02 Focus SPI no compression on cyl 2. Help!!! - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 04-04-2011, 02:28 PM   #1
TeamZetec
TeamZetec's Avatar
Fan#: 84603
What I Drive: 2000 Focus SE Zetec
FF Reputation: 1 TeamZetec Good Standing Member
I have a 2002 Ford Focus SE with the Split Port Induction 2000 engine that I bought for $1,200. It has 154k miles. It runs very rough the engine shakes, it has barely any power, and a valve started making a loud tapping noise yesterday when i revved it a bit. I took off the valve cover, cranked the engine with the plug wires off, and the valve rockers seem to be working good. It threw a code after i drove it around in my driveway a bit, i hooked my code scanner up and i got a P0302 code (cylinder 2 misfire). I pulled the plugs, they were all black and old, and cylinder number 2 had a different plug that was longer and the side electrode was smashed into the center electrode. It appears that since the plug was longer than the others, the piston hit the plug and smashed it. the whole plug is in one piece, there is nothing missing from it. I went to Advance Auto, got a set of NGK plugs, put them in, and it hasnt thrown another code yet but still runs very rough. Pulled the plugs again, they were black within a few mins, and the cylinder 2 plug had carbon flakes all over it. I then did a spark test, spark was strong on all cylinders except cylinder 2 where it had an intermittent spark...it would be strong spark a few times, then it would get really weak. Put the plugs back in, let it run for about 3 mins, and revved it a bit. A valve started tapping pretty loud. Pulled the plugs again, and did a compression test. Cylinder 1, 3, and 4 registered 150 on the compression tester. Cylinder 2 showed 0. I have now come back to my original thought that it has a dropped valve seat on cylinder 2.
What do you guys think? Since there is NO compression on cylinder 2, i would take a guess that it would almost have to be a bad valve seat. Any help is appreciated. Thanx!
TeamZetec is offline
Old 04-04-2011, 02:35 PM   #2
tonythetiger
tonythetiger's Avatar
Fan#: 82065
What I Drive: 2006 Silver MAZDASPEED 6
FF Reputation: 1 tonythetiger Good Standing Member
That definitely sounds like a possible issue. Did you check the condition of the cams? I worked on a car that had a rounded cam lobe on one lifter. (Just a suggestion.) Maybe a stuck lifter? It could even be bad piston rings? There's just so many possibilities...
Is it backfiring or sputtering at all?
It's hard not knowing without hearing it.
EDIT: It almost sounds like you might have a collapsed lifter.. One of your valves might be stuck open. I'm not too familiar with the SPI's, just helping with my knowledge of engines.
tonythetiger is offline
Old 04-04-2011, 02:42 PM   #3
drunkyoda
Hmmmmm
drunkyoda's Avatar
Fan#: 65151
What I Drive: 2003 Pitch Black LX
Points 13,451, Level 75
Points: 13,451, Level: 75 Points: 13,451, Level: 75 Points: 13,451, Level: 75
Level Up 51% Completed
Level up: 51% Level up: 51% Level up: 51%
FF Reputation: 9 drunkyoda Good Standing Member
well its usually the number 4 valve seat that drops.. but it could be your problem
2003 Focus Sedan - Sold but not forgotten
2014 Mustang V6 - Current
drunkyoda is offline
Old 04-04-2011, 05:50 PM   #4
TeamZetec
TeamZetec's Avatar
Fan#: 84603
No backfiring or sputtering. It shoots water out the exhaust like a river when you revv it. Im tearing the head off this weekend to check for a bad lobe. Hopefully its just a bad valve and not a bad camshaft lobe. I bought this car to fix and resell and its turning out to be a nightmare. The SPI 2000 is such a terrible motor, I cant wait to fix this POS, sell it, and get another Focus Zetec sedan.
Old 04-04-2011, 05:52 PM   #5
TeamZetec
TeamZetec's Avatar
Fan#: 84603
Have you ever heard of the SPI 2000 droppin a seat on cylinder 2? i know that usually when these motors drop seats, the valve slams the piston and shatters the piston.
Old 04-04-2011, 07:37 PM   #6
tonythetiger
Fan#: 82065
Glad I could be of some help.
Posted via FF Mobile
Old 04-05-2011, 12:08 PM   #7
drunkyoda
Hmmmmm
drunkyoda's Avatar
Fan#: 65151
never heard of it droppin on number two. but anything is possible. when mine dropped it didnt shatter my piston but it puts gouges in me head and scratched the cylinder wall to hell along with gouges in the piston
Old 04-10-2011, 08:25 PM   #8
TeamZetec
TeamZetec's Avatar
Fan#: 84603
Tore the head off, dropped valve seat on cylinder 2. Piston and cylinder head mashed all up. Attempted to find a junkyard motor or even a cylinder head at the tons of junkyards around here, no success. I hate these SPI junks, shows you how much they blow up when every junkyard car you find has the engine gone, but the Zetecs are always there (only Focuses with Zetecs i ever see in JYs is because they are wrecked)
Old 04-10-2011, 10:06 PM   #9
Focus7081
Fan#: 83591
What I Drive: 2003 Ford Focus
FF Reputation: 1 Focus7081 Good Standing Member
Mine was #2.
Join the club. BOTH!
-SOLD CAR-
-After zetec swap, car never ran right.
-Was a member of the "#2 dropped valve seat" club...Twice! Now a SPI->Zetec club member.
Focus7081 is offline
