2012 Focus Sport Package - Changes? - Page 8 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 04-07-2012, 10:13 AM   #71
Hawktwoe
Hawktwoe's Avatar
Fan#: 91129
What I Drive: 2012 Focus SE Sedan 5spd SGM
FF Reputation: 1 Hawktwoe Good Standing Member
Wow, now I'm as confused as my salesman was, he said the 203a package has MFT (not true). Are there three suspensions for the Focus (standard, sport, and touring)?
I ordered the sport pkg. with 16" alloys. The car has aluminum LCA's. The build sheet says "touring suspension". I'm assuming the build sheet is correct. Is the sport suspension stiffer than the touring? Did I pay for an upgrade I didn't get? Could I get compensated for this?
12 Focus SE sedan Sport pkg, 203a, 5-spd
09 Edge SEL
02 F-150 FX-4 Lariat
63 Galaxie 500XL fastback
94 FXSTC
Hawktwoe is offline
Old 04-07-2012, 10:50 AM   #72
Dgc333
Fan#: 85422
What I Drive: 2012, candy blue, SEL
Points 750, Level 14
Points: 750, Level: 14 Points: 750, Level: 14 Points: 750, Level: 14
Level Up 50% Completed
FF Reputation: 1 Dgc333 Good Standing Member
What you get with the Sport pkg on the SE is the touring suspension and is the same suspension as the SEL and TI. Only the TI with the performance package gets the sport suspension.
You got an upgrade over the standard S and SE suspension so you got what you paid for.
Dgc333 is offline
Old 04-07-2012, 11:16 AM   #73
kam327
-----<M>-----
kam327's Avatar
Fan#: 94700
What I Drive: '14 Ruby Ti w/ Handling Pkg
Points 7,361, Level 57
Points: 7,361, Level: 57 Points: 7,361, Level: 57 Points: 7,361, Level: 57
Level Up 6% Completed
Forum Activity 11%
FF Reputation: 13 kam327 Great Standing Member
This was posted in another thread a while back. The SE Sport and Ti have "touring" suspensions. The SE and SEL have "standard" suspensions. Only the Ti w/ 18's has the "handling" suspension.
This is compiled from checking dealer inventory VINs in Etis, parts lists from Fordparts.com, and information from other posters. It is interesting to see how the different models are packaged. It also makes me wonder if there are errors in Etis. For example, I don't see the "MD" rear springs being used with any model, but I expected them to be used on the Titanium with 18" wheels. Also, the SE Sport uses the S rear springs?
There is no difference between hatch and sedan suspensions.
All models use the same stabilizer bars - 23.5mm front and 19mm rear.
Both suspension packages use standard brake calipers and pads.
There are two different front lower control arms - one for the S model (15" wheels) and one for all other models (16", 17" and I assume 18" wheels).
Front suspension knuckles are the same, but different rear (I think) suspension knuckles for 18" wheels.
S
6 x 15" Steel Wheels
standard suspension (shocks)
BV61-5310-NF* Left Front Coil
BV61-5310-NF* Right Front Coil
BV61-5560-NF* Left Rear Coil Spring
BV61-5560-NF* Right Rr Coil Spring
SE
With 6.5J X 16" Steel Wheel
BV61-5310-NG* Left Front Coil
BV61-5310-NG* Right Front Coil
BV61-5560-NG* Left Rear Coil Spring
BV61-5560-NG* Right Rr Coil Spring
SE - sport package
7 X 16" Alloy ET 50MM Style 2
touring suspension (shocks)
SEL
7 X 16" Alloy Wheels
Titanium
7J X 17" Style 5 Alloy Wheel
Titanium - 18" alloy wheels
8 X 18 ET 55MM Alloy Style 2
With Handling Suspension (shocks)
BV61-5310-MD* Left Front Coil
BV61-5310-MD* Right Front Coil
kam327 is online now
Old 04-07-2012, 02:00 PM   #74
jimfocus
Fan#: 69155
What I Drive: 2012 Race Red Focus SE
Points 102, Level 2
Points: 102, Level: 2 Points: 102, Level: 2 Points: 102, Level: 2
Level Up 4% Completed
FF Reputation: 2 jimfocus Good Standing Member
Thumbs up
Great research and writing kam327. I can verify the part numbers as posted on my 2012 SE Sedam with sport pkg. Thanks for the clarification.
jimfocus is offline
Old 04-07-2012, 02:19 PM   #75
kam327
-----<M>-----
kam327's Avatar
Fan#: 94700
Forum Activity 11%
No problem, but all I can take credit for is doing a search a while back and finding this. It was someone else's hard work.
