2012 Focus owners - how do you like Powershift tranny so far? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 04-22-2011, 01:56 AM   #1
focus11
Fan#: 62411
What I Drive: Honda Civic
FF Reputation: 2 focus11 Good Standing Member
For those who own a 2012 Focus with the Powershift 6-speed automatic transmission, so far how do you like it? Any problems or concerns you might have? I recently test drove 2 Focus models (1 sedan, 1 hatchback) and the Powershift performed flawlessly and seamlessly. Felt very much like a regular automatic transmission. I came away very impressed with the performance.
Thanks for your feedback!
focus11 is offline
Old 04-22-2011, 11:54 AM   #2
Targon
Fan#: 81074
What I Drive: 2012 Focus SEL 5-door
FF Reputation: 2 Targon Good Standing Member
I don't have one YET, but the two that I took for a test drive felt very smooth and NOT like most automatics. The normal slow shifting really does feel like it is gone. I suspect that some work is still needed for WHEN the car should shift, but it feels VERY smooth in acceleration.
Targon is offline
Old 04-22-2011, 10:20 PM   #3
autolite
autolite's Avatar
Fan#: 46002
What I Drive: 2006 pitch black zx4
Points 457, Level 9
Points: 457, Level: 9 Points: 457, Level: 9 Points: 457, Level: 9
Level Up 14% Completed
FF Reputation: 3 autolite Good Standing Member
Heard there is are are issues with them shuddering till you get over 300 miles on them.Then they are fine.
autolite is offline
Old 04-23-2011, 07:49 AM   #4
usapatriot
Fan#: 73594
What I Drive: 09' Black SE Coupe
FF Reputation: 0 usapatriot Newbie
Like any new car, all the parts have to break in.
usapatriot is offline
Old 04-23-2011, 09:00 AM   #5
mmmoose
Bunneh Fanatic
mmmoose's Avatar
Fan#: 39963
What I Drive: 2008 United Gray VW Rabbit
FF Reputation: 9 mmmoose Good Standing Member
The low-speed "shuddering" is normal for any dual clutch transmission. The same effect can be felt on a GTI or R32 with VW's DSG transmission. A lot customers simply don't understand that a dual clutch transmission is basically an automated manual transmission, and that manual transmissions by nature have a very notchy feel to it.
Traditional automatics use a torque converter to help synchronize gear changes and make shifting smoother. It also unfortunately delays the process of shifting itself and saps power from the engine in the process. And CVT equipped cars don't have any physical gears to speak of, so they're even smoother. So any regular customer who goes from driving one of those to a dual clutch transmission car will probably think that something is wrong when they feel the transmission jerking.
Ford could definitely solve the problem by making the lower gears taller, or by inducing some type of artificial delay in the shifting process. However your fuel economy will suffer and the transmission won't feel nearly as responsive. Essentially you're taking away the two major benefits of even using this transmission technology to begin with.
The bottom line is if some people can't handle the way this transmission works, they should look into getting a car with a regular automatic or CVT instead. There's no reason Ford should have to resort to castrating the PowerShift transmission for the sake of smoothness. I'm sure in the future they'll find ways to make it shift smoother without compromising anything. But for now this is what it is.
-Moose
mmmoose is offline
Old 04-23-2011, 11:43 AM   #6
DrkKnight614
GO Green
DrkKnight614's Avatar
Fan#: 14522
Points 25,851, Level 96
Points: 25,851, Level: 96 Points: 25,851, Level: 96 Points: 25,851, Level: 96
Level Up 51% Completed
Level up: 51% Level up: 51% Level up: 51%
FF Reputation: 47 DrkKnight614 Great Standing Member
Good post, and I totally agree. Ford better not! Ill have a shit fit.
Posted via FF Mobile
DrkKnight614 is offline
Old 04-23-2011, 11:07 PM   #7
2012htch
Fan#: 84735
What I Drive: 2012 kona blue hatch sport package
FF Reputation: 1 2012htch Good Standing Member
I find the trans very smooth. I try to make the car jerk at 1st gear but it just shifts when expected! If you never drove a manual you would not notice the feeling of the dual clutch, it's hard to explain!
2012htch is offline
Old 06-05-2011, 03:55 PM   #8
CoasterDan
Fan#: 86083
What I Drive: 2012 Focus SE Hatch Tuxedo Black
FF Reputation: 1 CoasterDan Good Standing Member
Sorry Moose but I have to disagree. No auto. transmission should shudder at any speed. I drove the VW dsg transmission only once, but I did not feel any low speed shudder as I am feeling (sometimes) in my new Focus. Hopefully, the problem will correct itself with more miles. The problem wouldn't be solved with taller gears; that might only make things worse. A delay in the shifts (there's already some delay or at least "softness"--the shifts are softer than VW's dsg) wouldn't help the shudder either.
As for manual transmissions (I have own in my current car and have owned several cars with them), if they are driven properly, they are very smooth.
I like firmer shifts and the response, weight savings and hopefully fuel savings you can get from a dual clutch transmission, but Ford has to get it right. The Powershift is the only auto. transmission offered in what is supposed to be a high volume car. I'm sure that most of these cars will be equipped with the Powershift. Shuddering and jerky shifts (I'm getting those when the car is cold) will turn buyers off. I can live with these relatively minor issues, even if they are not resolved, but I'm not sure that everyone would want to.
It might help if the Ford salespeople explained to the potential customers that the transmission is not like a typical auto. trans. and will act a little differently in some respects. However, I'm not sure that they have the requisite knowledge to be able to do that and/or that they want to. My salesman said nothing about the dual-clutch Powershift.
Having said all that, I do like the Focus a lot and if it proves to be reliable, will enjoy driving it for years.
CoasterDan is offline
Old 06-05-2011, 06:38 PM   #9
firstfordever
Fan#: 85944
What I Drive: 2012 Titanium Hatchback White plati
FF Reputation: 1 firstfordever Good Standing Member
no problems with mine
I have not noted any problems with mine and have 1600 miles on it so far. I find it shifts very smoothly with the best evidence that I don't even notice the tranny. I had an 08 Enclave where the set-up for the tranny was so bad it was difficult to drive until a reflash was offered that solved most of the problems. I am also impressed with the sport mode and do not fine the button shifter cumbersome at all as many reviewers have.
firstfordever is offline
Old 06-05-2011, 09:19 PM   #10
Spartan12
Fan#: 85167
What I Drive: 2012 Black Titanium
FF Reputation: 1 Spartan12 Good Standing Member
It's smooth, but it did confuse itself one day and clunked hard into 1st gear as I was coming to a stop.
'12 Ford Focus Titanium Hatch
'10 Infiniti G37S 6MT Coupe
'08 Ford Explorer Ironman 4.6L V8
Spartan12 is offline
Tags
dct , powershift
