#21 | ||||
If the Koni kit is cheaper, get it. Especially if you don't want to lower your car very much.
1992 Eagle Talon TSi - sold (POS) 2002 Mustang GT - sold 2002 SVTF - sold 2008.5 Mazdaspeed3 GT - cursed 2003 350Z Track - basically stock, and it runs |
| Sponsored Links | |||
Advertisement | |||
#22 | ||||
According to the description, they both lower the car roughly 1.5" but, as someone noted, apparently the Konis only really bring it down about 0.5"-1".
This hasn't really come up so I assume there aren't but are there any camber issues that need to be addressed mechanically or will an alignment do the trick after installing the springs and dampers? (Koni Sport Kit) UPDATE: Ordered the Koni Sport Kit (Dampers + Springs). $655 + free shipping from autopartsdealer.com |
#23 | ||||
( o Y o )
No it doesnt. For the assembled kit (new struts, springs, bearings, and mount front and spring and shock rear) its gonna be closer to $350 iirc. I didnt ever order one. This is through Steve at Toulsey ford. Mention ff/fj when you talk to him.
I think you'll be happy with this setup!
#24 | ||||
My trailing arm bushings have some play and I thought while I'm doing this... The Moog LCA's I bought from RockAuto and they were actually within a buck or two of buying the bushings and ball joints separately. They came assembled with the arm, two bushings, and the ball joints. One other thing you might need to know... The Koni's come with some pitiful pictures as the only instructions and you have to re-use the old shock bellows and mounts. Well mine were all rotted so I just today ordered the parts for this. So hopefully I'll be doing the install next week.
#783 of 4788 SVTOA Member MCA Member "Government is not the solution to our problem, government IS the problem." Ronald Reagan |
#25 | ||||
[QUOTE=BigRed03;3621363]No it doesnt. For the assembled kit (new struts, springs, bearings, and mount front and spring and shock rear) its gonna be closer to $350 iirc. I didnt ever order one. This is through Steve at Toulsey ford. Mention ff/fj when you talk to him.
I just installed the assembled refresh kit from Steve @ Tousley. It's $286+shipping. It is also available unassembled, but you have to buy the strut bearings separately and it comes with a new rear sway bar the assembled kit does not come with.
CD Silver 02 SVTF, #1336, Tom's Tune, K&N Panel, Steeda 8mm, Powerslot w/Hawk HPS & Steeda STS "Brace for the G's, and fast heel-toe work!"- Hunter S. Thompson |
#26 | ||||
I got the part numbers from Toulsey and was going to call and order them tomorrow. I was wondering one general thing - the boots or baffles that go on the dampers are going to need to be reused. They aren't super expensive if memory serves but if it ain't broke... I can't quite see them very well without getting the car on a lift. At 90k are they generally falling apart or still intact? Also, anyone have a recommendation on where can I get little clamping collars for the sway bar? And do I need four of them or just two? Their necessity is a recurring topic on this and various other posts about upgrading the suspension... |
#27 | ||||
did u get polyurethane bushings and endlinks is so where from
HATCH NATION #56 2004 Sonic Blue SVT!!! 2.5" orp and flex and trubendz catback, toms tune, steeda sts, custom intake, good ol motocraft copper plugs! |
#28 | ||||
I just got done putting on the front sway bar bushings, it appeared that my front sway bar walked off of the stock bushings a little, which isn't unheard of. So I'm glad that I have to clamp the bar now.
I got the clamps from mcmaster.com, you need two per bar. I kinda wish I did the hose clamp method in the front because of the tight space.
EAP with 1/3 of the cold weather package. No block heater or TCS. |
#29 | ||||
#30 | ||||
how do u do the front bushings do u pretty much have to remove the sway bar?
| Thread Tools | |
| Display Modes | |
