Motor rebuild torque specs - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 04-16-2011, 10:51 PM   #1
crackin_x
crackin_x's Avatar
Fan#: 47785
What I Drive: 03 infra-red SVT
FF Reputation: 2 crackin_x Good Standing Member
Ok, so I did use the search button came up with bits and peices but nothing solid.
I am rebuilding my motor and need pretty much a full list of torque specs. I have a haynes manual but I don't trust those specs about as much as I would trust a man in a black panel van with candy.
Any help?
03 Infra-Red svt #1936
FS strut bar, Eibach sport system plus, Power slot front rotors, EBC greenstuff pads front and rear, CFM lower mount, VF upper mounts, Spec clutch and Aluminum flywheel stage 2, JRCS+BBK ported for 67MM TB, Torsen T2
crackin_x is offline
Old 04-16-2011, 11:04 PM   #2
iminhell
C2H5OH
iminhell's Avatar
Fan#: 36222
Points 18,689, Level 86
Points: 18,689, Level: 86 Points: 18,689, Level: 86 Points: 18,689, Level: 86
Level Up 68% Completed
Forum Activity 18%
Buy-Sell-Trade Rating: (4)
cut from the How-To section ...
... and I see the Head, Cam, Crank, Rod TQ's are not listed. But those should be easily found elsewhere ... But IIRC you're running ARP's so,
Engine Data Description 2.0L DOHC 16V
Engine management EEC V/SEFI
Emission standard 96 EEC
Fuel 91 RON unleaded
Identification code CAA
Firing order 1-3-4-2
Bore 84.8 mm
Stroke 88.0 mm
Cubic capacity 1,988 cm3
Compression ratio 9.6:1
Maximum engine performance at 5,300 rpm 130 hp
Maximum engine torque at 4,000 rpm 130 lb ft
Idle speed rpm 800 rpm
Speed limitation (rev/min) 7,100 rpm
Engine Oil Viscosity/ambient temperature Description Specification
Recommended engine oils — —
SAE 5W-20/below -30C to over +40C SAE 5W-20 Engine Oil certified for gasoline engines by the American Petroleum Institute ILSAC GF-3 and WSS-M2C153-H
SAE 5W-20/below -30C to over +40C Ford Formula E Economy Engine Oil ACEA A1/B1 and WSS-M2C914-A
If engine oils of this specification are not available, engine oils of specification API SH/EC, ACEA A2/B2 or ACEA A3/B3 may also be used.
Capacities Description Liters
Engine oil, initial fill including filter 4.35
Engine oil, oil change including filter 4.25
Engine oil, oil change excluding filter 3.75
Lubricants, Fluids, Sealers and Adhesives Item Specification
Sealant, camshaft bearing caps WSK-M2G348-A5
Sealant, cylinder block mating faces (Hylosil 502) WSK-M4G320-A
Sealant, cylinder block mating faces (Loctite Ultrablack) (alternative) WSE-M4G320-A2
Sealant, crankshaft position sensor ESW-1C155-A
Sealant, crankshaft position sensor (alternative) WSD-M1C-226-A
Sealant, oil pan WSE-M4G323-A6
Thread locking compound SDM-M4G9107-A
Spark plug thread lubricant (Never Seeze) WSD-M13P8-A1
Lubricant, injection nozzle O-rings WSEM-2C903-A1
Silicone grease for spark plug connector seal A696-M1C171-AA
High-temperature grease for clutch disc engagement splines ESD-M1C220-A
Cylinder Block Description mm
Cylinder bore diameter, class 1 84.800-84.810
Cylinder bore diameter, class 2 84.810-84.820
Cylinder bore diameter, class 3 84.820-84.830
Inner diameter, main bearing shells installed 58.011-58.038
Inner diameter, main bearing shells installed (main bearing shells with stepped sizes) 58.008-58.031
Main bearing radial clearance 0.011-0.058
Main bearing radial clearance (main bearing shells with stepped sizes) 0.020-0.042
Main bearing parent bore 62.287-62.300
Pistons Description mm
Piston diameter, class 1. 84.770-84.780
Piston diameter, class 2. 84.780-84.790
Piston diameter, class 3. 84.790-84.800
Piston clearance in cylinder 0.010-0.030
Piston ring gaps (installed) a
Upper compression ring 0.30-0.50
Lower compression ring 0.30-0.50
Oil scraper ring 0.40-1.40
a The piston ring gaps must be distributed evenly around the circumference of the piston This also applies to the oil scraper ring elements. Align the ring gaps at 120 degrees to each other.