Old 04-07-2012, 02:46 PM   #76
Hawktwoe
Hawktwoe's Avatar
Fan#: 91129
Thanks for the info. I AM happy with my choice, however, I did get shorted the rear floor mats. From what I've seen in other forums, this happens more ofrtn than not.
09 Edge SEL
94 FXSTC
Hawktwoe is offline
Old 04-07-2012, 08:49 PM   #77
lscrx
Fan#: 41668
What I Drive: 2012 Focus SE hatch 5mt
FF Reputation: 2 lscrx Good Standing Member
Hmmm... I got eight floor mats.
Posted via FF Mobile
lscrx is offline
Old 04-27-2012, 04:38 PM   #78
90whtgsi
Fan#: 97951
What I Drive: 2012 sgm SE sedan 5mt w/sport pkg
FF Reputation: 1 90whtgsi Good Standing Member
Question
kam327
In your post from 04-07-12 you show a listing for SE SPORT pkg w/16" wheels as having BV61-5310 NG for front coil and BV61-5560-NF for rear coil. (I know this is not your research, just posted findings). I also found a post from newmission that lists BV61-5310-NF for front and BV61-5560-NF for rear. (NF for front and rear coils). Confusing ,right? Hold on. Here we go. I have a '12 SE sedan W/SPORT pkg and 16" wheels. I pulled the tags off both right side springs...front # is BV61-5310-NF and the rear # is BV61-5560 NG. Really confusing now, right? I went to Fordparts.com Catalog and entered my VIN# to narrow the search. Results here matched the tags on the springs. WOW! Now I still don't know if i have the "sport-tuned"-"touring" suspension or not. Not sure if it matters. When I bought the car, it seemed to have a softer ride than my previous ride. I inflated the tires to 45psi and this made a big difference in ride and handling. BTW, build date is 08-05-11.
john
90whtgsi is offline
Old 04-27-2012, 08:52 PM   #79
Hodge Podge
Hodge Podge's Avatar
Fan#: 96120
What I Drive: 2012 5-Dr Se Sport Pkg Ingot Silver
FF Reputation: 1 Hodge Podge Good Standing Member
My 2012 5-Door, SE Sport Pkg w/ 16" wheels, has a November 2011 build date. Just checked the stickers/labels on the springs for part numbers...
Fronts: BV61-5310-NGF
Rears: BV61-5560-NFD
Referencing 90whtgsi's post, there is apparently a difference between the sedan/hatches, but I still have no idea what all this means...
It's just my $.02, which, when adjusted for inflation, depreciation, cost of living, electricity to run this laptop, internet connection fees, etc. etc. etc..., is worth a net value -$6.42.
____________________
Hodge Podge
2012 Se Ingot Silver 5-Door w/ 201A & Se Sport Package
2001 Silverado 1500 RCLB 4x4 4.8L 5-Speed
Hodge Podge is offline
Old 04-27-2012, 11:45 PM   #80
jsr72
Fan#: 97393
Points 151, Level 3
Points: 151, Level: 3 Points: 151, Level: 3 Points: 151, Level: 3
Level Up 2% Completed
FF Reputation: 5 jsr72 Good Standing Member
If you look at ETIS for a bunch of different cars under the minor features you will see SE and SELs listed with standard suspension. SEs with the Sport Pkg and Titaniums listed with Touring suspensions. Titaniums with the 18" wheels are listed as having performance suspension.
Then go to Fordparts.com and you will see different part numbers for standard, touring and performance shocks.
The springs are listed in ETIS and they don't follow the standard, touring and performance so I would expect that they are tuned to the weight of the car to maintain a consistent ride height based on content.
This
jsr72 is offline
