SCT Datalogging 101 - Downloadable Datalog List & How-To - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 02-28-2011, 11:04 AM   #1
1turbofocus
FF Affiliate
1turbofocus's Avatar
Fan#: 1123
Points 51,939, Level 100
Points: 51,939, Level: 100 Points: 51,939, Level: 100 Points: 51,939, Level: 100
Level Up 0% Completed
Forum Activity 35%
Activity: 35% Activity: 35% Activity: 35%
Buy-Sell-Trade Rating: (28)
This will take some time to get finished , I will be posting links to download datalog list for your Yocus of Diff years and ECU codes for the ZX3 , SVT , Duratec codes
Downloadable DataLog List Files for SCT LiveLinkTHESE ARE GENERIC LIST THAT WORK ON 85% OF THE FOCI IF IT says IT DOES NOT MATCH YOUR ECU GO PAST THAT AND THEY SHOULD WORK TO LOG WITH
Instructions:
  1. Download & Install LiveLink from SCT to your laptop.
  2. Download the correct engine datalog file above.
  3. Connect your SCT tuning device to your laptop & ODB-II port.
  4. Open SCT LiveLink.
  5. File > Open Live Link Configuration > Select Your File > Open
  6. Click Start Data Logging to begin logging.
STFT1/stft1 : Short Term Fuel Trim 1 (1 meaning bank 1 sensor1)
Some Duratecs use STFT FINAL / stft final (choose both 1 and final if datalogging)
This should be between 1.250 max rich and .750 max lean the target is 1.000 stoich 14.7 A/F. You will never see 1.000 (unless you just started your car OR you have failed closed loop and you are now in open loop read below ) as the ECU cannot hold the A/F at 1.000/14.7 so you should be seeing roughly between 1.100 and .900 always switching . On the graph the stft1 should look like a castle top and I would post a picture of a proper working stft1
Failed closed loop (enters open loop) is when either your above 1.250 max rich or below .750max lean , the o2 sensor has failed , fuse for the o2 sensor has blown
Fuse is located under hood on Drivers side fire wall Fuse # ????(anyone)
Location :This o2 is located closest to the Cyl. head between the CAT and Cyl head
ECT / ect: Engine Coolent Temperatures
This one should be easy and tells you the engine/water temp of the engine
Location: Zetec In the Cyl head close to Intake runners 1 and 2
Location: SVT in the thermostat Housing Pass side end of Cyl Head
Location: Duratec Center of head between Spk Plug 2 and 3
IAT / iat :Intake Air Temp
Measures the incoming air temperature between the filter and the Throttle body
MAF COUNTS / maf counts - MAF VOLTAGE / maf voltage
Measures the incoming air (Mass Air) to the engine in counts/voltage
Knock Retard / Knock timing adder
This shows the amount of timing retard or timing adder -2 would be 2 deg timing taken out , 2 would be the amount of timing added , Not all Foci have the ability to add timing
Zetec / SVT Knock sensor is located just below the 2,3 Cyl intake runners in the top back of the block
Duratec Knock Sensor is located on the front of the block below Cyl 2
Spark Advance / Timing
This will show the amount of timing that is going to the engine at that given RPM and load
Throttle Position Sensor / TPS Voltage / TPS Counts / TPS Absolute
This shows the amount the throttle is at , Idle would be close to 190-200 and WOT would be 850-1000
Location: TPS is located on the drivers side of the Throttle Body
Spark Source : There are MANY calculation that make up the final spark advance/timing this will tell you where the final timing calculation is coming from
Fuel Source : There are many ways to get fueling to an engine , closed loop , open loop , cold start etc. this will tell you what the ECU is using for fueling
If you are using SCT Live Link to do your datalogging and go to "Help" then to "Source Codes" it will tell you what the numbers mean that you will see in on the datalog for the Spark Source / Fuel Source
Time Stamp : At the bottom of all logging there is a timer that shows the amount of time the log has been running. It is a great help if your having an issue and you can reproduce that issue why logging to take a quick note of that exact time that way your tuner can go to that spot in time and see what's happening
What do things mean
ECT = Engine Coolent Temperature
IAT = Intake Air Temperature
WOT = Wide Open Throttle
TPS = Throttle Position Sensor
STFT1 = Short Term Fuel Trim , The 1 means sensor 1 bank one you would never use 2
LTFT Long Term Fuel Trim , rarely used
RPM = Revolution Per Minute
MAF = Mass Air Flow
EGR = Exhaust Gas Recirculation
IF THERE IS SOMETHING YOU WOULD LIKE TO SEE ADDED TO ANY OF THESE LIST PLEASE ASK
Customer Support
AIM: hpdyno
Email: hpdyno@aol.com
Phone: 704-249-3745
Site: focus-power.com
Elder 1turbofocus
1turbofocus is offline
Old 02-28-2011, 12:21 PM   #2
Jgrove998
i <3 my ST
Jgrove998's Avatar
Fan#: 45311
What I Drive: '12 Fusion SE V6
FF Reputation: 24 Jgrove998 Great Standing Member
Buy-Sell-Trade Rating: (13)
Sweet. A good start. Thanks Tom.