Crankshaft Description mm
Main bearing journal diameter 57.980-58.000
Crankshaft end play 0.09-0.26
Connecting rod bearing journal diameter 46.89-46.91
Lower Crankshaft Spacer Description mm
Required spacer washer thickness if there is a gap between the cylinder block and the lower crankcase of:
0.26 mm-0.50 mm 0.25
0.51 mm-0.75 mm 0.50
Connecting Rod Description mm
Big end bore diameter 49.89-49.91
Small end bore diameter 19.951- 19.981
Inner diameter, connecting rod bearing shells installed 46.926- 46.960
Radial connecting rod bearing clearance 0.016-0.070
Axial connecting rod bearing clearance 0.090-0.320
Piston Pin Description mm
Piston pin length 55.800- 56.200
Piston pin diameter, white 19.997- 20.000
Piston pin diameter, red 20.625- 20.628
Piston pin clearance in piston 0.016-0.049
Camshaft Description mm
Bearing journal diameter 25.960- 25.980
Camshaft bearing radial clearance 0.020-0.070
Camshaft end float 0.080-0.220
Lobe lift intake 8.90
Lobe lift exhaust 8.70
Theoretical valve maximum lift intake 8.90
Theoretical valve maximum lift exhaust 8.70
Valves Description mm
Valve clearance in the valve guide
Intake valve 0.017-0.064
Exhaust valve 0.017-0.064
Intake valve clearance (at 20C 5C) 0.11-0.18
Exhaust valve clearance (at 20C 5C) 0.27-0.34
Cylinder Head Description Specification
Maximum distortion (mating surface) 0.1 mm
Height of mating surface 1.76 mm-2.12 mm
Peak-to-valley height of mating surface (reference length 2.5 mm vertical to groove direction) R 3z = 6.0 μm
Oil pressure at 800-850 rpm 1.3 bar-2.5 bar
Oil pressure at 4000 rpm 3.7 bar-5.5 bar
Torque Specifications Description Nm lb-ft lb-in
Hose clamps 4 — 35
Intake manifold studs 5 — 44
Intake manifold bolts and nuts 18 13 —
EGR tube assembly to EGR valve 40 30 —
EGR pipe to ignition coil bracket 6 — 53
EGR tube assembly to catalyst 40 30 —
Heat shield to exhaust manifold 10 — 89
Exhaust manifold studs 5 — 44
Exhaust manifold nuts 16 12 —
Catalytic converter to exhaust manifold 48 35 —
Catalytic converter to exhaust 47 35 —
Right-hand driveshaft center bearing 25 18 —
Generator to bracket 25 18 —
Generator bracket to upper cylinder block bolts 25 18 —
Generator bracket to lower cylinder block bolts 65 48 —
Transmission flange bolts 47 35 —
Starter motor to transmission 35 26 —
Oil drain plug, MTX transmission 45 33 —
Oil control plug, MTX transmission 45 33 —
Flywheel bolts 112 83 —
Clutch pressure plate 29 21 —
Engine roll restrictor to transmission 48 35 —
Engine roll restrictor to subframe 48 35 —
Engine rear mount to body 48 35 —
Engine rear mount (nut on transmission mounting bracket) 133 98 —
Engine front mount to engine 80 59 —
Engine front mount to body 48 35 —
Power steering pump to bracket 24 18 —
Power steering pump bracket 48 35 —
Cylinder head bolts a — — —
Camshaft bearing cap boltsa — — —
Cylinder head covera — — —
Spark plugs 15 11 —
Timing belt tensioner 25 18 —
Camshaft timing belt pulleys 68 50 —
Upper timing belt cover 10 — 89
