Short throw AUTOMATIC shifter - Page 16 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 04-27-2011, 05:14 PM   #151
CJohn364
GoKart and Me!!!
CJohn364's Avatar
Fan#: 49277
What I Drive: 2K5 ZX4 SEt (ATX) French Blue, Met
Points 73,243, Level 100
Points: 73,243, Level: 100 Points: 73,243, Level: 100 Points: 73,243, Level: 100
Level Up 0% Completed
FF Reputation: 119 CJohn364 Excellent Standing Member CJohn364 Excellent Standing Member
Yours looks good, also. I had to use a grommit or something similar to put on the shifter to fill the gap so that the orange marker still showed what gear it's in. I had some issues with my key coming out as well and that was the issue. Once I put the grommit in, no issues. I relocated my OD button on the left side of the center console between the shifter and ebrake. You can see it in the lower right corner of this pic:
-Carl-
Sedan Revolution #61 / NW Posse #2
FF Moderator
Member Rules
Buy-Sell-Trade Rules
Complete 'How-To' Archive
General Racing Thread Rules
CJohn364 is offline
Old 04-27-2011, 05:32 PM   #152
Tom-E09
Pimp'n ain't easy
Tom-E09's Avatar
Fan#: 59383
What I Drive: 2002 Gray ZTS
Points 9,998, Level 66
Points: 9,998, Level: 66 Points: 9,998, Level: 66 Points: 9,998, Level: 66
Level Up 87% Completed
Level up: 87% Level up: 87% Level up: 87%
Forum Activity 10%
FF Reputation: 2 Tom-E09 Good Standing Member
looks good carl
Sedan Revolution #138SR Town Drunk
Team Dreamspeed
Originally Posted by ChazimusZX4ST View Post
I come speeding along and they think I'm all "lets run" when in reality its "MOVE YOU POS, IT'S BURRITO TIME!"
God I love burritos.
Tom-E09 is offline
Old 04-29-2011, 12:15 AM   #153
mpalmer91
Fan#: 74582
What I Drive: 2003 Twilight Blue Sedan - 2.3L
Points 293, Level 5
Points: 293, Level: 5 Points: 293, Level: 5 Points: 293, Level: 5
Level Up 86% Completed
FF Reputation: 2 mpalmer91 Good Standing Member
Buy-Sell-Trade Rating: (7)
does anyone know whats underneath the little popup panel, to the right of the shifter directly across from 2nd gear? that little circle looks like a great place for a button for the OD. I popped it off but didnt see anything, any reason it wouldnt work?
Originally Posted by CJohn364 View Post
MTX-75 swapped, Exedy OEM clutch kit, 05 front brakes, VF Engineering mounts, tint, fog lights, cosworth cai, custom 2.5" exhaust, focussport upper stress bar, ground control/koni yellow coilovers, more to come
mpalmer91 is offline
Old 04-29-2011, 12:21 AM   #154
CJohn364
GoKart and Me!!!
CJohn364's Avatar
Fan#: 49277
Believe it or not, that is a small access port. It leads to a small lever that you can depress using a long screwdriver or something similar in order to unlock the shifter. Like if your car is totally dead, but you need to put it in gear. You can use a screwdriver and press that lever and put the car in neutral.
-Carl-
FF Moderator
Member Rules
CJohn364 is offline
Old 04-29-2011, 12:28 AM   #155
mpalmer91
Fan#: 74582
Points 293, Level 5
ok thanks. darn, that wouldve been too perfect.
so to take a guess, is there an "outer tube", and and "inner tube" to the shifter? and the "inner tube" gets pushed down when we push the button in, which lets us shift?
Im trying to understand what makes it work so i can decide which style shifter i want to use. Id love to use the ball as i could make it shorter, but if i have to ill take one with a button.
Old 04-29-2011, 12:37 AM   #156
BowerR64
BowerR64's Avatar
Fan#: 78699
What I Drive: 2007 ZX3 SE
Points 12,075, Level 72
Points: 12,075, Level: 72 Points: 12,075, Level: 72 Points: 12,075, Level: 72
Level Up 7% Completed
FF Reputation: 12 BowerR64 Great Standing Member
Yeah i think you can just poke your key in the hole and put it into N to get it off the roadway or something if it stalls or if you dont have the keys. Say if some one leaves it in the way but its not something most know about. It says what it does in the manual but its not something most commonly know about.
It's not important to win, it's important to make the other guy lose.
BowerR64 is offline
Old 04-29-2011, 12:38 AM   #157
CJohn364
GoKart and Me!!!
CJohn364's Avatar
Fan#: 49277
From the stock T handle, you will have three parts. The outer sleeve, which is part of the T handle, the metal shaft of the shifter itself and then a plastic rod that runs down the center of the metal shaft. The plastic rod is what gets pushed down in order to unlock and shift the shifter.
-Carl-
FF Moderator
Member Rules
CJohn364 is offline
Old 04-29-2011, 12:59 AM   #158
BowerR64
BowerR64's Avatar
Fan#: 78699
I seen this one at walmart a few weeks ago and i busted out laughing. So i bought it and i actualy like the way it feels better then the first one i put on.
I decided this time to cover the shaft with some silver foil tape just to make it a little different.
The way the skull is shaped your fingers roll around the back of it and the size seems perfect for my hand.
Im handicapped in a wheelchair so i have to use an ATX and hand controls to push the brake and gas pedals. I relocated the O/D button to the handicap control lever. I also installed fog lights and put the button for them next to the O/D button.
BowerR64 is offline
Old 04-29-2011, 09:30 AM   #159
CJohn364
GoKart and Me!!!
CJohn364's Avatar
Fan#: 49277
I've seen that knob at Auto Zone. I like those seat cover, Ronnie.
-Carl-
FF Moderator
Member Rules
CJohn364 is offline
Old 04-30-2011, 12:51 AM   #160
BowerR64
BowerR64's Avatar
Fan#: 78699
Thanks Carl, i thought about tapping into the lights inside the shift console so the eyes would come on with the headlights but i figured its dumb enough why make it worse? lol
BowerR64 is offline
Similar Threads
08 Short Shifter Installed !! BradWhite DURATEC Performance (2008-2011) 164 07-12-2011 03:56 PM
I installed my short throw shifter today turbovation Focus SVT 41 03-11-2009 11:43 AM
need some help deciding on short throw shifter kshnitz ZETEC Performance (2000-2004) 13 10-30-2007 01:37 PM
Where can I find a short throw shifter for 07 ST AndrewST MK1 Interior Mods & Upgrades 3 08-11-2006 02:17 PM
