Rear-most Exhaust Heat Shield - How to Fix? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 03-27-2011, 05:08 PM   #1
Video Vertigo
Fan#: 84373
What I Drive: 2003 Black ZTW
FF Reputation: 1 Video Vertigo Good Standing Member
Hi Everyone! Vehicle is a 2003 Focus ZTW Wagon, 2.0 Zetec.
My exhaust heat shield is loose and rattling. I've searched the forums and I have decided it would be best to fix it instead of remove it, and I'd like to use the "stainless fender washers" fix. You can see from these pictures that the clips have all but disappeared from rust (Michigan car), and I'd like to know where to get new clips, fender washers, etc to get the job done. If the clips aren't easy to come by, does anyone know the thread of the attachment posts to the underbody? If I can just get regular stainless nuts for these that would be fine too . . . I just want it fixed right. Pics:
You can see in these pictures that the heat shield just broke around the fastener holes. This last picture shows the thread of the attachment post (what's left of it) that I was asking about:
Thanks in advance for your help!
Video Vertigo is offline
Old 03-27-2011, 05:10 PM   #2
deadend9009
Fan#: 69681
What I Drive: 2003 Grey Focus ZX5
FF Reputation: 3 deadend9009 Good Standing Member
Use big washers under the factory hardware. OEM clips are basically stamped washers which have the shape of a nut. A dealership would have those.
deadend9009 is offline
Old 03-27-2011, 05:38 PM   #3
Video Vertigo
Fan#: 84373
I'm going to need big washers with a pretty small hole, right? Would a dealer have these as well, or do I try a place like Autozone?
Old 03-27-2011, 06:12 PM   #4
Indy'sexclusiveZx3
Fan#: 65419
What I Drive: 2013 tuxedo black st
FF Reputation: 7 Indy'sexclusiveZx3 Good Standing Member
Try lowes they sale stuff like that in the hardware section
Parts for sale check out my thread, got a new st need to sale old parts
Indy'sexclusiveZx3 is offline
Old 03-28-2011, 07:46 AM   #5
nov173
nov173's Avatar
Fan#: 29840
What I Drive: 2014 Focus ST
FF Reputation: 79 nov173 Excellent Standing Member
Buy-Sell-Trade Rating: (4)
i had that problem too... i just took the shield off...honestly never had a problem. I had it off for a good 3yrs too.
SVT header kit, 2.25 MBRP cat-back & flex, r/t high flow cat. aem cai, frpp kit
For Sale: Rear bumper(stock). SVT side skirts FS as well. Buy em!!!!
nov173 is offline
Old 03-28-2011, 09:49 AM   #6
whynotthinkwhynot
Captain TMI
whynotthinkwhynot's Avatar
Fan#: 18416
Points 27,736, Level 98
Level Up 39% Completed
Forum Activity 5%
Yep. I doubt you'll find metric sizes, but it won't matter. That looks like a 1/4" hole would work. What you want is called a Fender washer. Since you'll have difficulty finding them in aluminum, I'd look for them in stainless. Otherwise you're going to have rust with galvanized steel. You can find fender washers in all sorts of diameters, and the listing will be like so: 1/4 x 1", 1/4 x 1 1/2" and so forth. Hole sizes go up 1/4, 3/8, 1/2, 3/4 and on up. Some places will even sell nylon fender washers that would do the trick as well.
Be eclectic.
You're special aren't you.
whynotthinkwhynot is offline
Old 03-28-2011, 10:32 AM   #7
sailor
Elder
sailor's Avatar
Fan#: 57268
Points 12,743, Level 73
Points: 12,743, Level: 73 Points: 12,743, Level: 73 Points: 12,743, Level: 73
Level Up 74% Completed
Forum Activity 99%
When I did my center shield with the same problem (needed fender washer for worn/corroded hole in shield), the local hardware store had stainless fender washers but I had to use plain steel for the stamped steel top-hat style screw on nuts.
Dealer could have special ordered them, but once I saw it was std. hdwe. I took the parts guy's advice and went to my usual hardware store source.
These are "special" nuts, but it's a common item.
"Top-Hat" is the basic shape of the stamped nut, with a keyhole shaped center hole. The hole is a single shaped "ramp", that grabs one slot of the screw with the slot being the corner that grabs first. You can use a socket or nut driver for installation, and it cuts through the rust on the old screw stud that extends from the body.
The trick is to pick a size that fits the rusted stud tightly, and not worry about the "official" size...
Luck!
sailor is offline
Old 04-12-2011, 03:46 PM   #8
earl2011
Fan#: 84849
What I Drive: 2005 Silver Wagon
FF Reputation: 1 earl2011 Good Standing Member
Had the same issue, except it happened after driving it 60 miles from the dealer I got it from the day I bought it. They had used some metal tape ask a temp fix and refused to repair it. Needless to say I'm done with that dealership (and it was in Holland, MI).
I went to Autozone and got washers that worked perfectly and some self tapping bolts that I just slammed in next to the old rusted ones.
earl2011 is offline
Old 04-21-2014, 07:53 PM   #9
2003 Ford Focus
2003 Ford Focus's Avatar
Fan#: 91951
What I Drive: '03 Focus SE and '03 ZTW
Points 1,312, Level 20
Points: 1,312, Level: 20 Points: 1,312, Level: 20 Points: 1,312, Level: 20
Level Up 12% Completed
FF Reputation: 4 2003 Ford Focus Good Standing Member
Question
Sailor,
Old thread I know, but just discovered this same problem today on my daughter's '03.
The studs are pretty much rusted off too. Thinking of using large SS washers, but also grinding the studs off and drilling a hole for a SS machine screw. Ya, I know the fuel tank is under there somewhere too!
Gee, I just found the fuel filter as well. Doesn't look like the filter has ever been off in 187,000 Kms.
May take the shield off completely when I replace the intermediate pipe and resonator this summer.
Any thoughts or hints would be appreciated.
First Ford: '62 Falcon Futura 2-door / Modified Production 302 / 270 HP / Close Ratio 4-speed / 3.50 ratio 8" Fairlane Differential (289-271 HP cam / heads / exhaust / medium high rise / 600 CFM Holley / dual-point) Low 15's at 90+ MPH
2003 Ford Focus is offline
Old 04-21-2014, 08:55 PM   #10
sailor
Elder
sailor's Avatar
Fan#: 57268
Forum Activity 99%
I've done that before as needed, fuel tank hanging underneath is pretty obvious - you won't be screwing with that (grin).
Other places you just do your best NOT to put a screw through were it'll cause a problem (don't want to step on one for example).
At least a couple here have ripped it off & used stick-on shielding for the tank, more work & expense than saving the stock shield so try that first IMHO.
If you've got a pop rivet tool, might try large head rivets plus washers. they aren't sharp on the business end at least (chuckle). Tryin' to think of alternatives, often based on what you can find or have handy.
Luck
"Rubber Side Down"
S.R. #275 Focus Takeover #003
sailor is offline
