Remote Start and "Open Door Shut Off" - Page 3 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 05-20-2011, 08:20 PM   #21
2012silversel
2012silversel's Avatar
Fan#: 83969
What I Drive: 2014 C-Max Energi, Sterling Gray
Points 1,963, Level 26
Points: 1,963, Level: 26 Points: 1,963, Level: 26 Points: 1,963, Level: 26
Level Up 63% Completed
FF Reputation: 1 2012silversel Good Standing Member
Originally Posted by warneej View Post
Yes I understand the Minnesota thing, I grew up in Upstate NY so I've had my share of -20. I solved that by moving . All I wish is that the remote start (when offered) was integrated into the keyfog like GM has been doing for almost a decade (probably the only thing they did right IMHO).
I agree, it would be nice if it was integrated into one fob. I have the same cold weather solution in my plans. I own a home in Sun City, AZ and will be permanently moving there in 6 years.
2014 C-Max Energi
302A Package
Sterling Gray
2012silversel is offline
Old 05-20-2011, 08:22 PM   #22
jeff2009
Fan#: 85828
What I Drive: 2009 Eclipse
FF Reputation: 1 jeff2009 Good Standing Member
There is a good possibility you could cancel. It renders it useless because you have to turn the car off and then back on, seems silly to me. You also may have to leave a prox key within the car which sounds like a recipe for having your vehicle broken into as the door unlocks when you touch the inside of the door handle if the key is near. There may be a work around but it seems like it would make the cool keyless thing not cool or totally keyless.
Can anyone who has a titanium focus confirm that the keyless entry is always accessible if the remote start is installed?
jeff2009 is offline
Old 05-20-2011, 11:47 PM   #23
entity
Fan#: 85163
What I Drive: 2012 Focus Titanium
FF Reputation: 1 entity Good Standing Member
Here is the PDF that another member sent me. I have yet try it, but I will report back once I do.
Feel free to test it out and let everyone else know how it went. Maybe a how-to? :)
Remote start programming 710620.pdf
entity is offline
Old 05-24-2011, 08:10 AM   #24
BiggerBoat
BiggerBoat's Avatar
Fan#: 85913
What I Drive: 2012 Red Candy Titanium Hatch
FF Reputation: 3 BiggerBoat Good Standing Member
I have the Titanium with dealer remote start. I have no problems with the keyless functions. However, as I noted in my original post, once in the car after a remote start, I can find no way to avoid an engine stop and restart before departing. I have not received a call back from my dealer who promised to look for a "workaround".
I don't expect this is a major tragedy (since I don't expect to use it that often) but its just lame for it to work this way having bought the top of the line setup. As with every technology company now, things are rushed out before they are thought through . There is no such thing as a thorough beta test phase anymore.
BiggerBoat is offline
Old 05-24-2011, 08:23 AM   #25
BiggerBoat
BiggerBoat's Avatar
Fan#: 85913
I remote started without leaving the regular keyfob in the car. Then again, I was only about 25 feet from the car with both fobs. I don't know what the range of the std fob (keyless entry) is vs. the remote start fob.
Old 08-28-2011, 08:58 PM   #26
DemskeetSkeet
Fan#: 88167
What I Drive: 2012, Black Focus Hatch SEL 302a
FF Reputation: 1 DemskeetSkeet Good Standing Member
Does anyone know where the "programming" button is? I cannot for the like of me find it anywhere in the 2012 Focus Hatch SEL.
2012 Black SEL Ford Focus 302a & remote start
Ordered July 21st
Vin received early August
Build Date: 08/16/2011
Picked up: 08/25/2011
DemskeetSkeet is offline
Old 10-15-2011, 01:18 PM   #27
Magazyne
Fan#: 90473
What I Drive: 2012 Focus Titanium Candy Blue
FF Reputation: 1 Magazyne Good Standing Member
Exclamation
I have a 2012 Focus Titanium with IA Push Button Start and recently had the remote start installed by the dealer. I found the programming button on the passenger side. I was able to successfully disable the annoying honk when remote starting and also change the setting to remote start on 2 button presses instead of press & hold.
I only have one remaining problem. The "Open Door Shut Off" feature is supposedly in Option Bank 2, however, Option Bank 2 ends at Option #6 (Horn Honk on Start). I can't seem to get to Option #7 to change the "Open Door Shut Off" behavior. Does anyone know why?
Thanks!
Magazyne is offline
Old 10-15-2011, 02:27 PM   #28
DemskeetSkeet
Fan#: 88167
Thanks!
Well you've gotten farther than most of us so great work there! Where is the program button at? If I can find mine with your help I could try mine out to see what happens!
Thanks & nice work!
Ordered July 21st
Old 10-15-2011, 02:39 PM   #29
Magazyne
Fan#: 90473
Thanks & nice work!
You'll have to look under the dash and around the floor area in both the driver's and passenger side. It may be tucked behind a panel or the carpet so it's concealed pretty well. Every installer chooses a different location. It looks like just a regular wire with a button on the end. The button is about the size of a pencil eraser :)
Magazyne is offline
Old 10-15-2011, 09:24 PM   #30
DemskeetSkeet
Fan#: 88167
Thanks. Mine is run along the top of my windshield and then tucked behind the white piller on the left side of the windshield.
I was curious how far down it is on the wire from the start of the antennae?
Ordered July 21st
