In cabin Air filter 2012 Focus - Page 11 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 01-06-2014, 01:41 PM   #101
ccelaya
ccelaya's Avatar
Fan#: 92465
What I Drive: 2012 Sterling Grey - Focus HB Sport
FF Reputation: 1 ccelaya Good Standing Member
I just got mine from amazon (picked it up in the US), I will install it tonight...
I went to 4 different motorcraft/ford dealers in two different cities in Mexico without any luck (also they wanted to charge double and special order it).. I will let you know how it turns out... I have 40,000 kms in my FoFo
ccelaya is offline
Old 01-13-2014, 08:37 PM   #102
ccelaya
ccelaya's Avatar
Fan#: 92465
I just replaced my filter, it was totally worth it...
I got used to my A/C performance and honestly I didn't expect that this would make such a difference in air output and quality :)
This is what the filter looks like after 41,000 km (dusty roads and foundry environment):
The new one:
And the magical moment I could finally squeeze that sucker in
ccelaya is offline
Old 01-28-2014, 02:47 PM   #103
wkumtrider
Fan#: 105044
What I Drive: 2012 Blue SE
Points 76, Level 1
Points: 76, Level: 1 Points: 76, Level: 1 Points: 76, Level: 1
Level Up 52% Completed
FF Reputation: 1 wkumtrider Good Standing Member
33,000 miles and hasn't been replaced yet. I think it's due.
wkumtrider is offline
Old 05-01-2014, 04:06 PM   #104
patrick24
Fan#: 109876
What I Drive: 2012 Ford Focus
FF Reputation: 1 patrick24 Good Standing Member
This also seem useful http://www.paulstravelpictures.com/F...acement-Guide/
patrick24 is offline
Old 05-01-2014, 09:36 PM   #105
Tigeo
Tigeo's Avatar
Fan#: 113481
What I Drive: 2013 Ignot Silver Focus HB
Points 3,491, Level 36
Points: 3,491, Level: 36 Points: 3,491, Level: 36 Points: 3,491, Level: 36
Level Up 94% Completed
Forum Activity 19%
FF Reputation: 2 Tigeo Good Standing Member
I had mine replaced at 30K/1 year when it was was in for an oil change and tire rotation. It was was $24 for for the filter and about the same to install...it was already there so convience won. I figure change once a year as much as I drive.
If its not grown it's mined!
2013 Ingot Silver Focus SE HB manual, 201a, winter pkg, moonroof. Snorkel delete/K&N drop/ST inlet. FSWerks RMM poly insert.
Tigeo is online now
Old 05-02-2014, 01:14 AM   #106
OldGray320i
Fan#: 93808
What I Drive: 2012 SE Hatch
Points 400, Level 7
Points: 400, Level: 7 Points: 400, Level: 7 Points: 400, Level: 7
Level Up 50% Completed
Forum Activity 7%
FF Reputation: 2 OldGray320i Good Standing Member
Mine's about due again, probably over due.
I like your tag line "If it's not grown, it's mined!" I was a salesman for a short period of time for a services company (crusher repairs, electric motors, etc...) and when I realized all the different things that the mines provide for the products we all use, I was blown away.
OldGray320i is offline
Old 05-02-2014, 05:29 AM   #107
Tigeo
Tigeo's Avatar
Fan#: 113481
Forum Activity 19%
I am a geologist working for a mining company; the tagline is v. true, you either grow or mine everything we have..everything...the other one I use sometimes is "Where do you think that battery in your Prius came from?"
Tigeo is online now
Old 05-02-2014, 02:45 PM   #108
OldGray320i
Fan#: 93808
Points 400, Level 7
Forum Activity 7%
Beautiful. Just beautiful.
I'm going to use that one - attributed, of course!
Old 05-02-2014, 07:23 PM   #109
block
Fan#: 133889
What I Drive: 2013 Performance Blue SE 5 speed
Points 300, Level 5
Points: 300, Level: 5 Points: 300, Level: 5 Points: 300, Level: 5
Forum Activity 4%
FF Reputation: 1 block Good Standing Member
Originally Posted by SydneyRoo View Post
The Matrix/Vibe one was easy! 1) Remove glovebox (1 screw involved) 2) unlatch filter door 3) remove!
I can't imagine how much the dealer is going to charge to replace the Focus air filter... And yes, they do get clogged up.
My Ford Contour is 15 years with the original filter...PITA to change it, and since it wasn't "broken", I didn't bother. I figure there is a bypass. They seem "silly" to me - do we use an air filter when we are outside jogging? They don't filter out exhaust.
block is offline
Old 05-02-2014, 07:33 PM   #110
block
Fan#: 133889
Points 300, Level 5
Forum Activity 4%
If they had charcoal though, they would be black from Day 1, right?
They all look way too nasty, I agree 100% that there is something going on. I hope the A/C (and/or rain) is not getting them wet and causing mold to grow!!!!
I wonder if aftermarket filters will all turn nasty, (assuming that not all have "charcoal" in them), and in Canada where they do not use A/C as often.
BTW, always turn off your A/C a few minutes/miles before getting home, and keep the fan running (set to a fairly high speed) to warm up and then dry the various airways so humidity doesn't condense in there and get moldy. When you first turn the A/C off, the passageways are very cool, and the warm humid incoming air will probably condense, so the longer the fan is on (w/o AC) the better.
Originally Posted by TboneZX3 View Post
I don't believe that the reason these filters turn black is due only to dirt. There is active charcoal in these, and after time and exposure to humidity, that charcoal stains the white filter media. I think the real story of how dirty the filter is told by the dirt trapped in the pleats, not the overall color of the filter.
Your engine/intake air filter "breathes" the same air these filters do, and they don't turn black. Why? no active charcoal.
block is offline
