Remote Start and "Open Door Shut Off" - Page 12 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 11-21-2012, 02:35 PM   #111
TiPilot
TiPilot's Avatar
Fan#: 93667
What I Drive: 2012 Ingot Silver Ti Hatch
FF Reputation: 1 TiPilot Good Standing Member
Originally Posted by bellamr View Post
The program override button is fairly close to the module (around 12"). I would think it is unlikely that the button is located on the driver's side if your module is behind the glove box.
The glovebox is easy to remove;
1. Remove the right hand instrument panel side trim panel
2. Remove the right hand lower instrument panel insulator.
- Remove the 2 retainers.
3. Remove the glove compartment.
- Remove the 5 torx t25 screws. (1-side, 2-top, 2-bottom {way at the back})
It takes me about 5 minutes now, but on the first attempt to remove the glove box it took me about 30 minutes to find the 2 bottom torx t25 screws.
Yeah, I was hoping to avoid it... but that actually doesn't sound too bad. Thanks for the instructions!
2012 Focus Ti Hatch | Ingot Silver | 401A, Nav, Winter Pkg, Moon Roof, Parking Tech. Pkg
Build Date: 12/2/2011 | New APIM: 4/4/2012
MFT: Factory v2.11, 3/14/12 Web -> v3.0.2, 9/24/12 Web -> v3.2.2, 1/24/13 Web -> v3.5.1, 8/13/13 Web -> v3.6
TiPilot is offline
Old 06-14-2013, 11:24 PM   #112
Guilty Trace
Guilty Trace's Avatar
Fan#: 97641
What I Drive: 2012 Tuxedo Black Titanium
Points 382, Level 7
Points: 382, Level: 7 Points: 382, Level: 7 Points: 382, Level: 7
Level Up 64% Completed
FF Reputation: 1 Guilty Trace Good Standing Member
I had been wanting to disable the shutdown on door open feature forever and finally found the programming button under the glove compartment, behind the tear away fabric that lines the passenger foot well. However, as I followed the instructions on the PDF I found online, it turned out that I only had 6 options in my available options bank no matter if I had a MyKey programmed to the car or not (which I thought was the deciding factor since the PDF says "NON MY-KEY OPTIONS" and "MY-KEY OPTIONS"). While I did change my remote start time to 15 minutes from 10, disabled the horn honk on remote start and I changed the input from "push and hold" to "push twice," I was dismayed that I couldn't access the MY-KEY OPTIONS so I could scroll to option 7 and disable the one thing I started doing all of this for in the first place! Has anyone had any success in this and, if so, how the hell did you do it? Thanks forum!
Guilty Trace is offline
Old 09-21-2014, 10:02 PM   #113
SilverPony2001
SilverPony2001's Avatar
Fan#: 27073
What I Drive: 2013 SGM Sedan SE
Points 6,761, Level 54
Points: 6,761, Level: 54 Points: 6,761, Level: 54 Points: 6,761, Level: 54
Level Up 6% Completed
Forum Activity 3%
FF Reputation: 9 SilverPony2001 Good Standing Member
Bumping an old thread, but have some questions. I just put in the Ford bidirectional remote start today and want to make sure I got everything hooked up correctly.
First question, when you remote start the car does the car lock itself before it starts, if the doors are unlocked?
Second question.... I have the same problem as others with a newer system, I don't have a 7th bank to disable the car shutting off after opening a door. Has anyone with this problem tried using Focccus to disable the MYKEY? According to the manual, if you don't have MYKEY then the door opening should not shut off the car.
Thanks!
SilverPony2001 is online now
Old 10-09-2014, 12:10 AM   #114
SilverPony2001
Fan#: 27073
Forum Activity 3%
Ok, I got everything working correctly now. Just wanted to add, my remote start DOES have the 7th option in the second bank to keep the car running after opening the door. It's not documented anywhere in the manual that came with it though. It shows that bank 7 is "unused". I'm not sure when they decided to program this back into it, but it works. The sticker on the brain module had a date of 2013 if that makes any difference. Just an FYI for anyone thinking about purchasing one.