Ignition coil (EI) bracket to cylinder head 21 15 —
Thermostat housing 20 15 —
Fuel rail 10 — 89
Engine rear lifting eye 16 12 —
Engine rear lifting eye studs 6 — 53
Engine front lifting eye 47 35 —
Cylinder blocka — — —
Engine oil drain plug 25 18 —
Oil pressure switch 27 20 —
Cylinder block oil gallery blanking plugs 23 17 —
Heater pipe bracket to oil pan 10 — 89
Oil pan to lower crankcasea — — —
Lower crankcase to cylinder block 22 16 —
Oil pump 11 8 —
Oil intake pipe to oil pump 10 — 89
Main bearing boltsa — — —
Connecting rod bearing cap boltsa — — —
Coolant pump 18 13 —
Crankshaft rear oil seal carrier 20 15 —
Drive belt idler pulley 40 30 —
Crankcase ventilation pipe bracket 23 17 —
Crankcase ventilation 10 — 89
Coolant pump pulley 24 18 —
Crankshaft belt pulley 115 85 —
Crankshaft position sensor bracket 21 15 —
Crankshaft position sensor to bracket 8 — 71
Idler pulley 23 17 —
Knock sensor 20 15 —
OH, you're not playing dumb ...
iminhell is offline
Old 04-16-2011, 11:06 PM   #3
crackin_x
crackin_x's Avatar
Fan#: 47785
Thank you sir.... that most certainly did not show up on the search lol
EDIT: except it is missing several specs one would need for internals.
RE-EDIT: you are right my friend I'm rebuilding the block with main studs so I won't need that spec anyway.
Old 04-16-2011, 11:10 PM   #4
sleepyboy
FF's Night Security
sleepyboy's Avatar
Fan#: 15335
Points 138,625, Level 100
Points: 138,625, Level: 100 Points: 138,625, Level: 100 Points: 138,625, Level: 100
Level Up 0% Completed
Forum Activity 50%
Activity: 50% Activity: 50% Activity: 50%
Buy-Sell-Trade Rating: (11)
Also don't forget to double check what measurements system you are using. I easily confuse in/lbs with ft/lbs. and stripped and broke a bolt when doing my cams. But I do see that each is listed next to each other so that should help greatly. I wish I had this info a few months ago lol.
Moderator for
Technical Chat
Zetec Performance Chat
Southern Fanatics Chat
sleepyboy is offline
Old 04-16-2011, 11:13 PM   #5
crackin_x
crackin_x's Avatar
Fan#: 47785
I'm downloading a factory manual now, there is not much I need to know, only thing I have not had apart on this car before is the block. Everything else I have had down to is knickers.
Old 04-16-2011, 11:15 PM   #6
sleepyboy
FF's Night Security
sleepyboy's Avatar
Fan#: 15335
Forum Activity 50%
^^about the same here. I feel like I know this car like the back of my hand lol
Moderator for
Technical Chat
Old 04-17-2011, 07:51 AM   #7
fordtech
fordtech's Avatar
Fan#: 68998
What I Drive: 04 Turbo SVTF, 88 GMC V2500
FF Reputation: 2 fordtech Good Standing Member
Buy-Sell-Trade Rating: (6)
This is straight from the ford workshop manual:
1. Tighten the main bearing and connecting rod bearing bolts.
Tighten the main bearing bolts in two stages.
Stage 1: 25 Nm.
Stage 2: 60 degrees.
2. Tighten the connecting rod bearing bolts in two stages.
Stage 1: 35 Nm.
Stage 2: 90 degrees
Funny, I just took my SVT engine apart yesterday.
fordtech is offline
