Autocross Tire Pressures - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum > Ford Focus Racing Discussions > Autocross Racing
Autocross Racing The place to discuss information about autocross stats, tips and events. Track sanctioned events only.
Old 04-15-2011, 09:21 AM   #1
John W
Fan#: 77028
What I Drive: 2012 Ford Focus SE 5MT
FF Reputation: 1 John W Good Standing Member
On Sunday, I will be autocrossing my Focus for the first time (although I have autocrossed on and off for the past 15 years) and am wondering what a good starting point for tire pressures would be.
My car is an 05 Focus SE with SVT shocks, struts and springs. It still has the stock front sway bar and no rear bar. The tires are Falken Ziex 912s, 195/60/15. Currently, the tire pressures are set 32 psi cold F/R.
The car is my daily driver and as it sits now, I know it will not be competitive. I just want to have fun and make the most of what I have.
Thanks in advance for any advice.
2012 Ford Focus SE, ╠╬╝, Sport Package, Ingot Silver. 1993 Volkswagen Fox. Formerly: 2005 Focus ZX3 SE, ╠╬╝, Pitch Black, SVT suspension.
John W is offline
Old 04-15-2011, 09:29 AM   #2
Rafal
Rafal's Avatar
Fan#: 73222
What I Drive: 2005 Beige ZX4 SE
FF Reputation: 2 Rafal Good Standing Member
When I run my Falken Ziex 912s, 195/60/15 I run front at 41-42 psi and rear 34-35 psi. Works for me I can carry enough speed thru the corners. To be honest this tires are not the best for Auto-x but for having fun they will do the trick.
17" Team Dynamics Monza,H&R Coil Overs, FS-Stealth Exhaust, FS CAI, tuned by TOM, GlowShift gauges, CFM 67mm TB, VF polyurethane engine mounts, FS lower & upper stress bars
SEDAN REVOLUTION-58
Rafal is offline
Old 04-15-2011, 10:43 AM   #3
John W
Fan#: 77028
Thanks Rafal -- your advice is helpful!
John W is offline
Old 04-15-2011, 10:47 AM   #4
tukaniSVT
FF PHOTOG ENTHUSIAST
tukaniSVT's Avatar
Fan#: 5521
What I Drive: 2003 SVT Focus 2009 BMW 335i
Points 36,504, Level 100
Points: 36,504, Level: 100 Points: 36,504, Level: 100 Points: 36,504, Level: 100
Level Up 0% Completed
FF Reputation: 34 tukaniSVT Great Standing Member
** Moved to AutoX Section **
Since this is more AutoX related, I bought it here.
For me, on Hankook RS3s I run 32-34 in the front and 28-30 in the back. This has been my fav and best runs. Of course this goes up as the heat goes on. My tire specs are 225/50 on 16s.
On my Yokohama S.Drives I ran 37-40 in the front and 34-37 in the back. Tire Specs 215/45 on 17s.
You want to have a good amount of tire touching the pavement when you are running or it will slide a bit.
PSI is a bit different per tire.
-Ray-
Hatch Nation Member: #147
R.I.P - FELLOW FF MEMBER, IZZY, BLK2k3GTS, will always be remembered. We will compete on a different course again one day.
tukaniSVT is offline
Old 04-15-2011, 11:33 AM   #5
Rafal
Rafal's Avatar
Fan#: 73222
No problem mate, let me now if that worked for you.
SEDAN REVOLUTION-58
Rafal is offline
Old 04-15-2011, 01:08 PM   #6
wrc_fan
slow
wrc_fan's Avatar
Fan#: 11913
What I Drive: 03 ZX3 Duratec 08 WRX Hatch
Points 3,584, Level 37
Points: 3,584, Level: 37 Points: 3,584, Level: 37 Points: 3,584, Level: 37
Level Up 56% Completed
FF Reputation: 23 wrc_fan Great Standing Member
Start high, and then work your way down in pressure. With a 195/60, you'll be needed at least 40 in front I think.
Parking Lot Hero
2008 WRX daily driver
2003 ZX3 23D Autox Car 42 FSP
"Hella Functional - Raced, Not Hard Parked"
wrc_fan is offline
Old 04-15-2011, 06:07 PM   #7
GodLovesUgly
.Flat Out.
GodLovesUgly's Avatar
Fan#: 56705
What I Drive: ^^^ That!
Points 28,304, Level 98
Points: 28,304, Level: 98 Points: 28,304, Level: 98 Points: 28,304, Level: 98
Level Up 96% Completed
FF Reputation: 10 GodLovesUgly Great Standing Member
Buy-Sell-Trade Rating: (7)
chalk the side of your tires, it's much easier to see where they are wearing.
as mentioned every tire and every surface will need different psi. also factor in the weather, on hot days the PSi will rise so you'll have to keep a close eye on it.
on my kumhos i run 35-38 in the front and about the same in the rear.
The Rich Get Richer Until The Poor Get Educated.
Do Vegetarians eat Animal Crackers?
Moderator of Ford Focus Racing Discussions & Rocky Mountain Fanatics
GodLovesUgly is online now
Old 04-19-2011, 08:54 PM   #8
John W
Fan#: 77028
I ended up running about 41 psi front/36.5 psi rear. Surprisingly, this even allowed my car -- with no rear sway bar -- to rotate a bit in certain sections of the course. Predictably, the tires didn't work particularly well. Not much grip and findable traction was in short supply. I ended up placing 7th out of 13 cars in ST, which I think is fine considering the tires and that the only upgrade to my car is SVT springs and shocks, which are really stock pieces anyways.
John W is offline
Old 04-19-2011, 10:18 PM   #9
GodLovesUgly
.Flat Out.
Fan#: 56705
wrong thread :)
Old 04-20-2011, 11:01 AM   #10
Rafal
Rafal's Avatar
Fan#: 73222
YEah this falken s are not great for that kind of driving I had the same problem. Word on a street is that for ST class this setup is the best 15x7.5" with some toyo 195/50/15.
SEDAN REVOLUTION-58
Rafal is offline
