2003 cruise control shuts off - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 03-16-2011, 12:20 AM   #11
sailor
Elder
sailor's Avatar
Fan#: 57268
Points 13,378, Level 75
Points: 13,378, Level: 75 Points: 13,378, Level: 75 Points: 13,378, Level: 75
Level Up 32% Completed
Forum Activity 99%
Me Too
Originally Posted by mikeeshaq View Post
BC_ZX3 is RIGHT
STICKY this post!
Yup, Me too
sailor is online now
Old 03-16-2011, 11:32 PM   #12
6SPD_soul
6SPD_soul's Avatar
Fan#: 53637
What I Drive: 2003 Comp Orange EAP SVT
Points 2,489, Level 30
Points: 2,489, Level: 30 Points: 2,489, Level: 30 Points: 2,489, Level: 30
Level Up 26% Completed
FF Reputation: 24 6SPD_soul Great Standing Member
Thanks for the rep and sticky nominations, hopefully people will find this if they need to diagnose cruise control issues.
6SPD_soul is offline
Old 04-25-2011, 09:24 PM   #13
bigbuick
Fan#: 54944
What I Drive: 2003 zx5
FF Reputation: 1 bigbuick Good Standing Member
My cruise wouldn't work, turns out it was the 3rd brake light burnt out. Changed the bulbs and all is fine again.
bigbuick is offline
Old 04-26-2011, 07:58 PM   #14
RunninPlaya
Fan#: 84370
What I Drive: 2003 Silver SVT
FF Reputation: 1 RunninPlaya Good Standing Member
weird, but interesting
not sure if you've thought of checking this, but if you have a vacuum leak somewhere it can throw off your cruise control. more commonly a chevy problem, but this is a possibility.
RunninPlaya is offline
Old 05-09-2011, 01:36 AM   #15
sparky34kv
Fan#: 63383
What I Drive: 2004 Blue ZTW Wagon, 2.3 L Duratec
Points 365, Level 7
Points: 365, Level: 7 Points: 365, Level: 7 Points: 365, Level: 7
Level Up 30% Completed
FF Reputation: 1 sparky34kv Good Standing Member
Thanks for the diagnostic. Mine turns on the indicator in the instrument cluster, but doesn't actually engage the cruise control. With any luck this will tell me where it has gone wrong. Again, thanks for sharing.
sparky34kv is offline
Old 05-11-2011, 06:58 PM   #16
Buhda420
Buhda420's Avatar
Fan#: 85611
What I Drive: 2003 svt, silver. 5dr
FF Reputation: 1 Buhda420 Good Standing Member
Okay I just ran the diagnosis minutes ago and flash three times it did haha!!!!!! which means "Brake deactivation switch is open or circuit is damaged"....... dude it was easy and worked like a charm....... so how do i fix the number 3 problem???
Buhda420 is offline
Old 05-11-2011, 07:14 PM   #17
Buhda420
Buhda420's Avatar
Fan#: 85611
Thumbs up Ran test!!!!
everything was easy if you fallow step by step..... i read the instructions then wrote down the important steps so it would be fast to read........ ran the test and it was a success on first try.... results read 3 flashes which means Brake deactivation switch is open or circuit is damaged...... soo im going to be honest..... i just started working on cars and yeah so please tell me where to go from here!!!!!!!! thank you very much for all your help!!!!!!!
Buhda420 is offline
Old 05-11-2011, 09:03 PM   #18
6SPD_soul
6SPD_soul's Avatar
Fan#: 53637
My problem was the brake deactivation switch too. Have you had any work done on the car lately where someone would have been in drivers footwell area? Anyway, to get at the pedal switches that interact with the cruise control, you need to remove the panel underneath the steering wheel. I think the bolts are all 6 or 8 mm if I remember correctly. You will also need to get the hood release out of the way, there's a big nut on the back and a crescent wrench will loosen it some (don't remember size, might be 3/4 or something) then you pull it down out of the way; the release cable is just in a groove and the nut holds it in place. You would also need to pop the OBD scan port through the panel for the panel to come free, I think this is easiest if you get the panel loose and then use a small screwdriver or something to wedge it through the gap, look at it closely and be careful with it as it could be an expensive mistake, but it pops through pretty easily. There will be a small panel covering the OBD port and it just pops out with a finger pull at the bottom.
