LED dome light - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum > Ford Focus First Generation > MK1 Interior Mods & Upgrades
Old 07-21-2014, 01:26 PM   #11
Tiger-Heli
Fan#: 12379
What I Drive: 2002 French Blue SE Sedan
Points 999, Level 16
Points: 999, Level: 16 Points: 999, Level: 16 Points: 999, Level: 16
Level Up 99% Completed
Level up: 99% Level up: 99% Level up: 99%
Forum Activity 7%
FF Reputation: 4 Tiger-Heli Good Standing Member
I thought Reply #3 covered that ...
Tiger-Heli is offline
Old 07-21-2014, 02:04 PM   #12
NickZ20
Fan#: 160058
What I Drive: 2003 Red ZX3
Points 748, Level 14
Points: 748, Level: 14 Points: 748, Level: 14 Points: 748, Level: 14
Level Up 48% Completed
Level up: 48% Level up: 48% Level up: 48%
FF Reputation: 1 NickZ20 Good Standing Member
Nope, that's called a work around. Even though it's minor if there's any electricity leaking where it's not supposed to, I want to fix it.
NickZ20 is offline
Old 07-21-2014, 02:26 PM   #13
Tiger-Heli
Fan#: 12379
Forum Activity 7%
So you want to re-wire the entire car ???
Ford designed the circuit for an incandescent bulb and determined that a few mA of stray current wouldn't matter as it wouldn't be enough to light the filaments in the bulb.
If you want to remove the dome light wiring from the central timer module and run new door switches and the dome light wiring straight from the fuse box it will work, but not with the delay and be a nightmare for anyone how has to t-shoot the circuit. Or you can wire in a pull-down resistor ...
Old 07-21-2014, 02:29 PM   #14
NickZ20
Fan#: 160058
I was thinking maybe a worn out door switch? Is this something that I can ignore and just leave it alone throughout the whole night every night? It is very dim but I don't want to destroy something.
NickZ20 is offline
Old 07-21-2014, 03:07 PM   #15
Tiger-Heli
Fan#: 12379
Forum Activity 7%
Everyone else in the thread said it is normal. You can either live with it, add the pull-down resistor, or swap back to incandescent.
Old 07-21-2014, 05:40 PM   #16
NickZ20
Fan#: 160058
Where do I get a pull down resistor? Do I have to solder?
NickZ20 is offline
Old 07-22-2014, 07:06 AM   #17
Tiger-Heli
Fan#: 12379
Forum Activity 7%
I would try here: http://bit.ly/1nQdpCT
I would think the local Radio Shack should have these also.
Keep in mind, I have never done this and probably wouldn't bother (I hate and suck at soldering), but ...
Yes, you are pretty much going to either need to solder the resistor into the existing wiring, solder the resistor to wire leads and splice into the existing wiring, or solder the resistor across the LED.
Personally, I would do the last one, but I don't know how careful you need to be with heat and the LED lights.
(You don't necessarily HAVE to solder - the dome light is a festoon bulb, so you MIGHT be able to tuck the resistor leads under the contact wires of the bulb holder - it should work, but obviously won't be as good a connection.)
Old 08-05-2014, 06:08 PM   #18
NickZ20
Fan#: 160058
Fixed it, paid a dollar for a two pack of 1 watt resistors, wrapped it around each end and called it a day. Took care of that.
NickZ20 is offline
Old 08-06-2014, 07:40 AM   #19
Tiger-Heli
Fan#: 12379
Forum Activity 7%
Good deal - thanks for letting us know.
Old 02-02-2015, 11:15 PM   #20
dukevader33
Fan#: 61990
What I Drive: 2004 black
Points 9, Level 1
Points: 9, Level: 1 Points: 9, Level: 1 Points: 9, Level: 1
Level Up 17% Completed
FF Reputation: 1 dukevader33 Good Standing Member
Dome light trim
Where did you buy the LED interior light? Does it come with a new trim piece? My trim piece is broken and I cannot find a replacement, unless any of you know where I can find one!
dukevader33 is offline
