch Nation #29
Joeywhat is online now
Old 09-17-2012, 07:17 PM   #32
PratoN
PratoN's Avatar
Fan#: 88058
Points 3,084, Level 34
Points: 3,084, Level: 34 Points: 3,084, Level: 34 Points: 3,084, Level: 34
Level Up 23% Completed
Forum Activity 3%
FF Reputation: 15 PratoN Great Standing Member
Originally Posted by treoless View Post
How much did it cost you?
I forget - I think $43 for parts and labor? But I got it done at 20k miles because the manual says to get everything "checked out" or w/e. I don't know what that means or how to prove that I greased zerk fittings and made sure my ball joint boots aren't torn, etc. other than by my word. So I figured if I just brought it in, that'd be proof enough. heh...
PratoN is online now
Old 09-19-2012, 11:11 AM   #33
DavidJames
Fan#: 103989
What I Drive: 2012 Black Focus Titanium
FF Reputation: 1 DavidJames Good Standing Member
2012 Focus Cabin Filter
Just relpaced filter @21K. It was black.
To make it easier to get the new filter in, if you gently squeeze the top & bottom of the filter it decreases the size & provides a rounded leading edge as you insert it. Once you have the leading edge in the filter snaps back to its squared shape.
Did not have to remove fuse box doing it this way.
Who ever designed this should be shot.
DavidJames is offline
Old 09-19-2012, 05:51 PM   #34
slowmazda3
Fan#: 58220
What I Drive: a rental
Points 683, Level 13
Points: 683, Level: 13 Points: 683, Level: 13 Points: 683, Level: 13
Level Up 66% Completed
FF Reputation: 0 slowmazda3 Newbie
If you think its bad in this application, the Mazda 3 has 2 short panels that need to be levitated in on top of one another. #fail
I bought a mazda and all I got was some crappy motor mounts and wheelspin.
slowmazda3 is offline
Old 09-19-2012, 08:41 PM   #35
Hodge Podge
Hodge Podge's Avatar
Fan#: 96120
What I Drive: 2012 5-Dr Se Sport Pkg Ingot Silver
FF Reputation: 1 Hodge Podge Good Standing Member
I second this, both parts! An extra half inch or so would have made all the difference in the world.
And no, that's not what she said...
Also, my factory filter appeared black/dirty, but didn't have that much loose dirt in it. So either it's really nasty after 10k miles or more likely, it's like one of the filters like Fram or Purolator offered a while back with "Activated Charcoal" for odor removal or some such. At first glance, they too look dirty even when new.
____________________
Hodge Podge
2012 Se Ingot Silver 5-Door w/ 201A & Se Sport Package
2001 Silverado 1500 RCLB 4x4 4.8L 5-Speed
Hodge Podge is offline
Old 10-06-2012, 09:54 PM   #36
Kevin_agar
Fan#: 104461
What I Drive: 2012 Silver Focus Titanium
FF Reputation: 2 Kevin_agar Good Standing Member
I took mine out today and replaced it... 10 minute job and did not remove or unplug any pcm parts or disconnect the battery. Here's the secret... There is a small downward facing vent under the glovebox. Undo the bolt and push the vent to the left. Pull the old filter out in an arc through the space where the downwards facing vent was while squeezing the filter as previously noted by others. To install u simply push the filter in through this space while squeezing the end a bit and just feed it in on an arc (like making a left hand turn kinda)... Occasionally aligning and manipulating the top then bottom back and forth until it is all the way in. It is a pain but it does go in in less than 3minutes... Then just slide the vent over 2 inches to the right and tighten the small bolt.... Install the cover and u r done.
Kevin_agar is offline
Old 10-09-2012, 06:53 AM   #37
12FOCUS S
Fan#: 98622
What I Drive: '13 FOCUS ST/'12 Mustang GT BBP
FF Reputation: 1 12FOCUS S Good Standing Member
Thumbs up
thanks!
12FOCUS S is offline
Old 10-14-2012, 12:56 PM   #38
Creamsicle
Creamsicle's Avatar
Fan#: 91108
What I Drive: 2012 Ti hatch
FF Reputation: 2 Creamsicle Good Standing Member
Hey guys - I'm at 20k miles and time to replace this filter. I have tried in vain to come up with a part number... not in the manual, nothing online @ Ford (that I was able to find). Purolator says it's C36174 which is not available.
Anybody have a PN for this replacement filter? Ford or aftermarket, I don't care.
Thanks.
2012 Ti hatch, 401A & Sport Pkg
Creamsicle is offline
Old 10-14-2012, 01:04 PM   #39
craigsfocus
craigsfocus's Avatar
Fan#: 97985
What I Drive: 2012 Race Red SE
Points 3,162, Level 34
Points: 3,162, Level: 34 Points: 3,162, Level: 34 Points: 3,162, Level: 34
Level Up 75% Completed
FF Reputation: 6 craigsfocus Good Standing Member
Thanks.
Motorcraft- FP70 . I got that via Rockauto.
2012 Ford Focus SE Hatchback Race Red. 203A Spec. Window Tint. K&N Typhoon CAI. FSWerks Race Exhaust. Weathertech Digital Fit Floormats. HIDs with Projectors. Build Date: 2/14/2012
Active Duty US Army. MOS 91E (Machinist). OEF Vet.
craigsfocus is offline
Old 10-14-2012, 01:07 PM   #40
Creamsicle
Creamsicle's Avatar
Fan#: 91108
+ your rep.. TY Craig.