2012 Fusion SE 3.0L V6
'86 XR4Ti ; 2.3L Turbo, 15psi
1988 F150 Custom
'07 ST ; formally bewst'd - R.I.P
D23 Crew: #07
Jgrove998 is offline
Old 04-20-2011, 12:48 AM   #3
BowerR64
BowerR64's Avatar
Fan#: 78699
What I Drive: 2007 ZX3 SE
Points 12,075, Level 72
Points: 12,075, Level: 72 Points: 12,075, Level: 72 Points: 12,075, Level: 72
Level Up 7% Completed
FF Reputation: 12 BowerR64 Great Standing Member
what about what you do with the car?
Do you log a 1/4 mile drag run? a trip to walmart? a drive down the freeway for 5 minutes at 70mph, rev it up in park?
It's not important to win, it's important to make the other guy lose.
BowerR64 is offline
Old 05-01-2011, 09:00 PM   #4
1turbofocus
FF Affiliate
Fan#: 1123
Forum Activity 35%
All depends on what you need the log for , If youe working with a new tune and need to log then I would have you do a 5 min cruise , WOT in 3rd gear from 2000 to 4500 then a 1 min idle all in one log
If your trying to find an issue your having then log till the issue shows a few times then note the time stamps so your tuner can see the issue easier
Customer Support
AIM: hpdyno
Phone: 704-249-3745
Elder 1turbofocus
Old 05-01-2011, 11:52 PM   #5
BowerR64
BowerR64's Avatar
Fan#: 78699
Thanks, its all starting to come together now.
BowerR64 is offline
Old 06-23-2011, 09:57 PM   #6
BowerR64
BowerR64's Avatar
Fan#: 78699
Im having another issue now.
I can log using this datalog list but my LC-1 wideband wont show as a log option in the list. If i log threw the SCT it shows the LC1 but not some of the other options in this duratec log list.
How do i add the LC1 to the "duratec-log list"?
If i try adding the LC1 before i log on the SCT, then using livelink and the PC it locks up and wont show any data while its live logging. I get an error that says no data received for 10 seconds or somthing like that.
BowerR64 is offline
Old 06-24-2011, 09:15 AM   #7
1turbofocus
FF Affiliate
Fan#: 1123
Forum Activity 35%
When you download a list to log and have to add something to the list you will have to create a new list and check the PID you want to log, The checked PID wont show up if you need to add something else to the downloaded list I have been asking for that to be corrected for years
Just save the list where you can see it and go through the PID and check the boxes then next time you need to add something the checked boxes are there and you wont have to redo the list
Customer Support
AIM: hpdyno
Phone: 704-249-3745
Elder 1turbofocus
Old 06-25-2011, 03:49 PM   #8
BowerR64
BowerR64's Avatar
Fan#: 78699
Is this under commands, configure datalog items? The SCT needs to be plugged into the car then into the laptop to create a new list right?
Then when i make a new list it will "match the car" or what ever the warning says when it pops up?
What else can i add that will better help tune? Ide like to remove analog 1, 3 and 4 from the list.
BowerR64 is offline
Old 06-25-2011, 08:49 PM   #9
1turbofocus
FF Affiliate
Fan#: 1123
Forum Activity 35%
Yes you can remove analog 1,3,4 if your not using them
Customer Support
AIM: hpdyno
Phone: 704-249-3745
Elder 1turbofocus
Old 06-25-2011, 09:04 PM   #10
BowerR64
BowerR64's Avatar
Fan#: 78699
Ok ive figured out how to make a new log list and it seems to work ok.
What are some other things that would be good to add to help tune the car better? Besides whats posted in the duratec log?
I have a 2.0 with FSwerks intake and 103 copper plugs thats about all ive done.
I also have a wideband, ofcorse ide add that.
BowerR64 is offline