Once the panel is free you can get down in the footwell and examine the pedal assembly and switches. There will be 3 switches in front of the top of the pedals. The brake deactivation switch is the green one on top, stop lamp switch is grey, and clutch position switch is red. They all work the same way, they have spring loaded plungers that either open or close circuits when they extend. In the case of the brake deactivation switch, you hit the brake, the pedal arm moves away from the plunger, the plunger moves out and the circuit opens, deactivating the cruise control.
Odds are very good that green switch is faulty. The BPP switch has a ratcheting mechanism that only goes one way, so for instance, if you were to intentionally pull up on the brake pedal the plunger would go further into the switch and if you then let go of the pedal the plunger might not extend far enough back out to contact the pedal arm, and the circuit would stay open and disable the cruise control. You can test the switch by bypassing the plunger mechanism and using a little jumper wire to complete the circuit. To remove the green brake switch you rotate counter-clockwise and some tabs line up with slots and then you can pull the switch from the pedal assembly; it will be the plunger mechanism and a little wiring harness deal it mates with. You separate the two by taking a small pick or something and pulling out the square little brass tab(that's a misleading description, but you'll recognize it when you see it) it just pulls straight out and then the plunger mechanism will be free from the wiring.
I don't remember now how many wires are involved. If there are only two you can just find the corresponding connections in the bottom of the wiring harness and bridge the gap with a small (thin) jumper wire (just a small wire with stripped, nicely twisted ends like a spliff). This closes the circuit and fools the CC system into thinking that the brake pedal is in its normal position. You could then run the self diagnostic again, and if it passes you will know that the problem was the plunger switch. I'm going to try to check some schematics tomorrow and see if I can identify exactly where the jumper wire needs to go. Incidentally, you could keep the jumper wire in and leave the plunger mechanism out altogether, but then you wouldn't be able to shut off the cruise control with the brake and that's a little dangerous.
The switch was like $25 from a local dealership, so you could just buy the switch and put it in. Also, if the only thing you mess with is that green brake switch, it won't affect the car at all to leave it disconnected while you figure it out; that switch only interacts with the CC system and that's already broken, so you can't harm it anymore by leaving it disconnected.
To install the new switch, just plug the switch and harness back together, and push the square metal tab back into place. Then you have to depress the brake pedal, line up the switch correctly so it slots back in, and then turn it back clockwise until it stops. Be careful not to depress the plunger when putting the switch back in, it could effectively ruin it since it only ratchets in and doesn't come back out all the way. Then you release the brake pedal and the plunger ratchets to the correct position and that's it. Set aside plenty of time and make sure you have a good light source so you can see what's going on around the pedals.
Just realized I wrote an entire novel about a cruise control brake pedal position switch.
Old 05-13-2011, 01:29 AM   #19
Buhda420
Buhda420's Avatar
Fan#: 85611
MY CRUISE CONTROL WORKS NOW!!!!!!!!!! I OWE IT ALL TO YOU SIR :)!!!!!!!! thank you
Buhda420 is offline
Old 05-13-2011, 02:00 AM   #20
Vexorg
Vexorg's Avatar
Fan#: 85499
What I Drive: 2001 Zx3 ChromeGold
FF Reputation: 3 Vexorg Good Standing Member
Most excellent. and welcome to hobbyist car fixing. You can learn lots on these forums. My number one advice is to find a GOOD INDIE PARTS STORE. If the store employees look like they have never heard of a PCV valve, or are experts at selling Air Fresheners, and pushing the counter product of the day... this is NOT your part store.
My part store rocks. There's several parts veterans there... and they sell to many regional repair shops. That's the first clue you are onto something. 2nd clue.. They have super good filters in stock. Look for brands like Hastings, Wix, and Purolator. When you need a part, do they have to order pretty much anything, or can they have it later today, or it's in the back..... If they seem to have nothing in stock for a car as common as a Focus, this is NOT your part store. Do they specialize in shiny lights to put under your dash board? this is NOT a parts store... it's a BS retail operation.
A good part store has real stock, smart people that get you the RIGHT part, and the prices are totally fair. There's no "super protection warranty" for an extra 20$.. none of that crap. Just parts and smart people.
My car part stores are "Car Parts Warehouse" (carpartsplus) and my most favorite. Fisher Federated (Federated Auto Parts). The big losers are the shamrock guys, and the big orange zone. the Red place with the checkered flag isn't on a hate list.. so they get me by in a pinch.
Vexorg is offline
