Massive PORTWERKS Duratec ULTIMATE Cylinder Head finally available!!! - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum > Exclusive Vendor Discussions > Massive Speed
Massive Speed Discuss about forced induction upgrades and performance tuning for your Ford Focus.
Sponsored By: Massive Speed
Old 03-01-2011, 04:41 PM   #1
K Dog
FF Affiliate
K Dog's Avatar
Fan#: 23554
What I Drive: Car
Points 15,918, Level 81
Points: 15,918, Level: 81 Points: 15,918, Level: 81 Points: 15,918, Level: 81
Level Up 14% Completed
Buy-Sell-Trade Rating: (19)
For Ford 2.0/2.3 Duratec powered vehicles.
These heads have been through years of development and "back-burnered" long enough!!!
Finally released to the public - out ULTIMATE CNC ported cylinder head for the Duratec!
Here's the dirt:
Simply the best head money can buy.
Massive has created the worlds TOP FLOWING CYLINDER HEAD SERIES for modern Ford 4 cylinders!!!
5 Axis CNC machined for the best in consistency and flow!
In our quest for power superiority, OE heads are flow tested on a Superflow SF-600 flow bench at 28 of water to determine base line flow numbers. After the initial flow test the heads were ported by hand to develop a working port shape and volume. The head was then reflowed after hand porting to verify the increase in flow. The heads are then reverse engineered using 5-axis digitizing to acquire the port shape of the finished port. This makes for the greatest possible flow capacity and consistency.
Heads begin as production cores which are fully disassembled and hi temp rwashed. The heads are then glass bead blasted clean to remove any rust or scale. They are then CNC machined using 5-axis simultaneous machining. All ports and chambers are machined then hand finished to blend out any unwanted tool marks. All valve guides are honed to size and a multi-angle valve job is cut into the head. The valve job is cut using Newen single carbide insert style cutters of varying profiles. The valve job is hand lapped in then blended to the finished port and chamber. The heads are then surfaced and reflowed again to confirm that the finished product performs as expected. Our designs outflow ANY competitor Zetec/Duratec head without sacrificing velocity. Substantial chamber modification for superior flow dynamics and greater resistance towards detonation. NEW on 2011s heads:
  • Crower high rate valve springs allow for elevated RPM usage without float. High boost applications WONT force force them open.
  • Crower lightweight Titanium retainers. This reduced valve train weight allows faster revs and avoids valve float while maintaining strength.
  • SuperTech OVERSIZE +1mm undercut stainless steel black nitride hardened valves. Undercutting, in addition to reducing the valve weight (which provides benefits in opening rate and RPM limits) the radius of the head is such that is significantly improves air/fuel flow. Fully swirl polished. Nitriding reduces guide friction and increases surface hardness.
  • Fel-Pro PREMIUM valve stem seals standard
JUST $1557!!! In stock!
Core return required (must be identical casting # on Duratec, call for info) or $200 core fee must be collected.
08+ vehicles may require retrofit to early style camshafts/sensors/wiring. Will bolt on VCT equipped cars but would obviously need same retrofit and possible tune.
Find em Here
K Dog is online now
Old 03-01-2011, 07:49 PM   #2
Blackcatn2o
soon to be turbo!
Blackcatn2o's Avatar
Fan#: 48278
What I Drive: 06 silver ZX4 ST
Points 8,020, Level 60
Points: 8,020, Level: 60 Points: 8,020, Level: 60 Points: 8,020, Level: 60
Level Up 35% Completed
Level up: 35% Level up: 35% Level up: 35%
FF Reputation: 48 Blackcatn2o Great Standing Member
Buy-Sell-Trade Rating: (13)
Is the price still the same if I provide the valves, springs, retainers, keepers, and cams?
Blackcatn2o is offline
Old 03-02-2011, 09:10 AM   #3
K Dog
FF Affiliate
K Dog's Avatar
Fan#: 23554
What I Drive: Car
It only comes assembled, so yes. We can provide install/lashing service should you provide cams.
K Dog is online now
Old 03-02-2011, 09:36 AM   #4
UnFocusedST
Fear the TurboSnail!
UnFocusedST's Avatar
Fan#: 40342
What I Drive: 2013 Performance Blue Focus ST
Points 6,369, Level 52
Points: 6,369, Level: 52 Points: 6,369, Level: 52 Points: 6,369, Level: 52
Level Up 10% Completed
Forum Activity 9%
FF Reputation: 13 UnFocusedST Great Standing Member
Buy-Sell-Trade Rating: (14)
Hmm I'll have to save my pennies.
Team Duratec #17
Hatch Nation #17
Midwest Crew #55
Boosted Crew #118
UnFocusedST is online now
Old 03-02-2011, 01:38 PM   #5
Blackcatn2o
soon to be turbo!
Fan#: 48278
Also look into raceco.com its a uk company that makes wider valves for this engine.
Old 03-02-2011, 02:22 PM   #6
Buickboy
br/o/stang
Buickboy's Avatar
Fan#: 28542
What I Drive: 72 Skylark, '12 Mustang
Points 28,207, Level 98
Points: 28,207, Level: 98 Points: 28,207, Level: 98 Points: 28,207, Level: 98
Level Up 86% Completed
Forum Activity 3%
FF Reputation: 39 Buickboy Great Standing Member
Buy-Sell-Trade Rating: (29)
dat flow numbers
why did I have to buy a house?! ! someday lol. glad to see it comes with springs/ retainers and the option to install cams
==2012 Kona Blue Mustang V6==
==1995 Light Iris Neon Coupe==
==1972 Skylark==
Buickboy is online now
Old 03-02-2011, 06:51 PM   #7
K Dog
FF Affiliate
K Dog's Avatar
Fan#: 23554
What I Drive: Car
It comes with +1mm SuperTech's already? Why?
A future ProRace version with +2mm valves could be made availalbe as Supertech has made them for us before.
K Dog is online now
Old 03-02-2011, 07:00 PM   #8
Blackcatn2o
soon to be turbo!
Fan#: 48278
Alright
Old 03-02-2011, 08:22 PM   #9
Buickboy
br/o/stang
Buickboy's Avatar
Fan#: 28542
Forum Activity 3%
have you guys tested a ford racing duratec head VS one of these on the bench?
==1972 Skylark==
Old 03-03-2011, 11:38 AM   #10
K Dog
FF Affiliate
K Dog's Avatar
Fan#: 23554
What I Drive: Car
No.
FR is out and to my knowledge doesn't intend to reproduce them.
It's got almost no port work and totally stock valvetrain.
K Dog is online now
