Go Back   Focus Fanatics > Ford Focus Tech Discussions > ECU Tuning Chat
ECU Tuning Chat Discuss performance tuning options for your Ford Focus.
Old 04-27-2011, 10:02 AM   #31
illinipo
Token Engin-nerd
illinipo's Avatar
Fan#: 37693
What I Drive: dirty wag; Party; Bavarian phallus
FF Reputation: 272 illinipo Outstanding Standing Memberillinipo Outstanding Standing Memberillinipo Outstanding Standing Member
Buy-Sell-Trade Rating: (19)
Originally Posted by 1turbofocus View Post
He has the correct KS logged in his list
Originally Posted by EggYolkedZX3 View Post
the first "KNOCK SENSOR RETARD LIMIT" DMR in the SBAF6 processor code list
Not if he is using the first one.
But what the hell do I know (nothing apparently)
Originally Posted by Dennis_Grant
Remember this list: Bilstein; Penske; Koni; Ohlins; Sachs; Dynamic Suspension.
Not on this list? Almost certainly crap.
SUV this!
illinipo is offline
Old 04-27-2011, 01:16 PM   #32
BowerR64
BowerR64's Avatar
Fan#: 78699
What I Drive: 2007 DX3 SE
FF Reputation: 12 BowerR64 Great Standing Member
Bower you have a Duratec and your KS readings will be diff
ok i thought he just wanted to see some other logs.
DX3?.. huh?.. well ZX3 = Zetec the 05-07 has a Duratec so DX3
BowerR64 is offline
Old 04-27-2011, 06:00 PM   #33
EggYolkedZX3
EggYolkedZX3's Avatar
Fan#: 61654
What I Drive: '01 Yellow ZX3, '04 Blue SVT w/EAP
FF Reputation: 8 EggYolkedZX3 Good Standing Member
Originally Posted by illinipo View Post
SBAF6 has two DMRs that are described as KNOCK SENSOR RETARD LIMIT. I've talked to SCT about this at least 10 times over the last 3 years and all they have done was change the name of one of them, not the description. You need to take a closer look at the names, or download the latest livelink if you cannot see the difference I outline below.
KNK_RET_LIM is the first one. There is a table in the ECU with axes of RPM against load that simply limits the amount of knock retard you can get. It is -5 in almost all cells, with a few at low and high rpm at -4. The reason you are seeing -5 on this DMR only when you are moving or transbraking is the sensor is not allowed to be active at all until 0.359 load, and you would be hard pressed to see that much load without the car in gear (Tom already metioned this earlier in the thread). So basically whenever you are driving, as you describe, this should rightly show -5.
KNK_SEN_RETARD is the second one, the one you actually want to log, this is the actual knock retard. This one you ought to be able to at least see it ramp down (instead of jump down) to -5, and ramp slowly back up (instead of jump up) when you let off the throttle, if it is indeed pulling full knock retard.
You and Tom are both right. Thanks for the awesome detailed response though!
It turns out the right KNK SEN RETARD was being logged. I had the view on the "long name PIDs" setting instead of the "16 Char Name PIDs". In the long name veiw, both DMR's show up exactly the same as "KNOCK SENSOR RETARD LIMIT" but for some reason the correct one to be logged comes up first in the PID list. In the 16 view, the correct one comes up second on the list?
But yes, the graph shows a short little spike (about 0.6-1.0 advancement) then drops straight down to -5. Just waiting for my new one to see if anything changes.
EggYolkedZX3 is offline
Old 04-27-2011, 06:02 PM   #34
illinipo
Token Engin-nerd
illinipo's Avatar
Fan#: 37693
After going through the same process on a NFC1 car of buying a new sensor and lashing the valves to min spec, with no change in the sensor activity, I would recommend you guys just lower the sensitivity from the get-go. The combination of listening to it and lowering sensitivity would be very effective.
But supposedly I don't know what I'm doing so you probably should just ignore my posts.
SUV this!
illinipo is offline
Old 04-27-2011, 07:04 PM   #35
BowerR64
BowerR64's Avatar
Fan#: 78699
Why do you keep saying that?
Maybe you should make that your sig so you wont have to keep typing it.
BowerR64 is offline
Old 04-28-2011, 07:46 AM   #36
Roushturboedzx3
I Fab Too Much
Roushturboedzx3's Avatar
Fan#: 42814
What I Drive: 2002 Liquid Gray ZX3
FF Reputation: 20 Roushturboedzx3 Great Standing Member
Buy-Sell-Trade Rating: (18)
My knock sensor has been turned off for over a year now. There not accurate. I have logs of it picking up noise from the wastegate and it would pull 2degrees. Also when I would shift fast it would think it was knock and pull 5 degrees then slowly put it back in. As long as your tuner knows what he is doing there should be no problems. Also I fill up at any gas station. Hess, Bp, sans club. Etc.
New: 2012 Mustang GT premium
SOLD:RACE GAS 602whp 501tq Pump Gas SAE 454whp
Garrett GT3582r, Topmount, built motor, Ported head,Tuned by Fernando@RacingPartsSolution
I may not be the baddest, but the baddest dont Fu** with me
Roushturboedzx3 is offline
Old 04-28-2011, 01:58 PM   #37
BowerR64
BowerR64's Avatar
Fan#: 78699
How do you have it turned off?
I wondered about that myself, when i started reading about what they are and how they work. Then listening to sound clips i must say it sounded a little iffy to me. I then read where some one said they use some kind of audio filtering or somthing to single out the knock. It makes a little more sence till the OP said they are only $30. for the sensor now im starting to wonder.
If i raced my car i dont think ide want one pulling timming out but for how im using my car ill leave it alone.
BowerR64 is offline
Old 04-28-2011, 04:47 PM   #38
1turbofocus
FF Affiliate
1turbofocus's Avatar
Fan#: 1123
What I Drive: 2000 ZX3 / 2002 SVT , Turbocharged
FF Reputation: 146 1turbofocus Excellent Standing Member1turbofocus Excellent Standing Member
Buy-Sell-Trade Rating: (28)
You actually do want it to pull timing if you have knock and on the Zetec and Duratec they work perfectly on about 99% of the Foci
Its my opinion to leave the knock sensor on as it is a HUGH safety for your engine , yes you may see some knock on gear change but thats perfectly normal because of tip in timing adding timing on tipin in among other things
Please leave your KS on at all times unless you have a SVT
Customer Support
AIM: hpdyno
Email: tom@focus-power.com
Phone: 704-249-3745
Site: focus-power.com
Elder 1turbofocus
1turbofocus is offline
Old 04-28-2011, 06:43 PM   #39
EggYolkedZX3
Fan#: 61654
I just got my new KS and rear o2 sensor thanks to RockAuto.com, only took them 2 days! Once my car cools down, I'll be installing both things and report back if anything changes.
Old 04-28-2011, 09:21 PM   #40
Roushturboedzx3
I Fab Too Much
Fan#: 42814
I agree a knock sensor is a nice backup if something goes wrong (gas, boost,etc) but the focus ones are not calibrated right. they pick up the noise from the drums on the dyno, road noise, wastegate, and shifting.
Pulling 5.5 degrees (not 5 like i thought) is not normal. the car fell on it face everytime.
Also you know as well as i do that chris focus blew the ringlands with a J&S on it when you tuned it. there was deto marks on the piston head. I bring chris car up cause it had the J&S on it and still went. I would love if we had a company that would make a nice External knock system for our cars that get away with the factory one.
