2012 owners Post your MPG's - Page 66 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 04-02-2012, 04:11 PM   #651
Pretherius
Pretherius's Avatar
Fan#: 97062
What I Drive: 2012 SE Sedan 5-Spd Sterling Gray
FF Reputation: 1 Pretherius Good Standing Member
My first post here! :)
'12 SE sedan, 5 speed manual, steel 16's.
I've only filled up once since the dealer filled it when I bought it 2 weeks ago. I let the gas pump shut off on it's own and didn't add another drop since I figured this is what the dealer did, at best.
I got 34.4 MPG over about 250 miles. This is with neutral costing, predictive stops, slow acceleration, etc.
My mileage computer claimed 37.2 IIRC. It gave me a totally bunk reading on my drive home of 43.5. I assume that's part of why the computer read 3mpg high. My best theory is the computer takes a little time to get accurate.
I have a 22-mile commute that includes something around 15 to 30 stops each trip depending on traffic and how I hit the lights.
I'll be filling up again this week and I'll report back on the second tank if I remember it.
Pretherius is offline
Old 04-02-2012, 04:14 PM   #652
TboneZX3
Ford Fiend
TboneZX3's Avatar
Fan#: 90494
Points 1,277, Level 19
Level Up 77% Completed
You should do better coasting in gear. In gear, the injectors will shut off when you're coasting. In neutral, the engine must burn fuel to run at idle.
Hatch Nation #90
TboneZX3 is offline
Old 04-02-2012, 04:16 PM   #653
Pretherius
Pretherius's Avatar
Fan#: 97062
That's brilliant. Has anyone been able to test & confirm? Do we know anything about what conditions cause the injectors to shut off?
Also, hypothetically... Let's say you're riding down a long, slow hill doing 65mph on the highway. Assuming you're unwilling to shut off the engine... Do you a) coast in neutral if it allows you to maintain 65 without touching the accelerator, or b) leave it in 5th but hold down the accelerator to maintain speed because powertrain friction slows you down?
Old 04-02-2012, 04:20 PM   #654
TboneZX3
Ford Fiend
TboneZX3's Avatar
Fan#: 90494
It will shut the injectors off as long as you're off the gas and above idle RPM. As I understand it, this is how most, if not all, modern FI vehicles operate.
Hatch Nation #90
TboneZX3 is offline
Old 04-02-2012, 06:05 PM   #655
Infam0usprime
Infam0usprime's Avatar
Fan#: 96862
What I Drive: 2012 Ford Focus Ti | 2001 Dodge Ram
FF Reputation: 2 Infam0usprime Good Standing Member
ive gotten 37 on the highway and i average 27-28 mpg
Infam0usprime is offline
Old 04-02-2012, 07:55 PM   #656
unfocused1
Fan#: 95246
What I Drive: 2012 Candy Blue Ford Focus SEL
Points 986, Level 16
Points: 986, Level: 16 Points: 986, Level: 16 Points: 986, Level: 16
Level Up 86% Completed
FF Reputation: 2 unfocused1 Good Standing Member
My 2012 SEL still sees its Avg MPG readout increase.
As of today it's 30.1.
I've only driven winter blend gasoline so far, and typical fill-ups have seen 27~30MPG, which is fantastic. Both fill-ups that is, I'm almost at my third and I've driven 732 miles, so my net MPG so far is 31.016949... which is sweet given winter blend gas...
As for absolute lows and highs, I've not yet tabulated... but I tend to do more city driving than highway...
unfocused1 is offline
Old 04-03-2012, 08:26 PM   #657
kam327
-----<M>-----
kam327's Avatar
Fan#: 94700
What I Drive: '14 Ruby Ti w/ Handling Pkg
Points 7,056, Level 55
Points: 7,056, Level: 55 Points: 7,056, Level: 55 Points: 7,056, Level: 55
Level Up 53% Completed
Forum Activity 11%
FF Reputation: 13 kam327 Great Standing Member
Suburban commuting, including city traffic at one end.
kam327 is offline
Old 04-03-2012, 11:38 PM   #658
Boomertwo
Fan#: 96378
What I Drive: 2012 Ford Focus S
FF Reputation: 1 Boomertwo Good Standing Member
Figured I'd throw my stats in so far.
Car: 2012 Ford Focus S
Transmission: 5 Speed Manual
The first 3 fill-ups were 80-90% city driving and it was still within the break-in period.
All fill-ups were with 87 octane mostly from Krogers Fuel. The last 2 fill-ups were from Sunoco.
Date: 3/9/2012
Gallons: 3.87
Miles Driven: 82
MPG: 26.09802673
Odometer Reading: 258
Date: 3/16/2012
Gallons: 7.561
Miles Driven: 218.1
MPG: 28.84539082
Odometer Reading: 476
Date: 3/21/2012
Gallons: 8.367
Miles Driven: 249.4
MPG: 29.80757739
Odometer Reading: 766
Date: 3/28/2012
Gallons: 6.413
Miles Driven: 231.9
MPG: 36.16092312
Odometer Reading: 998
Date: 4/3/2012
Gallons: 7.855
Miles: Driven 281.5
MPG: 35.83704647
Odometer Reading: 1279
So far I have been very happy with the fuel efficiency as it has been pretty close to what was advertised. I know the first 1k miles we are not suppose to record our MPG but I did it anyway for my records. Also the last tank MPG were lower as I got a little rev happy since the break-in period was over so I gave it some gas a few times on the on ramps to the highway.
Boomertwo is offline
Old 04-04-2012, 12:05 AM   #659
thelongone13
thelongone13's Avatar
Fan#: 95644
What I Drive: 2012 Oxford White Focus SE Hatch
FF Reputation: 1 thelongone13 Good Standing Member
I know, not as detailed as most of you, but I'm averaging about 31, mostly city.
2012 Oxford White Focus SE Sport w/SelectShift
2012 Mini Cooper Clubman (wife)
A Ford Focus driver with ADD
thelongone13 is offline
Old 04-04-2012, 01:08 AM   #660
drufause
Fan#: 96294
What I Drive: 2012 titanium hatch silver
FF Reputation: 1 drufause Good Standing Member
This weekend got 37mpg on a 1200 mile road trip. My daily driving around town I get 25mpg
drufause is offline