Old 11-23-2014, 11:46 AM   #115
oktoberrust11
Fan#: 90598
What I Drive: 2012 White Plat Ti
Points 15, Level 1
Points: 15, Level: 1 Points: 15, Level: 1 Points: 15, Level: 1
Level Up 29% Completed
Level up: 29% Level up: 29% Level up: 29%
FF Reputation: 1 oktoberrust11 Good Standing Member
Read through the thread, great info, but I'm not grasping which bank/option I need to toggle. I have a '12 Ti w/ push start; all I want to do is to disable the shutoff when the doors are opened/unlocked. I found the programming button under the glove compartment, and cycled through the (4) options in bank 1 & the (6) options in bank 2 (no option 7). Which of the below options do I toggle? (copied/pasted from earlier posts):
Option Bank 1 - 4 chirps
Option 1: Tach Learn (N/A)= OFF
Option 2: Door Ajar Polarity(On=pos; Off=Neg) = OFF
Option 3: Key in sense Polarity (On=pos; Off=Neg) = ON
Option 4: Extended Horn Output (On=3x horn output; Off=Normal horn ouput) = OFF
Option Bank 2 - 5 chirps
Option 1: Blind Crank of Tach Mode (On=blind crank; Off=Tach Mode) = OFF
Option 2: Crank Time (On=1sec; Off=8sec) = ON
Option 3: Run Time (On=15min; Off=10min) = ON
Option 4: Start Activation (On=hold 2.5 seconds; Off=double press button) = ON
Option 5: Diesel Timer (On=30sec crank delay; Off=No Delay)= OFF
Option 6: Hon on Start (On=honk confirmation: Off=No honk) = OFF
Thanks,
Matt
oktoberrust11 is offline
Old 11-23-2014, 12:02 PM   #116
oktoberrust11
Fan#: 90598
Points 15, Level 1
Scratch that request. I re-read Yamazama's findings, and the statement "I'm uncertain as to why Tach Mode seems to cancel the auto shut off." triggered that Option Bank 2, Option 1 is the toggle I was looking for. Thanks!
I don't quite understand why, unlike before when I had 1 chirp after the car started, I now have to choose between 0 chirps and 4 chirps, but oh well. This is huge that I can leave my car running after unlocking it! Thanks a ton everyone.
Old 01-21-2015, 03:11 PM   #117
seaclusion4100
Fan#: 118782
What I Drive: 2014 Charcoal Focus SE
Points 4, Level 1
Points: 4, Level: 1 Points: 4, Level: 1 Points: 4, Level: 1
Level Up 7% Completed
FF Reputation: 1 seaclusion4100 Good Standing Member
Hello
I have been reading through the messages but I haven't seen yet where the instructions are on exactly how to get into the programming mode and how to navigate through the programming mode.
If you have them and could just email me direct it would be great.
Thanks
Dave
seaclusion4100@outlook.com
seaclusion4100 is offline
Old 01-22-2015, 07:50 AM   #118
oktoberrust11
Fan#: 90598
Points 15, Level 1
Originally Posted by seaclusion4100 View Post
Hello
Thanks
Dave
From Yamazama's post back on page 5:
So I have a 2012 Focus Ti with a dealer installed remote start. This is how I accessed the program menu: Yes you actually start the car.
The steps are:
-Ensure doors and liftgate are closed
-Depress and hold brake
-Press 'start' button (engine running now)
-Press and hold the Program button until the horn chirps 3 times signalling it's ready mode
-Press and release Program button, the horn will chrip 4 times indicating Option Bank 1. Scroll to Option Bank 2 with the Program Button (5 chirps indicates Option Bank 2). Scroll through options with a press/release of the brake pedal. Horn will chirp back at you to indicate what Option you are on (2 chirps, option 2; 3 chirps, option 3; etc). Once in an option, you can turn it on or off with a single click of the button on the transmitter.
-Turn the car off to save the settings.
