Remote Start and "Open Door Shut Off" - Page 5 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 02-04-2012, 05:18 PM   #41
84convertablegt
Fan#: 94511
What I Drive: 2012 White Focus S
FF Reputation: 1 84convertablegt Good Standing Member
Well, the part I got was CM5Z-19G364-B This is for vehicles with KEY start. I dont have the part number, but it IS different if you have the mykey feature(s) / push button start. It is also a slightly more difficult installation. I got it for 229 dollars. Everything needed is included and it is for the bi-directional model.
84convertablegt is offline
Old 02-04-2012, 05:19 PM   #42
84convertablegt
Fan#: 94511
Also, this kit includes the bypass and everything. You dont have to buy anything else.
Old 02-19-2012, 01:12 PM   #43
Yamazama
Fan#: 94122
What I Drive: 2012 Tux Black Focus Ti 18"
FF Reputation: 1 Yamazama Good Standing Member
Success with only 6 options in Bank 2 on 2012 Ti
Same story.. purchased a 2012 Ti with dealer installed Remote Start. Engine turned off as soon as I touched the door handle (keyless). I found the remote start module tucked up behind my glove box accessible through the glove box inner back side. The Program Button was obvious and mounted right beside the module along side the red LED.
Option Bank 2 only had 6 options settings when I scrolled through with the brake pedal. I'm guessing some of us have different firmware or something. After playing around a bit, this is how it now functions:
-Remote starts with 2 sec hold
-Honks 4 times on start up and door remain locked to anyone without the fob
-Car DOES NOT shut off when I touch handle or open the door. Nice!
Settings:
Option 1: LED Off
Option 2: LED Off
Option 3: LED On
Option 4: LED On
Option 5: LED On
Option 6: LED On
The 4 honks are annoying. Still trying to figure that out. I should mention that using the pdf I downloaded here, from start to finish it took me 10 min to get this figured out. The dealership said it would charge me 1 hour labour and $130-150 to do the same thing. Oh did I mention I'm an engineer for Ford? And that I purchased the car on A-plan? If this is how dealerships treat their own... rant rant... I'll pipe down now.
If anyone with a 6 option Bank 2 figures out how to set it up so it doesn't honk AND without restart needed.. please post the settings.
Yamazama is offline
Old 02-19-2012, 03:28 PM   #44
DemskeetSkeet
Fan#: 88167
What I Drive: 2012, Black Focus Hatch SEL 302a
FF Reputation: 1 DemskeetSkeet Good Standing Member
-Honks 3 times on start up and door remain locked to anyone without the fob
Settings:
Option 1: LED Off
Option 2: LED Off
Option 3: LED On
Option 4: LED On
Option 5: LED On
Option 6: LED On
The 3 honks are annoying. Still trying to figure that out. I should mention that using the pdf I downloaded here, from start to finish it took me 10 min to get this figured out. The dealership said it would charge me 1 hour labour and $130-150 to do the same thing. Oh did I mention I'm an engineer for Ford? And that I purchased the car on A-plan? If this is how dealerships treat their own... rant rant... I'll pipe down now.
That is a great start!
I was curious about how many feet from the antennae is the program button? Mine was ran up above the windshield then down the front stile on the driver side window.
2012 Black SEL Ford Focus 302a & remote start
Ordered July 21st
Vin received early August
Build Date: 08/16/2011
Picked up: 08/25/2011
DemskeetSkeet is offline
Old 02-20-2012, 05:50 PM   #45
Yamazama
Fan#: 94122
My antennae is in the top right hand corner of my windshield. The wire behind my passenger side a-pillar trim, and down into the IP behind the glove box. Follow that wire to the Remote Starter module (about the size of an old VHS tape). I would say I have about 4-6 ft of wire between the module and the antennae. The Program Button is on a branch of wire very close to the module. You can't miss it.
Yamazama is offline
Old 02-20-2012, 06:06 PM   #46
Yamazama
Fan#: 94122
Settings:
Option 1: LED Off
Option 2: LED Off
Option 3: LED On
Option 4: LED On
Option 5: LED On
Option 6: LED On
I need to correct my above statement. The horn chirps 4 times (not 3) with the above settings. In the remote start manual it says that 4 horn chirps means that my tach isn't programmed?? From what I've read, Option 1 should be "ON" indicating "Tachless mode". My above fix has Option 1 set to "OFF" which seems to prevent the auto-shutoff but triggers the 4 horn chirp error. I'm not sure if this could cause other issues. I'm going to go keep playing with it and will report back.. Any thoughts are welcome.
Yamazama
Yamazama is offline
Old 02-20-2012, 07:23 PM   #47
BAZINGA_2012
Fan#: 95358
What I Drive: 2012 Red Candy Titanium
FF Reputation: 1 BAZINGA_2012 Good Standing Member
Following you closely here, Yamazama. Looks like you have the same car and situation I do. I was very disappointed with how the remote start operated but a guy at the dealership told me I could probably find out how to re-program it here as he was legally bound (his words) to program it as it was. Since it's a push button start, do you actually have to start the car to start programming it? I did find my programming/override button so I at least have that info. Also, once programmed to continue running when the door is open, are you able to hit the break and shift gears without it shutting down? I'm kind of afraid to start messing with it but I guess I'll always be able to get it programmed back to how it started so it at least works..... hopefully.
BAZINGA_2012 is offline
Old 02-20-2012, 10:02 PM   #48
Yamazama
Fan#: 94122
So I have a 2012 Focus Ti with a dealer installed remote start. This is how I accessed the program menu: Yes you actually start the car.
The steps are:
-Ensure doors and liftgate are closed
-Depress and hold brake
-Press 'start' button (engine running now)
-Press and hold the Program button until the horn chirps 3 times signalling it's ready mode
-Press and release Program button, the horn will chrip 4 times indicating Option Bank 1. Scroll to Option Bank 2 with the Program Button (5 chirps indicates Option Bank 2). Scroll through options with a press/release of the brake pedal. Horn will chirp back at you to indicate what Option you are on (2 chirps, option 2; 3 chirps, option 3; etc). Once in an option, you can turn it on or off with a single click of the button on the transmitter.
-Turn the car off to save the settings.
To summarize what I've read, the problem has to do with the MyKey feature. When you remote start a car that has a keyless feature, it starts off a hidden fob imbedded in the remote start module. By default the 'safety' feature is actually just a way of making sure MyKey still functions with a remote start. By having the car shut down, it forces a restart. This time it starts off the drivers fob and thus retains any of the MyKey settings. Otherwise, if it stayed on, and a driver with MyKey functions set on his fob entered the car, those settings would not retain as the original start came off the hidden admin fob. That's why the dealership is giving people a hard time when they ask to disable shut-off. I checked the Installation manual for this remote start and the only thing programming instructions the Dealership Mechanics are given is to ensure Option 1 in Program Bank 2 is ON. Which goes against my "solution" above.
Yamazama is offline
Old 02-20-2012, 10:07 PM   #49
Yamazama
Fan#: 94122
I was very disappointed with how the remote start operated but a guy at the dealership told me I could probably find out how to re-program it here as he was legally bound (his words) to program it as it was..
I feel the same disappointment. Interesting to hear what your dealership said, because the guy at my dealership said he could change it for 130 bucks! So much for being legally bound. What a rip off! Once you know how to do it, it's about as hard as setting the time on your stove.
Yamazama is offline
Old 02-20-2012, 10:25 PM   #50
BAZINGA_2012
Fan#: 95358
Thanks for sharing what you have figured out. I do feel better equiped now to try to take this on. Maybe I'll give it a go tomorrow afternoon after work.
