knock sensor issues - Page 3 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 04-25-2011, 09:50 PM   #21
1turbofocus
FF Affiliate
1turbofocus's Avatar
Fan#: 1123
Points 51,787, Level 100
Points: 51,787, Level: 100 Points: 51,787, Level: 100 Points: 51,787, Level: 100
Level Up 0% Completed
Forum Activity 32%
Activity: 32% Activity: 32% Activity: 32%
Buy-Sell-Trade Rating: (28)
Try changing it
Customer Support
AIM: hpdyno
Email: hpdyno@aol.com
Phone: 704-249-3745
Site: focus-power.com
Elder 1turbofocus
1turbofocus is offline
Old 04-25-2011, 10:21 PM   #22
sleepyboy
FF's Night Security
sleepyboy's Avatar
Fan#: 15335
Points 138,132, Level 100
Points: 138,132, Level: 100 Points: 138,132, Level: 100 Points: 138,132, Level: 100
Forum Activity 54%
Activity: 54% Activity: 54% Activity: 54%
Buy-Sell-Trade Rating: (11)
^^right, do the easiest thing first. It's much harder to track down a short or something that might not even exist.
Moderator for
Technical Chat
Zetec Performance Chat
Southern Fanatics Chat
sleepyboy is offline
Old 04-25-2011, 10:26 PM   #23
BowerR64
BowerR64's Avatar
Fan#: 78699
What I Drive: 2007 ZX3 SE
Points 12,075, Level 72
Points: 12,075, Level: 72 Points: 12,075, Level: 72 Points: 12,075, Level: 72
Level Up 7% Completed
FF Reputation: 12 BowerR64 Great Standing Member
They are one of the more expensive sensors though
It's not important to win, it's important to make the other guy lose.
BowerR64 is offline
Old 04-26-2011, 02:21 AM   #24
EggYolkedZX3
EggYolkedZX3's Avatar
Fan#: 61654
What I Drive: '01 Yellow ZX3, '04 Blue SVT w/EAP
Points 859, Level 15
Points: 859, Level: 15 Points: 859, Level: 15 Points: 859, Level: 15
Level Up 59% Completed
FF Reputation: 8 EggYolkedZX3 Good Standing Member
They're not too bad actually. Just ordered one from RockAuto for about $28 plus shipping. I'll guess we'll see what happens when it gets here.
EggYolkedZX3 is offline
Old 04-26-2011, 04:18 AM   #25
BowerR64
BowerR64's Avatar
Fan#: 78699
REALLY! I thought they were around $100. Was it a PITA to get to it?
BowerR64 is offline
Old 04-26-2011, 08:49 AM   #26
redZX300
Fan#: 39044
What I Drive: 2000 red zx3
FF Reputation: 2 redZX300 Good Standing Member
Its basically right next to your oil filter.
redZX300 is offline
Old 04-26-2011, 08:17 PM   #27
BowerR64
BowerR64's Avatar
Fan#: 78699
oh you have the older motor. I have the duratec i think mine is more work.
BowerR64 is offline
Old 04-27-2011, 02:18 AM   #28
illinipo
Token Engin-nerd
illinipo's Avatar
Fan#: 37693
What I Drive: dirty wag; Party; Bavarian phallus
FF Reputation: 272 illinipo Outstanding Standing Member illinipo Outstanding Standing Member illinipo Outstanding Standing Member
Buy-Sell-Trade Rating: (19)
I'm wondering what others who datalog with the first "KNOCK SENSOR RETARD LIMIT" DMR in the SBAF6 processor code list see as far as values or on the graph while doing a normal cruise datalog. My issue currently is when I log the KS (on either the stock tune or on Tom's tune, doesn't matter), it shows that I'm always knocking and pulling -5 degrees of timing usually right around 2000 rpm or above.
SBAF6 has two DMRs that are described as KNOCK SENSOR RETARD LIMIT. I've talked to SCT about this at least 10 times over the last 3 years and all they have done was change the name of one of them, not the description. You need to take a closer look at the names, or download the latest livelink if you cannot see the difference I outline below.
KNK_RET_LIM is the first one. There is a table in the ECU with axes of RPM against load that simply limits the amount of knock retard you can get. It is -5 in almost all cells, with a few at low and high rpm at -4. The reason you are seeing -5 on this DMR only when you are moving or transbraking is the sensor is not allowed to be active at all until 0.359 load, and you would be hard pressed to see that much load without the car in gear (Tom already metioned this earlier in the thread). So basically whenever you are driving, as you describe, this should rightly show -5.
KNK_SEN_RETARD is the second one, the one you actually want to log, this is the actual knock retard. This one you ought to be able to at least see it ramp down (instead of jump down) to -5, and ramp slowly back up (instead of jump up) when you let off the throttle, if it is indeed pulling full knock retard.
Originally Posted by Dennis_Grant
Remember this list: Bilstein; Penske; Koni; Ohlins; Sachs; Dynamic Suspension.
Not on this list? Almost certainly crap.
SUV this!
illinipo is offline
Old 04-27-2011, 05:06 AM   #29
BowerR64
BowerR64's Avatar
Fan#: 78699
Well im not sure what your looking for and i dont even know what all this says. I probobly dont even have the same setup logs as you.
Here is the last one i ran a few nights ago.
All of my KS settings are just flat all the way across
BowerR64 is offline
Old 04-27-2011, 08:10 AM   #30
1turbofocus
FF Affiliate
Fan#: 1123
Forum Activity 32%
Bower you have a Duratec and your KS readings will be diff
He has the correct KS logged in his list
Customer Support
AIM: hpdyno
Phone: 704-249-3745
Elder 1turbofocus
