Tranny fluid - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 09-20-2004, 12:40 PM   #1
wadem
Fan#: 1204
What I Drive: 2001 ZX3 s2
FF Reputation: 1 wadem Good Standing Member
Tranny fluid
Every year when it starts to get cold out my 2001 ZX3 S2 becomes very hard to shift. Sense this is my first manual transmission car I thought this was normal until I drove my friends 2002 ZX3 same engine and tranny as mine. His car shift’s much better than mine when it got cold out. I began to do a little research and the only difference I could find between the 2 cars (other than mileage 29000km on mine and 24000km on his) was that Ford started to use a different tranny fluid in 2002. Ford wants $35 per liter for this stuff, has anyone tried anything cheaper that works well in the cold. Thanks
wadem is offline
Old 09-20-2004, 01:12 PM   #2
DidHeFocus?
Fan#: 1704
What I Drive: 2003.5 ZTW PZEV
Points 26,532, Level 97
Points: 26,532, Level: 97 Points: 26,532, Level: 97 Points: 26,532, Level: 97
Level Up 19% Completed
FF Reputation: 1 DidHeFocus? Good Standing Member
It could also be the linkage/cable lubrication is getting stiffer in the cold.
I'm a middle aged guy, with a middle school mind.
DidHeFocus? is offline
Old 09-20-2004, 01:19 PM   #3
wadem
Fan#: 1204
I was thinking that too but his doesn't do that. I have also test driven some of the newer focus 03 and 04 last winter and they shifted pretty good as well. You could tell they were a little stiff (-25c) but not nearly as bad as mine.
wadem is offline
Old 09-20-2004, 06:54 PM   #4
slammedfoci
slammedfoci's Avatar
Fan#: 2137
What I Drive: 2000 Bright Amber Metallic ZX3
FF Reputation: 1 slammedfoci Good Standing Member
Try putting some of that Red line raceing oil tranny fluid in it. I am going to get some soon and herd that it smoothes out the shifting. I can not rembber the number of it. I think D4 or DH4 or somthing like that.
PERFORMANCE:Aem cai, Aem air bypass valve, Autolite double platinum plugs,Ford Racing 9mm plug wires, Full magnaflow cat back exhaust, Fc race header, Focus Central Flex Pipe, Fc 65mm throttel body ,Fc strut brace, Prothane lower mount inserts, Prothane front and rear swaybar bushings and rear endlink kit, Fc spark plug cover
EXTERIOR: Aerospeed lowering springs, Sidemarkers, Svt upper grill, 03 Grey Headlights, Flat Black Stock 15s, APC Gen. 2 Mirrors, Euroglow Xenon Headlights
INTERIOR: Fc short shifter, Auto meter duel a-piller guage pod, Auto meter phantom oil pressure and Volt gauges, Ford racing tach w/shift light, SVT alum. pedals, Rear seat removed
slammedfoci is offline
Old 09-20-2004, 07:01 PM   #5
ModemJunki
ModemJunki's Avatar
Fan#: 10639
What I Drive: '02 Red on Black SVTF - tuned by Hypnotic
FF Reputation: 3 ModemJunki Good Standing Member
$35 per liter? What's it got, gold in it?
I take it you've tried some of the online discount parts warehouses...
I personally would look at all of the possible variables, starting with the shift turret, cables and associated links, as well as the fluid change.
Keep the revs up!
ModemJunki is offline
Old 09-20-2004, 07:04 PM   #6
tension001
tension001's Avatar
Fan#: 2278
What I Drive: 2001 Infra-Red 5sp ZX3
FF Reputation: 1 tension001 Good Standing Member
guys, adding on to what hes asking. can you lubricate the cables or something to make the car shift easier. i want mine to glide into gears...
2001 Red ZX3 5spd
OBX 4-2-1 Race Header; Borla 2.5" SVT Catback; MAC Short Ram; FC 65mm TB; FC Race Shifter; Gear Concepts Aluminum Pedals; Painted Interior; SVT Front Bumper and grille
tension001 is offline
Old 09-20-2004, 07:44 PM   #7
slammedfoci
Fan#: 2137
I do not think you can glide into gears with a cable shift. I always herd that the shifts will be some what harsh becuse of the cables. I have felt a noticible diffrence between the two(Cable shift and rod shift like on some hondas). I think that the Redline stuff is really worth it. Besides you get what you pay for when it comes to car stuff.
Similar Threads
"How To" - Clutch Master Cylinder Replacement pokeySVT General Technical Chat 98 12-14-2010 02:51 PM
Tranny fluid amount??? darkstarmotorsports General Technical Chat 14 07-08-2009 08:59 PM
Tranny Fluid 04 SVT weaponzero SVT Performance (2002-2004) 13 01-03-2009 08:37 PM
a/t fluid & filter r&r, brake & p/s fluid r&r. belt r&r boostedztec General Technical Chat 11 10-19-2008 02:55 PM
Tranny Fluid themangina69 General Technical Chat 7 09-28-2006 11:26 PM
