Timing belt replacement interval - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 04-13-2011, 12:51 PM   #1
ajoregon
Fan#: 84873
What I Drive: 2004, white, wagon
FF Reputation: 1 ajoregon Good Standing Member
At 69k miles I suppose it's time to change out the timing belt. Haynes makes it look alot easier than the one I changed on my 96 dodge stratus 2.4. At least there is a way to lock in TDC and secure the cams. Is it really that easy? Al
ajoregon is offline
Old 04-13-2011, 04:33 PM   #2
Fucus-minded
Fucus-minded's Avatar
Fan#: 72986
What I Drive: 2003, black, Ford Focus SE Wagon
FF Reputation: 3 Fucus-minded Good Standing Member
Buy-Sell-Trade Rating: (8)
mmm depends what you call easy... I just did it and it def takes the better part of a day. you have to take off the coolant resevoir, pax mount, waterpump pulley, crank pulley both timing belt covers...I would have a decent sized pry bar with me as there really is no room for that waterpump pulley to get out of there. its a pita but i got through it so it cant be that hard, lol.
Fucus-minded is offline
Old 04-17-2011, 11:01 PM   #3
TeamZetec
TeamZetec's Avatar
Fan#: 84603
What I Drive: 2000 Focus SE Zetec
FF Reputation: 1 TeamZetec Good Standing Member
my mom's Atlantic Blue 2000 Ford Focus SE w/ Zetec made it to 130k miles on the original timing belt before it went. They are non-interference motors so i would just run your Focus till the timing belt goes. Thats what I do when I buy a car that has a non-interference engine. Now my Focus with the SPI...thats a different story...they are interference...and my timing belt is dry rotted. Replace replace replace...always at or before 60k miles when you have interference engine
TeamZetec is offline
Old 04-18-2011, 11:20 AM   #4
ajoregon
Fan#: 84873
Thanks for the input. I read conflicting information about this engine as far as the interval (60K verses 120K) and the possible valve/piston damage (interference verses non-interference) so it is good to hear of your experience. Thanks again. AJOregon
ajoregon is offline
Old 05-05-2011, 01:42 AM   #5
Vexorg
Vexorg's Avatar
Fan#: 85499
What I Drive: 2001 Zx3 ChromeGold
FF Reputation: 3 Vexorg Good Standing Member
It's my undertanding that it's a "freewheeling" motor, and a Failed belt won't seal your engine's fate. I suggest visual inspection, and if it's not broken or looking shabby, don't fix it. I've had 125K on one thats still feeling fine.
Vexorg is offline
Old 05-29-2011, 09:38 PM   #6
bradmra
Fan#: 73319
What I Drive: 02 ZX5, 2011 Optima SX
FF Reputation: 1 bradmra Good Standing Member
between 90-100k miles is when the timing belt needs to be changed from what I've been told.
bradmra is offline
Old 05-29-2011, 09:46 PM   #7
Djzx3
WRX/Focus:)
Djzx3's Avatar
Fan#: 76864
What I Drive: 04 WRB WRX / 00 se zxw
FF Reputation: 33 Djzx3 Great Standing Member
Buy-Sell-Trade Rating: (6)
The non SVT Zetec's are non-interference, but there has been a few case's of people having a couple valves bent.
And I found doing the timing with the Haynes manual to be somewhat easy, but as said before, the hardest part is the water pump pulley. I got the one's that I could from the top, then lowered the engine some to be able to get to that T-50 I think, and even then a ratchet is not possible, I had to use a 10MM wrench to turn the T50 bolt in the bottom.
2000 SE wagon 2.0l Zetec.
HN #17
D23 crew-#1
Djzx3 is offline
Old 06-08-2014, 09:34 AM   #8
truckguy
Fan#: 168602
What I Drive: 2002 racing green ZX3
Points 5, Level 1
Points: 5, Level: 1 Points: 5, Level: 1 Points: 5, Level: 1
Level Up 9% Completed
FF Reputation: 1 truckguy Good Standing Member
I bought my 2002 ZX3 last August with 201,000 miles on it...my mechanic took the timing belt cover off to check the belt...the belt had white cracks on the outside of the belt...he said its original and wouldn't drive it out of this garage so I decided to have it done. Wouldn't surprise me that this timing belt was original....but I used the best parts and had it done the right way....and next change over will be at 321,000 (at 120,000 mile interval) miles.
truckguy is offline
Old 06-10-2014, 08:19 AM   #9
amc49
Fan#: 96610
Points 3,274, Level 35
Points: 3,274, Level: 35 Points: 3,274, Level: 35 Points: 3,274, Level: 35
Level Up 50% Completed
Forum Activity 11%
ALL timing belts on these are 120K change now, the change happened when belt material changed on all around '98 or so. Before that the belt makers advertised 60K on everything. Both SPI and standard zetec motors are non-interference, the standard zetecs I've heard of bending valves are ones overseas with different dish in piston tops that valves then hit to bend. US models won't unless it's a SVT. On SVT you change the belt early or nix the motor, it WILL bend valves.
amc49 is offline
Old 06-12-2014, 01:42 AM   #10
a_2000_se
a_2000_se's Avatar
Fan#: 62964
What I Drive: 2000 SE SOHC SPI, Compression @ 164
Points 4,699, Level 43
Points: 4,699, Level: 43 Points: 4,699, Level: 43 Points: 4,699, Level: 43
Level Up 75% Completed
Forum Activity 5%
FF Reputation: 15 a_2000_se Great Standing Member
Originally Posted by amc49 View Post
ALL timing belts on these are 120K change now......
I know this is an older thread but have to ask.......
Five years ago I put a 60k mile belt on the car, not knowing how much longer the car would be around. This past summer I changed the belt, had just under 60k, and put on another 60k belt from Advanced Auto - again thinking this would be the last one. Is Advanced Auto just being ultra conservative?
When looking at belts five years ago some were advertised as 90k mile belts from the parts stores. So it looks like you could have anything from a 60k, 90k or a 120k belt depending on where and what was previously installed
Member of the Dropped Valve Seat Club.
Replaced #4 Piston, Rings, Rod+Bearings, AERA Re-Manufactured Cylinder Head and a light Hone. Then CLEANED the hell out of everything.
60k+ miles.
a_2000_se is offline
