knock sensor issues - Focus Fanatics
Go Back   Focus Fanatics > Ford Focus Tech Discussions > Focus Tuning Chat
Old 04-22-2011, 01:08 AM   #1
EggYolkedZX3
EggYolkedZX3's Avatar
Fan#: 61654
What I Drive: '01 Yellow ZX3, '04 Blue SVT w/EAP
FF Reputation: 8 EggYolkedZX3 Good Standing Member
knock sensor issues
First off, I have an '01 ZX3 with the Zetec/ATX and have an XCAL 3 w/ Tom's tune.
I'm wondering what others who datalog with the first "KNOCK SENSOR RETARD LIMIT" DMR in the SBAF6 processor code list see as far as values or on the graph while doing a normal cruise datalog. My issue currently is when I log the KS (on either the stock tune or on Tom's tune, doesn't matter), it shows that I'm always knocking and pulling -5 degrees of timing usually right around 2000 rpm or above. The problem is though, I'm not hearing or feeling any detonation at all. I believe my KS is bad or something else making noise is setting it off but not positive. My graph would show a straight line at 0 when idling and almost always goes straight down to -5 when it hits the 2000 rpm mark and eventual goes back to 0. But there is never an in between, always at 0 or a straight vertical to -5 with the occasional advancement.
So I was wondering what should I be seeing on the graph or in values as far as the KS? Should it mostly read at 0 with very little timing being pulled at any rpm range with advancement here and there or what? I'd appreciate any advice or suggestions on this issue from others who know what I'm talking about. Its causing me to not be able to get tuned and I'd like to change that asap. Its impossible to get a proper tune when the KS decides to max out pulling timing.
Thanks in advance,
Steven
EggYolkedZX3 is offline
Old 04-23-2011, 01:50 PM   #2
EggYolkedZX3
Fan#: 61654
Bump for some help!
I'd really like to know what I should be seeing on the graph when I log the knock sensor.
Old 04-23-2011, 02:45 PM   #3
1turbofocus
FF Affiliate
1turbofocus's Avatar
Fan#: 1123
FF Reputation: 153 1turbofocus Excellent Standing Member1turbofocus Excellent Standing Member
Buy-Sell-Trade Rating: (28)
You shouldnt see anything 0
Customer Support
AIM: hpdyno
Email: hpdyno@aol.com
Phone: 704-249-3745
Site: focus-power.com
Elder 1turbofocus
1turbofocus is online now
Old 04-23-2011, 06:04 PM   #4
JCH841
JCH841's Avatar
Fan#: 79303
What I Drive: 2013 Blue ST3
FF Reputation: 3 JCH841 Good Standing Member
We used to see false knock in boat engine EFI from loose motor mounts, etc. I think even a couple of loose knock sensors. Make sure you don't have anything like that.
Growing old is unavoidable. Growing up is optional.
JCH841 is offline
Old 04-24-2011, 12:33 AM   #5
EggYolkedZX3
Fan#: 61654
Well today I found a few new things but the problem is still there.
First thing I found was the wire that goes from the battery to the alternator was rubbing on the stud where the knock sensor mounts. I moved it but the car still shows knock during a datalog.
I decided to log the car while free reving not in gear and in drive while on the jack stands still and the KS read 0 all through out the rpm's, couldnt get it to show knock. Then I go to put the car on the ground and go for a cruise. Well the same thing as before happens anywhere above about 2000rpm while accelerating in a gear, the KS goes off.
I guess I'll play with it more tomorrow and see if I get anything to work correctly. Is it unheard of to have a KS go bad? Starting to think its the problem.
EDIT: I tried transbraking while on jackstands to create load and the KS shows knock. Graph looks the same as if driving it on the street. So now, I think I've got this narrowed to a load issue. Gonna try a new set of Motorcraft spark plugs tomorrow and see what happens, cant hurt anything. I believe now its either ignition related or the KS itself is way too sensitive. I'll update tomorrow. Oh and I've run 87oct, 91oct, and 96oct all with the same knock results on the stock tune.
Old 04-24-2011, 02:32 AM   #6
BowerR64
BowerR64's Avatar
Fan#: 78699
What I Drive: 2007 ZX3 SE
FF Reputation: 12 BowerR64 Great Standing Member
If the knock sensor was bad or going bad wouldnt you feel a major power loss?
I read the life of the knock sensors are like 10 years. I read you can trick the sensor temporarily to trouble shoot problems. emergency solution not a long term solution.
It's not important to win, it's important to make the other guy lose.
BowerR64 is offline
Old 04-24-2011, 09:10 AM   #7
1turbofocus
FF Affiliate
Fan#: 1123
We talked about all the things that need to be checked and I dont see where you have tested any of them
Customer Support
AIM: hpdyno
Phone: 704-249-3745
Elder 1turbofocus
Old 04-24-2011, 12:35 PM   #8
EggYolkedZX3
Fan#: 61654
Ok,
The first thing you said was run 5 gallons of 91oct and 5 gallons of 100oct which averages out to 95.5 but since I had a little less 91oct in the tank already it came out to be about 96oct. Knock still showed in the datalog, just like the 87oct log, after wasting over $50 for a 3/4 tank of gas (remember jobless high school kid here)... That rules out bad gas though, right?
Next you said to get a piece of garden hose and listen around for metal noise while someone holds the rpms around 2000rpm. Well since I can only do that in place and already stated the KS doesnt pick up anything while revving in place, then what am I supposed to hear? I already said there's nothing out of the ordinary. Acording to datalogging, this only happens when driving around or transbraking on jackstands. Must be a load issue now, right?
And that's all you've said.
Old 04-24-2011, 02:46 PM   #9
1turbofocus
FF Affiliate
Fan#: 1123
You will only see knock after a set load and RPM , you have to have load to have/see knock
I was asking you to check thing to see if you had something loose and vibrating and that would cause the knock sensor to go off
I can adjust the sensitivity of the knock sensor but I would like to know for sure it isnt something else
Customer Support
AIM: hpdyno
Phone: 704-249-3745
Elder 1turbofocus
Old 04-24-2011, 05:37 PM   #10
redZX300
Fan#: 39044
What I Drive: 2000 red zx3
FF Reputation: 2 redZX300 Good Standing Member
is this an NA focus?
redZX300 is offline
