ECU Tuning Chat Discuss performance tuning options for your Ford Focus.
#1 | ||||
Faulty code
I'm getting this code p0135 o2 heater circuit bank 1 sensor 1. So I put a new front o2. But code keeps coming on. What do I need to do. Did i misunderstood the code. The sensor 2 has same faulty code but getting toms tune this week and it turns off rear o2 so not to worried about that but help with the other one would be great. Thanks
Remove Advertisements |
Fan#: 1
#2 | ||||
DTC P0606
Check your wiring harness and connectors.
P0135 - HO2S Sensor Circuit Malfunction (HO2S-11) During testing the HO2S Heaters are checked for opens/shorts and excessive current draw. The test fails when current draw exceeds a calibrated limit and/or an open or short is detected. Short to VPWR in harness or HO2S. Water in harness connector. Open VPWR circuit. Open GND circuit. Low battery voltage. Corrosion or poor mating terminals and wiring Damaged HO2S heater. Damaged PCM. |
#3 | ||||
FF Affiliate
If your getting my tune just hang on till you get it and with the predator we will be able to datalo and get the problem fixed
Could be o2 fuse wiring to check these 2 with key on unplug the o2 sensor and with a test light see if you have power to the o2 sensor could be that your running lean , tune and datalog will tell us that , check good for Vac leaks , dirty MAF Tom
Focus-Power: Your #1 Source for Ford Focus Speed, Tuning & Performance! Customer Support AIM: hpdyno Email: tom@focus-power.com Phone: 704-249-3745 Site: focus-power.com Elder 1turbofocus |
#4 | ||||
Ok only getting p0135 sensor 1 bank 1 heater circuit code now after tune. No vacuum leak fixed that. How do I data log with the tuner?
#5 | ||||
FF Affiliate
Check to see what the voltage is with the key on engine not running at the front o2 sensor , unplug it and see what the voltage is , if you have no voltage check the fuese on the fire wall then check the wiring
If you have voltage then datalog and send it to me datalogging is under diagnostics Tom
#6 | ||||
Ok got it fixed turns out to be a fuse. Question one last code left. It doesn't set off check engine but still. P1000, obd systems readiness test not complete. What is that. Should i be concerned?
| Thread Tools | |
| Display Modes | |
