2011 Focus ... Where is the Oil Filter? What Oil Filter? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 03-22-2011, 06:09 PM   #1
Miller88
Fan#: 73790
What I Drive: 2011 Focus SE 5 Speed
Points 1,769, Level 24
Points: 1,769, Level: 24 Points: 1,769, Level: 24 Points: 1,769, Level: 24
Level Up 69% Completed
Forum Activity 4%
FF Reputation: 5 Miller88 Good Standing Member
Either this weekend or next weekend I'm going to change the oil for the first time on my 2011. I'll be at 1300 or so miles so it's time for the first one.
The problem is ...
I can't find the oil filter. Maybe I'm missing something but I can't find it from the top or the bottom.
What model does it use?
Miller88 is offline
Old 03-22-2011, 09:40 PM   #2
fordtech
fordtech's Avatar
Fan#: 68998
What I Drive: 04 Turbo SVTF, 88 GMC V2500
FF Reputation: 2 fordtech Good Standing Member
Buy-Sell-Trade Rating: (6)
2011 uses a motorcraft FL910. look directly in the center of the front of the engine, Its mounted there vertically, you can't miss it. Plus if your only at 1300 miles, you don't need to change the oil yet. unless you let it idle a lot.
fordtech is offline
Old 03-22-2011, 09:41 PM   #3
Chris951
Chris951's Avatar
Fan#: 78320
What I Drive: 1991 mustang 5.0, 1992 Talon Tsi
FF Reputation: 1 Chris951 Good Standing Member
its under the engine at the front of the engine directly behind the front bumper
Chris951 is offline
Old 03-23-2011, 09:37 AM   #4
Miller88
Fan#: 73790
Forum Activity 4%
It is used like a taxi
Is it viewable from the top or bottom only?
Miller88 is offline
Old 03-23-2011, 09:53 AM   #5
Darthenstein
Darthenstein's Avatar
Fan#: 63587
What I Drive: 2009 Ford Focus SES
Points 1,534, Level 22
Points: 1,534, Level: 22 Points: 1,534, Level: 22 Points: 1,534, Level: 22
Level Up 34% Completed
FF Reputation: 4 Darthenstein Good Standing Member
From the bottom...right behind the radiator
"It isn't what you drive that matters, it's how you drive it" - Jeremy Clarkson, Top Gear
Ford: Taurus ('91, 01) Focus ('09); Mercury: Sable ('95); Dodge: Neon ('95); Trek: 1000SL ('07) Yamaha: VStar 650 ('03)
Darthenstein is offline
Old 03-23-2011, 10:52 AM   #6
FordService
Official Ford Rep
FordService's Avatar
Fan#: 79824
What I Drive: Ford Focus
Points 3,489, Level 36
Points: 3,489, Level: 36 Points: 3,489, Level: 36 Points: 3,489, Level: 36
Level Up 93% Completed
Level up: 93% Level up: 93% Level up: 93%
Forum Activity 26%
Activity: 26% Activity: 26% Activity: 26%
Hi Miller88,
My name is Deysha with Ford Customer Service. The info provided by the other members is correct. You can also find your filter info in your owner guide, under the maintenance and specifications section.
Deysha
FORD SERVICE
p: 800.392.FORD
FordService is offline
Old 03-24-2011, 07:27 AM   #7
Miller88
Fan#: 73790
Forum Activity 4%
Originally Posted by FordCustomerService View Post
Hi Miller88,
Deysha
Thanks! I read that thing 5 times but haven't found it yet :/
Miller88 is offline
Old 03-24-2011, 10:32 AM   #8
sailor
Elder
sailor's Avatar
Fan#: 57268
Points 13,422, Level 75
Points: 13,422, Level: 75 Points: 13,422, Level: 75 Points: 13,422, Level: 75
Level Up 44% Completed
Forum Activity 99%
Maintenance & spec. info, at least in my manual, is limited to how to check oil level - what oil to use - and what oil filter number is specified for the car.
It's NOT like a BMW motorcycle manual that gives full instruction on ALL owner serviceable items in detail...
sailor is offline
Old 03-24-2011, 10:42 AM   #9
whynotthinkwhynot
Captain TMI
whynotthinkwhynot's Avatar
Fan#: 18416
Points 27,933, Level 98
Level Up 59% Completed
Forum Activity 10%
Go stand directly in front of your car- right in front of the Ford blue oval. Now crouch down and scoot your head as far under the bumper as you can. Look directly up, and try not to hit your head on the filter.
As far as engine orientation of where it is: stand on the passenger side of the vehicle so you are standing at the front of the engine. On the right hand side of the engine which is the front of the vehicle, in the center of the engine at the bottom beside the oil pan is the oil filter.
This is one of the easiest cars on the planet to change oil. The only easier one I know of is the 12A and 13B rotaries from Mazda where the filter is on top of the engine- you don't even have to drain it.
Be eclectic.
You're special aren't you.
whynotthinkwhynot is offline
Old 03-24-2011, 11:12 AM   #10
sailor
Elder
sailor's Avatar
Fan#: 57268
Forum Activity 99%
Yup - if your arm is long enough to reach the drain plug when you stretch underneath you don't even need to jack it (try from the side) - the filter is an easy reach from the front...
sailor is offline
