How many People with the SPI had a Valve Seat Failure? - Page 13 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 03-20-2013, 10:42 PM   #121
BluBlue
Fan#: 111658
What I Drive: 2001, Blue, LX
FF Reputation: 1 BluBlue Good Standing Member
Originally Posted by Donnyd21 View Post
$2600!!!! I am in the wrong business, wish you were close I would have done EVERYTHING for $1100
And I would have paid you gladly. Unfortunately I needed the thing for work and I could only be without it (and work) for a little while (8 days).
I was the meat in a rock & Hard place sandwich.
BluBlue is offline
Old 03-21-2013, 12:32 AM   #122
Dark 007
Dark 007's Avatar
Fan#: 80502
What I Drive: 2001 marshall red LX
FF Reputation: 1 Dark 007 Good Standing Member
Originally Posted by TheGlassMaker View Post
$2600 for a refurbished spi. I did a $800 zetec swap.
Sent from 34.0764 N, 118.4296 W
Really?!? Did that included all parts & labor
I've talk to a few mechanics from my home town (South Chicago) and they claim that, that type of swap is impossible!!
Posted via iPhone using FF Mobile
Dark 007 is offline
Old 03-21-2013, 01:15 AM   #123
TheGlassMaker
REVOLT.BUILD.RISE
TheGlassMaker's Avatar
Fan#: 69510
Points 35,496, Level 100
Points: 35,496, Level: 100 Points: 35,496, Level: 100 Points: 35,496, Level: 100
Level Up 0% Completed
Forum Activity 6%
Yes.
engine, harness, ecu, alternator, intake tube, and passengerside motor mount was 500.
I Spent 300 on water lines, vacuum lines, powersteering line, timing belt, throttlebody, thottle cable and a few other odds and ends. The down pipe for the converter and the flex pipe was a mixture of cut up spi and zetec pipes. With a new universal flex.
I did it myself with the help of a co-worker.
Here's a write up I did.
http://www.focusfanatics.com/forum/showthread.php?t=296946
TheGlassMaker is online now
Old 03-21-2013, 05:38 PM   #124
Dark 007
Dark 007's Avatar
Fan#: 80502
Yes.
This is extremely useful. I shall bookmark your write up for probable future reference, thanks.
Dark 007 is offline
Old 03-23-2013, 11:50 AM   #125
digger658
Fan#: 92110
What I Drive: 2000 Focus 2.0
FF Reputation: 1 digger658 Good Standing Member
I think my daughter's Focus SPI dropped a valve on no. 4. It will start and run but rough. When I rev it up there is a loud popping sound at the higher rpm during the rev. Drove it down the road and could hear the popping sound continuously.
When I pull the no.4 plug wire it makes no difference in how the motor runs. I pull any of the others the motor dies. Exhaust or intake valve maybe?
What are my options?
digger658 is offline
Old 03-24-2013, 03:06 AM   #126
TheGlassMaker
REVOLT.BUILD.RISE
Fan#: 69510
Forum Activity 6%
If its still running your in a good spot. Stop starting it, revving it and driving it. Because it sounds like you have lost all compression in that cylinder. The seat has probably came loose and hasn't dropped off the head yet. If you keep messing with it, it fall and it can and most likly will destroy the head cylinder wall(s) piston and/or rod.
Pull the head a get that rebuilt before its too late. You got lucky, fix it while you can.
Old 04-23-2013, 01:08 PM   #127
Ispi
Fan#: 44846
What I Drive: 2003 Silver Focus SE (SPI-SOHC)
FF Reputation: 1 Ispi Good Standing Member
2003 SPI with 158,000miles bit the dust. New member of the dropped valve seat club. Happened 2 blocks away from home so I got it to my garage. I consider myself lucky. Tires and battery are like new (what a shame). Deciding what to do with it. Would need piston kit, rebuilt head, etc. I am now driving my backup car so I have time.
Ispi is offline
Old 04-23-2013, 03:41 PM   #128
Donnyd21
Fan#: 109211
What I Drive: 2002
FF Reputation: 1 Donnyd21 Good Standing Member
You can fix it yourself for about $500 in parts.
I HAVE GOOD USED OEM PISTON AND ROD ASSEMBLIES FOR ALL 2.0L SPI ENGINES (FOCUS, ESCORT AND TRACERS)!! PM ME.
Donnyd21 is offline
Old 06-04-2013, 01:44 PM   #129
whitcwa
Fan#: 115408
What I Drive: 2002 green Focus
FF Reputation: 1 whitcwa Good Standing Member
Just replaced my head in 2002 Focus w 90K mi. It hadn't dropped a seat, but I figured I shouldn't wait for it to happen. Cost $275 for rebuilt head and $200 for gaskets, belts, head bolts, fluids, filters, and water pump. Amazon sent the wrong bolts. Their statement that "This fits your vehicle" was wrong.
Problems I encountered:
Thought indent in the rim of the serpentine pulley was the timing mark. The real timing mark can't be seen until the serpentine pulley is removed. No harm done.
One exhaust stud in cat conv flange snapped. I could wiggle it in/out a little, but it would not loosen more. Cut it flush and drilled it out. Used a good HSS bit with lots of oil. It took a while, but it stayed centered. Reattached with bolt/nut instead.
Forgot to put cam pos sensor back in before tightening intake manifold. Removing fuel rail from injectors gave enough clearance.
Neglected to torque rocker arm nuts, so there was some lifter noise. I didn't drive it or rev it. I am confident I can fix that tonight. The nice man at Cylinder Heads Intl explained that I should torque them and let them sit overnight because the lifters are pumped up too high now. Then run it for a few minutes, shut off, and retorque them.
whitcwa is offline
Old 07-21-2013, 11:58 PM   #130
jd8450
Fan#: 117001
What I Drive: blue
FF Reputation: 1 jd8450 Good Standing Member
Best Place To Buy Conecting Rod
My 2002 just droped a valve an it mangled at least two pistons and rods. I see all the information about where to get the heads, etc but where have you guys gotten the used/rebuilt rods from? I see some guys selling them for 50 bucks on eBay but that does not make sense when I can get brand new from the dealer for 30 more dollars.
The car has 150 k but was extremely well maintained and amazingly I think the block and lower end are in perfect shape. I can even still see the cross hatches on the cylinder walls.
I appreciate any information?
jd8450 is offline
