Remote Start and "Open Door Shut Off" - Page 4 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 10-23-2011, 03:57 PM   #31
Kakakidan
Fan#: 85841
What I Drive: Waiting for 2012 focus titanium h/b
FF Reputation: 1 Kakakidan Good Standing Member
how did you enter into the programming mode on titanium with push button start
Kakakidan is offline
Old 12-20-2011, 08:55 PM   #32
astonius
Fan#: 92951
What I Drive: 2006 Saleen S281 S/C
FF Reputation: 1 astonius Good Standing Member
Having issues changing the settings. I can get into programming mode without issue, and I can change banks and options, no problem. The issue comes when trying to change a setting. The LED on the fob doesn't show anything, and when I press the button on the fob to change the setting nothing happens. No LED change, no horn honk, nothing. If I press and hold the button the factory reset initiates (as indicated by the four honks), but it doesn't respond to a press and release at all. This is on a 2012 Focus Titanium with Intelligent Access. Any ideas?
astonius is offline
Old 12-22-2011, 05:59 PM   #33
Rat Fink
Fan#: 92487
What I Drive: Ford, and vintage Dodge
FF Reputation: 6 Rat Fink Good Standing Member
The LED to watch is underneath the dash, and part of the remote start wiring harness (not the fob). It should be within a foot of the remote start module. Look under your dash. If you can't directly see the LED, then look for the red glow from it. When you are in one of the programming options, it will turn on or off with a single push of the remote start button.
Rat Fink is offline
Old 12-26-2011, 06:12 PM   #34
astonius
Fan#: 92951
Thanks! Now another issue: there are only 6 options in bank 2 on my titanium instead of 8. It has the intelligent key. How can I disable the unlock shutoff with no 7th option?
astonius is offline
Old 12-28-2011, 07:38 PM   #35
zick2500
Fan#: 93140
What I Drive: 2012, Black, SE
FF Reputation: 1 zick2500 Good Standing Member
Without the 7th option I don't think your going to be able to.
I just got a 2012 SE w/ the dealer installed remote starter and was able to disable the shut off when opening the doors.
Mine went up to option 7 on bank two before starting over so I was able to turn off that feature.
I don't know why some seem to have these options and others don't.
zick2500 is offline
Old 01-11-2012, 08:03 PM   #36
TitanRanger
Fan#: 92956
What I Drive: 2012 Ingot Silver Titanium
FF Reputation: 1 TitanRanger Good Standing Member
Originally Posted by jeff2009 View Post
Can anyone who has a titanium focus confirm that the keyless entry is always accessible if the remote start is installed?
keyless entry works with the remote starter installed. The doors unlock when I grab the door handle.
TitanRanger is offline
Old 02-04-2012, 04:45 PM   #37
84convertablegt
Fan#: 94511
What I Drive: 2012 White Focus S
FF Reputation: 1 84convertablegt Good Standing Member
FYI, I used the instructions in this thread to successfully disable the annoying "shutdown" on unlock / open door function. I had installed an OEM Ford remote starter myself on my 2012 "S" model Focus with regular key start. The install itself was actually the easiest remote starter install Ive ever done. Most of it is plug and play. Even though according to the instructions there is no option 7 in bank 2, there actually is. You can just find it by scrolling through with the brake pedal. So now I have no annoying honk, 1 press to start, 15 min run time, and I can get in and go without the stupid thing turning off. Success, thanks to the internet :)
84convertablegt is offline
Old 02-04-2012, 04:47 PM   #38
DemskeetSkeet
Fan#: 88167
What I Drive: 2012, Black Focus Hatch SEL 302a
FF Reputation: 1 DemskeetSkeet Good Standing Member
Thanks for posting!
Do you know how far down the line the programming button is from the antennae?
I know where the line runs but I don't want to start pulling things off without knowing how far to look.
Thanks!
2012 Black SEL Ford Focus 302a & remote start
Ordered July 21st
Vin received early August
Build Date: 08/16/2011
Picked up: 08/25/2011
DemskeetSkeet is offline
Old 02-04-2012, 04:50 PM   #39
84convertablegt
Fan#: 94511
Originally Posted by DemskeetSkeet View Post
Thanks for posting!
Thanks!
Well, on the factory OEM out of the box setup, the button is about 1 foot down the harness from the control module. It is very close to the LED. They both come out of the main harness connection. I put mine right under the trim above where your legs sit while driving. It is not connected to the antenna harness. It is attached to the main remote starter harness near the control module. FYI, mine is a bi-directional model, but Im sure the one way is the same.
Old 02-04-2012, 04:58 PM   #40
Joeywhat
Strichmädchen & Koks
Joeywhat's Avatar
Fan#: 85247
What I Drive: 2014 Mustang 3.7L SGM
Points 8,143, Level 60
Points: 8,143, Level: 60 Points: 8,143, Level: 60 Points: 8,143, Level: 60
Level Up 97% Completed
Level up: 97% Level up: 97% Level up: 97%
Forum Activity 8%
FF Reputation: 11 Joeywhat Great Standing Member
What exactly did you have to buy, and from where? I just searched fordparts.com and there's a bunch of remote start stuff, but no 'packages'. I'm very interested in getting it, and since you said it was easy to install may do it myself.
Hatch Nation #29
Joeywhat is online now
