Yet another high idle problem - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 07-30-2012, 06:50 AM   #11
whynotthinkwhynot
Captain TMI
whynotthinkwhynot's Avatar
Fan#: 18416
Points 27,933, Level 98
Level Up 59% Completed
Forum Activity 10%
PCV valve should be checked every 20k miles or every 3-4 oil changes. You test it by removing it's hose from the port and blowing into it. You should feel a lot of resistance, and ideally not be able to blow into the engine. Then suck lightly and you should be able to draw in some oily smelling air from the engine. That is a proper working PCV.
We've noticed lots of problems with the PCV vacuum line on older Zetecs. The line will crack and leak vacuum, and sometimes the line will collapse under idle. Be sure to double check this line or replace it, or at least replace the rubber elbows. Ford makes an insulated replacement part that is better than the factory part for $20.
Be eclectic.
You're special aren't you.
whynotthinkwhynot is offline
Old 10-01-2012, 10:00 PM   #12
focusnoworko
Fan#: 104428
What I Drive: 2000 Blue Ford Focus SE
FF Reputation: 1 focusnoworko Good Standing Member
Did you figure out what the problem was? We have a 2000 Ford Focus SE doing the same thing.
focusnoworko is offline
Old 10-01-2012, 11:58 PM   #13
amc49
Fan#: 96610
Points 3,360, Level 36
Points: 3,360, Level: 36 Points: 3,360, Level: 36 Points: 3,360, Level: 36
Level Up 7% Completed
Forum Activity 40%
Activity: 40% Activity: 40% Activity: 40%
The statement made that vacuum leaks were constant and do not come and go is absolutely and totally incorrect. On these cars they commonly come and go when the PCV line at the intake attachment point bubblegums up to suck a slight hole in it. That hole can leak and then reseal to not leak as the little flap of torn loose material flaps around in the hole. I've seen problems then suddenly it straightens up and runs fine for several months only to do it again.
amc49 is offline
Old 06-19-2013, 02:27 PM   #14
Busted2000SE
Fan#: 84153
What I Drive: 2000 red SE
FF Reputation: 1 Busted2000SE Good Standing Member
Just wanted to give everyone a update. The problem still was very inconsistent and would seem to happen on hotter days even though that ended up never having anything to do with it. I checked all the vac lines and the pcv was in working order. I ended up just dealing with it and would slow the engine down with the clutch if it decided to do it while I was at a stop light. I drove it this way for 6 mo since I was unemployed at the time and didn't have the money to blow at a mechanic or dealer.
Finally about 2 weeks ago the engine light came on. I plugged my scanner in and it said that the TPS sensor was showing low voltage. Got a new one from the local Napa and replaced it. Upon inspection and comparison of old to new, it was clear that the old one was very worn out. So far this seems to have fixed the random high rpm problem. I quick trip to the parts store and $45 later seems to of fixed my 2 year old problem. I just wish the code would of flashed sooner.
Busted2000SE is offline
