speedo sensor? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 09-20-2004, 03:16 PM   #1
cope1027
cope1027's Avatar
Fan#: 11265
What I Drive: Black 2000 ZX3
FF Reputation: 1 cope1027 Good Standing Member
Angry speedo sensor?
I was coming home the a few nights ago, and it was raining very hard. My speedometer started freaking out as I was coming on to base. It kept bouncing up and down, and as it would hit zero, it felt as though the brakes were being hit. The speedometer finally died the next day. I found out that there is five speed sensors on the foci. I figured that the one that went out was the one on the transmission near the diff. BUT, Today as I was heading home for lunch, it was pooring rain again, I decided to abuse my car and drive it through a puddle that came up to the middle of my passenger door. When I came out of the puddle, my speedo began working, bouncing a little, but it was working. I drove around for a few min. and it stopped working again.
Has anyone had or seen or heard of the speedo freaking out. Do you think that it is the sesnor in the transmission.
It is almost 200 dollars to fix this problem, so I want to make sure it isn't anything any worse.
cope1027 is offline
Old 09-20-2004, 03:26 PM   #2
jpickles
jpickles's Avatar
Fan#: 415
What I Drive: 2002 Pitch Black ZX5
FF Reputation: 1 jpickles Good Standing Member
Almost sounds like a short somewhere.
Jason
There is nothing we can do, the hippies have us surrounded, and they look like they have the munchies!
jpickles is offline
Old 09-20-2004, 03:29 PM   #3
cope1027
cope1027's Avatar
Fan#: 11265
that is what I was thinking. If the water was getting into the sensor, it could be allowing the current to go through causing the sensor to work. The bad thing is,I don't really know where the sensor is. I have a chilton's manual, it shows it, but my sensor doesn't look the same.
Volant intake, 65mm TB, 2000 ported intake, Port&Polished 10:9:1 FocalTech head, FR Stg 2 cams, FS cam gears, UDP, FC 4-2-1 header, flex pipe, o2 cheater. NO CAT. MBRP catback, 9mm wires, 19lb FR injectors,
heat index 3 Iridium plugs, DS chip.
cope1027 is offline
Old 09-20-2004, 11:11 PM   #4
sitlet
Fan#: 970
What I Drive: 2001 Focus ZX3
FF Reputation: 1 sitlet Good Standing Member
as a last resort if you cannot get to the sensor, you could try to cut the wire and bypass that sensor. if there is 5 sensors, the other 4 should work fine without one. im not sure if it would screw anything up more though
sitlet is offline
Similar Threads
Help - ECU PINOUT Diagram Ricci_BR General Forced Induction 8 01-19-2015 06:18 AM
Every trouble code defined 03OrangeSVT General Forced Induction 9 05-25-2011 01:53 PM
Focus Zetec/SVT Pinout Chart 03OrangeSVT General Technical Chat 1 05-27-2008 12:31 AM
A/F gauge hook up KRYPTO General Technical Chat 5 04-28-2008 04:44 PM
pin lay out for pcm kylebal SVT Performance (2002-2004) 7 12-27-2007 12:59 PM
