*Massive Absolute Timing Tool Kit Zetec/Duratec V2.0 Released* - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 04-07-2011, 03:00 PM   #1
K Dog
FF Affiliate
K Dog's Avatar
Fan#: 23554
What I Drive: Car
Points 15,888, Level 81
Points: 15,888, Level: 81 Points: 15,888, Level: 81 Points: 15,888, Level: 81
Level Up 8% Completed
Buy-Sell-Trade Rating: (19)
Massive has improved upon it's already superlative timing tool set with our new version 2.0.
Updated product description:
A true cut above in quality and accuracy! You’ll need these tools to positively hold your crank and cams in place whilst timing your motor. Several manufacturers have discontinued their tools. None offered the level of precision found here. 3 piece kit covers all Zetec and Duratec motors.
This high quality kit features both the cam lock gage, and 2 crank stop TDC pins (One for Zetec, one Duratec! This kit covers both!). Using both of these will allow you to be 100% certain your cam install results in proper timing – failing to do so can have very disasterous results – bent valves, smashed pistons, etc.
Gage is much more than simply a piece of bar stock like others have produced – it is a much thicker (and hence stronger) bar that features 2 machined releifs offering a TIGHT +/- .001” fit. A much more accurate means of locking your cams, resulting in less need for cam degreeing post install.
Pins are super tolerance monolithic machined 6061 aluminum for an exact fit. Pins are anodized in high vis Massive Purple for corrosion resistance and this bright coloring will help to remind user of removal(seen folks leave it in – NOT good!). Should pin be left in, aluminum construction will give way without harming vital engine internals. Handle area has built in hex for tool usage. Alpha stamping so you’ll know the difference between the 2 pin styles.
Quality made IN HOUSE right here in the USA!!!
Just $34.57, only $30.76 with our 11% OFF discount code til April 18th! (Use code: IRSWON)
Find it Here
K Dog is offline
    Quick reply to this message
Old 04-07-2011, 08:31 PM   #2
tobyboom
Fan#: 6129
What I Drive: 2000 Black boosted ZX3
FF Reputation: 1 tobyboom Good Standing Member
Buy-Sell-Trade Rating: (10)
Vewry noice dawg
2000 Black ZX3
TIMES:
1/4: 12.557 @ 112 (new time)
1/8: Dont remember at the moment
POWER: 302.25 HP 278.66 TQ
MODS: Custom Focus-Power Intake System
tobyboom is offline
Old 04-08-2011, 12:55 AM   #3
goinloco1
Late for Dinner
goinloco1's Avatar
Fan#: 8529
What I Drive: kermit
Points 14,711, Level 78
Points: 14,711, Level: 78 Points: 14,711, Level: 78 Points: 14,711, Level: 78
Level Up 66% Completed
Forum Activity 20%
Activity: 20% Activity: 20% Activity: 20%
FF Reputation: 90 goinloco1 Excellent Standing Member
right on time. have a collection of bars, pins are another story... don't forget to remove them when torquing the crank snout bolt. Or for that matter before cranking the engine over... been there done that. no fun removing everything to get at a pin bent flat against the inside of the block...
goinloco1 is online now
