Sponsored By: Massive Speed
Old 05-05-2011, 02:53 PM   #1
K Dog
FF Affiliate
K Dog's Avatar
Fan#: 23554
What I Drive: Car
Buy-Sell-Trade Rating: (16)
!NEW PRODUCT - Massive RaceSpec Adjustable Rear Toe Arms Contour/Cougar!
For Contour / CSVT Mystique Cougar CDW27 Platform vehicles
Replaces stock fixed arm with adjustable. Allows for custom toe in / out set up:
  • Obtain stock settings – many stock/mildly dropped vehicles cannot be set to OE specifications. Massive arms allow perfect alignment, resulting in optimal handling and proper tire wear.
  • Performance/racing settings – Tune for more advanced settings for max race performance in road race / autocross environments.
  • Rear steer – Massive arms are designed with a far greater degree of positive AND negative adjustment to attain rear steer – perfect for those only turning ONE way (circle track!!!).
Full T6061 billet aluminum .220 wall tie rod is not only stronger than OE stamped piece, but also lighter in weight! Machined wrench flats for easy adjustment.
FAR Stronger than easily bendable stock stamped piece. REALLY firms up handling!!!
Years of exhausting research at the race track and on the street have led us to these “cost-no-object” Aurora swaged PTFE lined oversize 5/8” 15,000 lb rod ends. These spherical joints not only provide the highest in accuracy for ultimate motion control, but also offer extremely low noise operation for the long haul.
Custom made Massive Billet Big OD offset bushings provide extended range of motion, tight fastener clearance for noise reduction and large load bearing surface for max strength.
Included is the Massive exclusive Hardcore Hardware kit – Mil-Spec blue grade 10.9 190,000 lb tensile strength hex bolts replace your worn, rusted weak factory stuff. Reuse stock cam type inboard bolt.
As always – made in house here in the USA!!!
Available in Massive Signature Purple Pearl or Gloss Black Powder Coat.
Just $199!!! Find em Here
K Dog is offline
Fan#: 1
