2.0 Cylinder Head Temp readings - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 05-01-2011, 04:30 PM   #1
daveringstaff
Fan#: 84320
What I Drive: 2000 ZX3
FF Reputation: 1 daveringstaff Good Standing Member
Hey all,
I wanted to try and have a thread where those with the 2.0 zetec dohc can post the temperatures they get when in the odometer testing mode so I can see if I am within the right temps with my focus.
When city driving after the car is warm, I run between 91* Centigrade and 97* Centigrade.
On the highway at high speeds upwards of 65mph I have gotten between 104* Centigrade and 107* Centigrade.
I'd like this thread not to turn into anything other than objective posting of the temps you are getting between city driving and highway driving.
And this is only for the 2.0 dohc zetec engine which uses a cylinder head temperature sensor and not an engine coolant sensor.
If you don't know how to get to your odometer test mode, follow this link:
http://www.focushacks.com/index.php?...%20Test%20Mode
Then go to the reading that has 0## C (that will be a number where the hash marks are)
Really hope we can see a bunch of your readings! Heading on a road trip and would like to be sure my temps are normal!
daveringstaff is offline
Old 05-01-2011, 09:54 PM   #2
daveringstaff
Fan#: 84320
bumpz0rs
Old 05-02-2011, 01:12 AM   #3
drostedrummer89
I <3 my SVT
drostedrummer89's Avatar
Fan#: 69059
What I Drive: 2002 Sonic SVT
Points 5,199, Level 46
Points: 5,199, Level: 46 Points: 5,199, Level: 46 Points: 5,199, Level: 46
Level Up 25% Completed
Level up: 25% Level up: 25% Level up: 25%
FF Reputation: 8 drostedrummer89 Good Standing Member
Buy-Sell-Trade Rating: (10)
I don't mind getting some numbers for you, do all zetecs use the cylinder head temp sensor, or do some use coolant temps?
Matt
Posted via FF Mobile
drostedrummer89 is offline
Old 05-02-2011, 08:17 AM   #4
1turbofocus
FF Affiliate
1turbofocus's Avatar
Fan#: 1123
Points 51,854, Level 100
Points: 51,854, Level: 100 Points: 51,854, Level: 100 Points: 51,854, Level: 100
Level Up 0% Completed
Forum Activity 31%
Activity: 31% Activity: 31% Activity: 31%
Buy-Sell-Trade Rating: (28)
All Focus Zetec use Cyl Head Temp but its convirted to water temp
180 thurmostat and a tune for the fans and you can lower the water temps a good bit
Customer Support
AIM: hpdyno
Email: hpdyno@aol.com
Phone: 704-249-3745
Site: focus-power.com
Elder 1turbofocus
1turbofocus is offline
Old 05-02-2011, 08:23 AM   #5
daveringstaff
Fan#: 84320
Its not a fan issue. The higher temps only happen at highway speeds, 65mph+.
I made a video, sorry for quality, but you can see my speed with the corresponding CHT. As you can see, it gets to 102* C before I get off the highway, then from 0mph to 40mph, the temp goes down to 94* C
Fans work, radiator is brand new, water pump is brand new, radiator cap is brand new, thermostat is brand new (180* F stat) and has been flushed twice recently.
Here is the video...
http://www.youtube.com/watch?v=Yuc_4Se5vV8
Old 05-02-2011, 08:24 AM   #6
daveringstaff
Fan#: 84320
Matt
I'd love to see your numbers since you have same year and model car as I have.
Definitely would like to see your temps at 70mph for 10-15 minutes.
Old 05-02-2011, 09:34 AM   #7
1turbofocus
FF Affiliate
Fan#: 1123
Forum Activity 31%
Lets see 102 is what 214-216 thats very normal for the Zetec engine most run in the 219-225 range and I have seen higher
Adding a 180 thurmostat wont do much for lowering the temps if the fans are not reset to come on sooner
Customer Support
AIM: hpdyno
Phone: 704-249-3745
Elder 1turbofocus
Old 05-02-2011, 11:25 AM   #8
daveringstaff
Fan#: 84320
WHoa,
So, you're saying that the 2.0 zetec dohc engine on the ford focus normally runs at temperatures above 107* centigrade while at highway speeds?
This is what my mechanic said. This is what you say. However, plenty of foci owners say that is too hot, and i called 5 ford service centers and they don't know anything about cylinder head temps. So... I wouldn't recommend taking your car to a Ford dealer =\
You would think a Ford service center would be aware of normal engine temps and fluctuations. They didn't even know about the testing mode with the odometer :(
Old 05-02-2011, 01:34 PM   #9
Focus7081
Fan#: 83591
What I Drive: 2003 Ford Focus
FF Reputation: 1 Focus7081 Good Standing Member
I see you have two threads going about the same thing. So, I posted on both. lol. Like I posted on your other thread, maybe check your cat? Causing heat? Also, I have put in a new t-stat, and it was bad!
http://www.focusfanatics.com/forum/showthread.php?t=257067
Mine might run cooler due to the modified t-stat. It always has coolant flowing regardless if t-stat is open or closed. This might be cooling it sooner and keeping it cool? I don't know. Maybe someone else will post a pic of what they get to compare?
Post from your other thread I posted my car on there and here.
I made sure car was warm. I also drove it 5 miles before getting on freeway (to make sure it was warm). I then drove it 10 miles and got 78*C (same on the way back which would give you 20 miles). No traffic. Temp outside is 70*F in sunny California. I have a 180* stat and the copper plug (1/8" hole) removed for more coolant flow if t-stat is open or closed. Sorry for the shacky pic, not young anymore
-SOLD CAR-
-After zetec swap, car never ran right.
-Was a member of the "#2 dropped valve seat" club...Twice! Now a SPI->Zetec club member.
Focus7081 is offline
Old 05-02-2011, 03:05 PM   #10
drostedrummer89
I <3 my SVT
Fan#: 69059
See I said 98 is normal for most modern cars, 102 is nothing to worry about. You said 107 at times, which is probably a little high. I will do it on the way home tonight, around 7 pm eastern.
Matt
