Power steering noise? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 03-17-2011, 05:36 PM   #1
uRabbit
Fan#: 82829
What I Drive: 2007 Ford Focus SE
Points 1,845, Level 25
Points: 1,845, Level: 25 Points: 1,845, Level: 25 Points: 1,845, Level: 25
Level Up 45% Completed
Level up: 45% Level up: 45% Level up: 45%
FF Reputation: 1 uRabbit Good Standing Member
Never had issues with power steering on my other vehicles, so this is new to me.
So I know the manual says occasional power steering noise is normal. However, this is pretty regular. Happens once, sometimes twice a day. The noise occurs usually after hard acceleration. We're getting 33mpg in mainly city driving, so we don't gun it often. Today, after a hard acceleration, I was idling at a light and the noise was happening at idle. Usually it only makes noise when accelerating normally or when turning; again, after hard acceleration.
Fluid is topped off.
Any ideas?
My Mileage: 36.218 mpg/127.08% EPA est. MPG lifetime avg // 85% city, 15% hwy
2007 SE M/T Cloud 9 White [purchased January 27th, 2011 w/ 30k mi]
uRabbit is offline
Old 03-17-2011, 05:49 PM   #2
drunkyoda
Hmmmmm
drunkyoda's Avatar
Fan#: 65151
What I Drive: 2003 Pitch Black LX
Points 13,451, Level 75
Points: 13,451, Level: 75 Points: 13,451, Level: 75 Points: 13,451, Level: 75
Level Up 51% Completed
Level up: 51% Level up: 51% Level up: 51%
FF Reputation: 9 drunkyoda Good Standing Member
what does it sound like? a whine?
2003 Focus Sedan - Sold but not forgotten
2014 Mustang V6 - Current
drunkyoda is offline
Old 03-17-2011, 06:03 PM   #3
uRabbit
Fan#: 82829
A whine, yes. I'll try to record the noise on my iPhone today on my drive home from work here in an hour. I'll upload it to YouTube if I can get it.
Also, I've parked in the driveway when it was happening once and turned the wheels with the hood up.
uRabbit is offline
Old 03-17-2011, 06:07 PM   #4
drunkyoda
Hmmmmm
drunkyoda's Avatar
Fan#: 65151
idk thats wierd. i have never had that problem. have you checked make sure your not leaking a little bit? maybe your pump is bad? when you turn on your car does the ps fluid lvl go down at all? we dont need a vid save your time we all know what a ps whine sounds like. haha
Old 03-17-2011, 06:22 PM   #5
russmistro
russmistro's Avatar
Fan#: 76170
What I Drive: 2007 focus st w/SAP
FF Reputation: 1 russmistro Good Standing Member
i know exactly what he's talking about. happens to me too, or rather, it did, when my car was running. its like a low ghastly moan.
Team duratec #60
Sedan revolution #107
Originally Posted by mikebontoft View Post
oh but my was she hungry!
Originally Posted by besthaticouldo View Post
white. or i will smack you in the cock.
russmistro is offline
Old 03-17-2011, 08:11 PM   #6
uRabbit
Fan#: 82829
That's exactly it.
And wow, okay, the fluid level is at MIN. Huh. It must have a leak somewhere. I checked it... Oh wow. It's been two weeks since I checked it.
uRabbit is offline
Old 03-18-2011, 12:40 AM   #7
goinloco1
Late for Dinner
goinloco1's Avatar
Fan#: 8529
What I Drive: kermit
Points 14,712, Level 78
Points: 14,712, Level: 78 Points: 14,712, Level: 78 Points: 14,712, Level: 78
Level Up 66% Completed
Forum Activity 21%
Activity: 21% Activity: 21% Activity: 21%
FF Reputation: 90 goinloco1 Excellent Standing Member
Pump is shot. My 07 did the same thing.
good news is advance carries reman pumps for around 45 bucks.
goinloco1 is offline
Old 03-18-2011, 07:36 AM   #8
frednumber15
frednumber15's Avatar
Fan#: 83585
What I Drive: 2003 2dr ZX3
Points 1,671, Level 23
Points: 1,671, Level: 23 Points: 1,671, Level: 23 Points: 1,671, Level: 23
Level Up 72% Completed
FF Reputation: 5 frednumber15 Good Standing Member
I'd put the car up on ramps and LOOK to find the leak. My PS system has/had 2 areas where it leaks....the coolant line at the coupling near the bottom of the radiator on the drivers side...and from out of the boots on the ends of the rack. I'm going to try using Lucas PS leak fix fluid...a lot of people claim it works.
2003 2dr ZX3 2.0 L Zetec auto 205/50/16s
...and I am unanimous in that position.
frednumber15 is offline
Old 03-18-2011, 07:58 AM   #9
whynotthinkwhynot
Captain TMI
whynotthinkwhynot's Avatar
Fan#: 18416
Points 27,736, Level 98
Level Up 39% Completed
Forum Activity 5%
Check for leaks.
The Ford (all Fords) power steering pump noise is something that happens when the pump is going bad, old, or the wrong fluid is put in it. Most of the time- especially if someone says "I just changed the pump and it still does this"- they have put in the wrong fluid. Reading comprehension is part of the problem- even on this forum I get feedback against what I've double checked. The right fluid is either standard power steering fluid, or Type F ATF. In the Owner's manual it will be listed as "Mercon", and give a Motorcraft part number that is different from the AT fluid which is MerconV. Lots of people think this means that it uses any Mercon, but old Type F is thicker, and is the same as standard power steering fluid. All other Mercons are too thin. It works, but it moans.
One thing you can try doing now, to see if it goes away, is bleed the system. It's very simple, rotate the steering all the way to one side, and then all the way to the other side with the engine running. Do this a few times. If the fluid was low before you topped it off, this might help. You'll still have to find and repair the leak, but if air in the system was the cause, then you'll alleviate it.
I personally advise against stop leaks. These things are designed to seal up a system when the fluid comes into contact with air. Well what happens when the fluid leaks out? Anyway, the Lucas stuff is just a thickener, and that will solve seepage from old seals in some cases. In other cases it will completely break the seal. If you're handy with a wrench, pop your head under the car- find the pressure and return line, see if you can turn the pressure line fitting with a wrench. Do not be surprised if the pressure line seems floppy or loose. The line should move when the fitting is tight. I'd then clean all the built up crud off so I could see where the leak was.
Hopefully that will solve all your problems, if not, then you'll need to either replace the O-ring seal at the pressure line, replace the pressure line itself, or whatever is causing the problem.
Be eclectic.
You're special aren't you.
whynotthinkwhynot is offline
Old 03-18-2011, 09:14 AM   #10
frednumber15
Fan#: 83585
IF my rack was not leaking at the seals (1/8" loss of fluid every 300 miles?....under the boots) I would flush the whole system and use Mobile 1 synth ATF with some Lubegard additive. I did this with my truck...got some metallic soup looking fluid out...did need to put the front up on jacks and move the steering back and forth with engine running to bleed it...not a good idea to try and drive it and expect it to bleed.
As it is...with the Lucas stuff I might get a couple of years out of it yet....not much point in Mobil 1 and Lubegard. I'm currently doing a sort of easy flush...just using a t baster to get some fluid out and putting in new Mercon. I solved the line leak at the coupling near the rad by just moving the coupler back and forth...leak stopped.
