If i pull the fuse will the engine light go out? - Focus Fanatics
Go Back   Focus Fanatics > Ford Focus Tech Discussions > Focus Tuning Chat
Old 03-19-2011, 08:34 PM   #1
BowerR64
BowerR64's Avatar
Fan#: 78699
What I Drive: 2007 ZX3 SE
FF Reputation: 12 BowerR64 Great Standing Member
Today i put in my wideband sensor to the bottom bung (the third one)
I wired the module (innovate LC-1) into the fuse box under the hood for power but when i drove it i notice its not reading quite right. I may need to replace the sensor or rewire it to a different power source.
When i look in the manual i see a fuse for "HEGO sensors" it says (Heated exhaust gas oxygen) what if i pull that fuse? is that for all the sensors maybe?
Im sure its not that easy but it never hurts to ask.
It's not important to win, it's important to make the other guy lose.
BowerR64 is offline
Old 03-19-2011, 08:46 PM   #2
mikebontoft
Toxx
mikebontoft's Avatar
Fan#: 58647
nope that just gives it more of a chance to stay ON. can you read the codes?
SR #127 | '02 Focus SE "Foci" (5.0 RWD - parting) | '90 Mazda 626 GT "Greenie" (2.2L turbo T3/T4 rebuild-sold) | '75 BMW 2002 "Carby" (resto-mod racecar) | '75 BMW 2002 (donor -sold) | '98 Jeep Grand Cherokee 5.9L (lifted and fast) | '99 BMW 328is (alt. daily).
Moderating General Chat Lounge, General Technical Chat, Ford Focus & General Car Chat, and Rocky Mountain Fanatics
mikebontoft is online now
Old 03-19-2011, 08:52 PM   #3
BowerR64
BowerR64's Avatar
Fan#: 78699
The engine codes? I just put it on today and it came on instantly after i unhooked the stock one and started it up. Im sure thats what the CEL is from.
BowerR64 is offline
Old 03-19-2011, 09:00 PM   #4
mikebontoft
Toxx
Fan#: 58647
yeah I thought of that after I posted and left the thread. well.... hook up a cheater to it or something just so it's hooked up. may not even need to do that. I (sadly) had an 02 sensor wrapped around a harness for a few days so I could still drive the car and didn't get a light
Old 03-19-2011, 11:02 PM   #5
FocusedSlayer
has a screw loose
FocusedSlayer's Avatar
Fan#: 59042
What I Drive: 2007 CD Silver Sedan SE w/Sap
FF Reputation: 34 FocusedSlayer Great Standing Member
Buy-Sell-Trade Rating: (4)
This should stop the CEL until you get a tune . I did it after I installed my header and not once did I get the CEL until I put my Wideband in and then I got a tune update and now no more CEL .
But this should do the trick for you , I know you don't have a header but it would be worth a try .
http://www.focusfanatics.com/forum/showthread.php?t=161467
Team Duratec #01,Sedan Revolution#4, Elder FocusedSlayer, Gump Crew 21
February 2012 Sedan of The Month
FocusedSlayer is online now
Old 03-20-2011, 12:16 AM   #6
BowerR64
BowerR64's Avatar
Fan#: 78699
I dont understand.
The wideband comes with its own 02 sensor, i used the #3 bung and took out the stock 02 in the #3 location and just unplugged it. Thats why its throwing the CEL because its reading nothing at that location.
I need to try and trick it with the LC-1 it has an analog out with a selectable voltage output to trick the ECU into thinking its there but i wanted to ask about that fuse first. I knew it wasnt that easy but thought ide ask.
I need to find out what lead the stock 02 uses and tap into it. I believe its +12, -12 (for the heater) and signal + and signal ground to the ECU
BowerR64 is offline
