Knock Sensor spark? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 03-15-2011, 08:30 PM   #1
iminhell
C2H5OH
iminhell's Avatar
Fan#: 36222
Points 18,426, Level 86
Points: 18,426, Level: 86 Points: 18,426, Level: 86 Points: 18,426, Level: 86
Level Up 16% Completed
Level up: 16% Level up: 16% Level up: 16%
Forum Activity 7%
FF Reputation: 49 iminhell Great Standing Member
Buy-Sell-Trade Rating: (4)
Knock Sensor spark?
KNK_SEN_RETARD is what it's called, or what I'm talking about.
When the number is positive it it adding spark, advancing, or retarding spark?
I assume it's adding spark but I just want to be sure.
Also, should I let the knock sensor do it's thing or should, can, I adjust the timing at those loads to keep the sensor from adding or removing timing ... much the same process as doing the MTF?
Something like you'd only want to see the KS add/subtract 0.5* at most instead of the -5 to +6 I'm seeing now.
Steady throttle, 60mph, on my way home I logged and all the KS did was add timing, positive numbers, moderate loads, 0.65 and below ... but load for me right now is all screwed up I think, WOT nears 1.9 for a load vs the 1 I think it should be; figure that out when I can, if I can.
Don't "think outside the box".
There is no box.
Do it correct, or do it twice.
iminhell is offline
Old 03-15-2011, 08:45 PM   #2
1turbofocus
FF Affiliate
1turbofocus's Avatar
Fan#: 1123
Points 51,351, Level 100
Points: 51,351, Level: 100 Points: 51,351, Level: 100 Points: 51,351, Level: 100
Level Up 0% Completed
Forum Activity 27%
Activity: 27% Activity: 27% Activity: 27%
Buy-Sell-Trade Rating: (28)
You need to get the load straight it is one of the largest things with timing
You are correct -2 means it is taking 2 deg from the timing , 2 means it is adding 2 deg to the timing
I like to set the timing tables where it is adding about .5 to 1 deg by it self and you will see this change a lot with enging temp , intake air temp , load etc
NA you shouldnt be seeing more then 1.2ish load
Customer Support
AIM: hpdyno
Email: hpdyno@aol.com
Phone: 704-249-3745
Site: focus-power.com
Elder 1turbofocus
1turbofocus is offline
Old 03-15-2011, 09:03 PM   #3
iminhell
C2H5OH
iminhell's Avatar
Fan#: 36222
Forum Activity 7%
Load is based off the MTF right?
and if my STFT's are pretty damn close to perfect, why would Load be so screwed up?
There is no box.
iminhell is offline
Old 03-16-2011, 01:08 AM   #4
illinipo
Token Engin-nerd
illinipo's Avatar
Fan#: 37693
What I Drive: dirty wag; Party; Bavarian phallus
FF Reputation: 272 illinipo Outstanding Standing Member illinipo Outstanding Standing Member illinipo Outstanding Standing Member
Buy-Sell-Trade Rating: (19)
load being that high could mean a couple things.
1. engine displacement scalar is wrong (but I assume you havent changed this)
2. injector values are wrong, this is likely if the load is way off and the MTF is giving good stft's
3. MTF is way too high and the stft are bad
Theoretically 1.0 load is perfect volumetric efficiency, you should never see more than that on a NA car. In fact I would be impressed to see more than .95 load. Unfortunately load calculation is only as good as your tune. I have seen a bit over 1, maybe 1.02 or 1.03 on my logs after I changed injectors, so I just changed the injector slopes and MTF a bit to get it to fall around .96-.98 at wide open.
I'm trying to think if what you are seeing is from too big or too small injector slopes... need a minute on that one. Hopefully it is becoming apparent to you why it is so important to have the correct injector values in your tune, as I have been telling you for years. The entire tune is thrown off when the load calculation is wrong.
Originally Posted by Dennis_Grant
Remember this list: Bilstein; Penske; Koni; Ohlins; Sachs; Dynamic Suspension.
Not on this list? Almost certainly crap.
SUV this!
illinipo is offline
Old 03-16-2011, 05:29 PM   #5
iminhell
C2H5OH
iminhell's Avatar
Fan#: 36222
Forum Activity 7%
Well I'm not going to change anything just yet. I have parts on the way to rebuild my 42#'ers and I'll toss them in. It could be the PZEV injectors aren't 24# as I'd always thought. I never have been able to track down any info on them through Bosch, and I'm not convinced they are really a Bosch injector, the 12 hole design look to be only a Delphi design; so the PZEV would be a Delphi with a Bosch part # on it is what I'm thinking.
At least the 42's I know what they are and many people are using them, the Ford racing 42's you get in the PW kit.
Should be a day or 2 and I'll have them in.
Odds are everything is screwed up and I'll have to start from scratch again. But that's probably a good thing, teaches me more. And I should be able to get it back in line much faster than this trial run.
There is no box.
iminhell is offline
Old 03-16-2011, 06:34 PM   #6
1turbofocus
FF Affiliate
Fan#: 1123
Forum Activity 27%
Your PZEV Inj are not the issue
Customer Support
AIM: hpdyno
Phone: 704-249-3745
Elder 1turbofocus
