No Radiator Fan After Thermo Replacement - Page 2 - Ford Focus Forum, Ford Focus ST Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum > Ford Focus Tech Discussions > General Technical Chat
Old 05-01-2011, 12:35 AM   #11
Focus7081
Fan#: 83591
What I Drive: 2003 Ford Focus
FF Reputation: 1 Focus7081 Good Standing Member
Originally Posted by sokratz View Post
Actually found the procedure on focushacks. Any idea what temp the fans should kick in on?
Thanks!
Here...110C* on and of @ 102C* This is the engine temp not the coolant temp.
http://www.focusfanatics.com/forum/showthread.php?t=255079
-SOLD CAR-
-After zetec swap, car never ran right.
-Was a member of the "#2 dropped valve seat" club...Twice! Now a SPI->Zetec club member.
Focus7081 is offline
Old 07-21-2013, 07:07 PM   #12
Bassplayer62
Fan#: 116529
What I Drive: 2003 se 2.3l silver sedan.
FF Reputation: 1 Bassplayer62 Good Standing Member
I am the same problem with my 2003 2 .3 li. the fanscome when on the AC is on, but they don't come on when the car gets hot. is it possible to jumper the resistor and run the fans and high speed all the time
Bassplayer62 is offline
Old 07-22-2013, 12:54 PM   #13
amc49
Fan#: 96610
Points 2,845, Level 32
Points: 2,845, Level: 32 Points: 2,845, Level: 32 Points: 2,845, Level: 32
Level Up 64% Completed
Forum Activity 85%
Activity: 85% Activity: 85% Activity: 85%
FF Reputation: 23 amc49 Great Standing Member
Resistor not the issue there, it's working or fans wouldn't come on in a/c.
amc49 is offline
Old 07-24-2013, 08:20 PM   #14
Bassplayer62
Fan#: 116529
True. I have bench tested fans and works fine. I jumpered the low speed relay, and fans come on. I jumpered high speed relay and fans come on. I have replaced the cyl head temp sensor ( I replaced when i dod the head gasket). So from the way i see it, the PCM is not telling the fan relay to turn on when teperature is reached. So I am at a loss for where to go from here, other than taking it in to a shop $$$$
Old 07-24-2013, 08:28 PM   #15
Bassplayer62
Fan#: 116529
At 97c the coolant backs up to the expansion tank and overflows. I have new tank and cap.
Old 07-26-2013, 04:33 PM   #16
amc49
Fan#: 96610
Forum Activity 85%
That could just be a leak, assuming coolant and not straight water. With proper pressure retention you should have no boil there at that temp at all. You're boiling there, should not happen until cap popped. Maybe leak somewhere else.
Normal system should be able to shut down and five minutes later come back and pop cap loose and get some good hiss doing so. If it won't at all, especially even after a
minute only you have a pressure leak somewhere.
Sure the head job went right? Many often run into unforeseen troubles once one back together, simply changing gasket alone often doesn't get it by itself. Overheat affects other parts as much as the gasket. Warped head or block deck can re-leak even with a new gasket.
The PCM is NEVER going to tell low fan to come on at what it considers to be too cold.
amc49 is offline
Old 07-27-2013, 06:07 PM   #17
Bassplayer62
Fan#: 116529
I had the head resurfaced and valve job and pressure tested. Initially I filled with 50/50 antifreeze/water. AI drove around block and it overheated. Then replaced thermostat which was corroded. (had trouble finding it, had to remove ps pump and a/c compressor to get to it). Replenished with 1 quart wayer. . At what temp should fans come on?
Old 07-28-2013, 07:46 AM   #18
amc49
Fan#: 96610
Forum Activity 85%
Low fan around 225F, high at around 235F. Don't hold to exact number, it can vary a couple of degrees.
amc49 is offline
Old 07-28-2013, 02:13 PM   #19
Bassplayer62
Fan#: 116529
That being the case, since I depleted coolant from the fozen themostat, I will drain and replenish with 50/50 antifreeze and try to get the car to that temp. I will post the outcome.
