a/c low pressure port - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 04-06-2011, 06:55 PM   #1
johnhagen
Fan#: 78457
What I Drive: 2003 Focus SW
Points 1,288, Level 19
Points: 1,288, Level: 19 Points: 1,288, Level: 19 Points: 1,288, Level: 19
Level Up 88% Completed
Level up: 88% Level up: 88% Level up: 88%
Forum Activity 3%
FF Reputation: 1 johnhagen Good Standing Member
hi guys
i have 03 ford focus se
i searched here but i couldnt find related posting with this subject if its already posted sorry about that .but i want to add a/c gas in to my car and can not decide where is low pressure and high pressure arms?can you guys tell me where are they?and what kind a/c gas do you guys recommend?
another question is why we dont use high pressure port to add a/c gas?
thanks.
johnhagen is offline
Old 04-06-2011, 07:58 PM   #2
warneej
BodyKits=PantiesDrop
warneej's Avatar
Fan#: 20372
What I Drive: 04 ZX3 D23E-10SES Sedan-12 Ti Hatch
Points 32,482, Level 100
Points: 32,482, Level: 100 Points: 32,482, Level: 100 Points: 32,482, Level: 100
Level Up 0% Completed
FF Reputation: 201 warneej Excellent Standing Member warneej Excellent Standing Member warneej Excellent Standing Member
Buy-Sell-Trade Rating: (12)
Low pressure is the suction side, High pressure is the blow side. You want the car to suck it in, not blow it out.
All cars take R-134a. I like the Qwest SubZero which retails for about $19.99 at your local AutoZone.
The low pressure port on the Focus is below your passenger side headlamp. Easiest way to access it is to remove the lamp. The port is on the top of your accumulator/dryer which is in that space between your wheel and your bumper. There are 2 bolts on top and one bolt from underneath to remove the light.
Disciple of the "Push harder, suck less" school of autocross.
173.4whp
gump
crew #6
warneej is online now
Old 04-06-2011, 08:03 PM   #3
speedyg
Fan#: 49534
What I Drive: 2001 White SE 5-speed
FF Reputation: 3 speedyg Good Standing Member
Need to use R-134a for the AC system and is around $9 for a small can at Wal-Mart (if your state lets them sell it to the public)
High pressure port is under the hood right there on top of the grill by the passenger headlight.
Low pressure is on the drier which is under the car by the front right wheel. You will have to remove the fender liner and maybe the wheel to access it.
Turn your car on and the AC to Max. Then hook the can up and charge till the compressor stops cycling.
Chances are tho that if your having to add freon then you have a leak. Buy a can with dye and a UV light and look for it. Will be cheaper in the long run to find the leak and repair it than having to keep putting cans in. Cause if freon is leaking, then the oil in the system is leaking to. And if the compressor runs out of oil it can and will seize and it may break the belt (trust me on that). This is just my two cents tho but I hope it helps.
7/8/13 Final mileage 248,565-sold
speedyg is offline
Old 04-07-2011, 05:09 PM   #4
johnhagen
Fan#: 78457
Forum Activity 3%
thanks guys i added r134 but when i turn on a/c it doesnt really blow cold air.i checked gas pressure im sure its enough(between 30 and 45).it blows out air but its not enough cold.whats the problem?
Old 04-07-2011, 06:04 PM   #5
speedyg
Fan#: 49534
The more freon in the system the colder the the air coming out will be. Did you put in enough to make the compressor stop cycling tho?
speedyg is offline
Old 04-07-2011, 06:24 PM   #6
johnhagen
Fan#: 78457
Forum Activity 3%
well if you mean a/c comperessor (puller) stopped engaging i didnt pay attention but i checked the gas pressure with gauge it shows about 40.how i can check if its cycling or not?and what if does or not?
thanks.
Old 04-07-2011, 06:31 PM   #7
whynotthinkwhynot
Captain TMI
whynotthinkwhynot's Avatar
Fan#: 18416
Points 27,933, Level 98
Level Up 59% Completed
Forum Activity 10%
Not true. If you put too much refrigerant in the system, then it won't cool. Refrigerant pressure on the low side = evaporator temp in F (not exact but close). I think with 134 it's more like 25 psi = 32F. The pressure where the low switch cuts the power to the clutch is when the evaporator core temp is at freezing. To make it worse, higher ambient temps raise all system pressures, meaning your slightly cool charge now is going to be barely lukewarm in August. You're better off charging by pressure to just barely above the LP switch cut-off at idle this time of year. If it cycles while you're rolling around- that's ok for cooler temps- it won't do that as it gets hotter.
To the OP: We need more information. Can you see the face of your compressor as it cycles? Do you hear it click on and off? What is the pressure when it's running? Was the system fully discharged? Did you add any oil? Has the orifice tube ever been replaced? When you turn the AC on, do the engine cooling fans come on?
If your system is fully discharged or you have a leak, then you should read this thread before you start throwing refrigerant in your system.
Be eclectic.
You're special aren't you.
whynotthinkwhynot is offline
Old 04-08-2011, 01:03 PM   #8
johnhagen
Fan#: 78457
Forum Activity 3%
thanks guys and whynotthinkwhynot here is your answers.
Yes comp.cycles and i hear clicks on and off.
the pressure is between 20 and 42 while running but while not running its about 67.
i am not sure system was fully discharged i didnt pay attention but gauge was zero but the another thing gas can is 18 Oz.after i added gas into system half of the can is still full that may mean system maynot be fully discharged(i dont know how much freon can take A/C gas tank but it looks pretty big.i believe if it was fully discharged it could take more than 9 Oz(Half Of the 18 Oz can)).
i didnt add any oil or anything else.
about orifice tube i dont know previous owner replaced or not (i think they never did).
when i turn on a/c cooling fans come on.air blow is strong but the problem is no cool air.
and last summer i didnt have this problem.
thanks.
