DURATEC Performance (2003-2011) The place to chat about any Duratec 23, 23E, and 20 engine performance, tuning and exhaust related upgrades.
#131 | ||||
The engine has 52k miles, and the oil is only on the threads of the two plugs. The ignition bit is dry, and in the same color as the other plugs - pretty much the same color as the day they were bought.
| Sponsored Links | |||
Advertisement | |||
#132 | ||||
swapped in the ar103s today gapped at .055"
engine seems to be running like new (not that it was too bad before) and now it is comparable to my wife's 2010 2.4 vibe with the throttle being a little more touchy at the start, wasn't like that before, it used to be sluggish (most likely because of the buildup/etc on the old plugs) thanks for the write up!
"I hate advice unless I'm giving it," Jack Nicholson Last edited by bmxninja; 04-15-2012 at 07:39 PM. |
#133 | ||||
just had my first total fill up after the swap, picked up a little over 2 mpg
"I hate advice unless I'm giving it," Jack Nicholson |
#134 | ||||
So let me know if I have gotten this wrong. AR103's are the recomended plug gapped to .55-.6, .55 for longevity and .6 for a bit extra power. So my question is if I gap them to .55 how long should I expect them to last? I saw 20K somewhere in here but I didn't see if that was the AR's or A103's.
Let me introduce Mr. Roush to the party. |
#135 | ||||
[QUOTE=jabulon;4102464]A bit off topic:
I have gapped my AR103 to 0.065 a few days back. The engine behaved beautifully, until this one time I needed to reach about 5k while the engine was still cold; it stalled, and I've decided to go back to .060. One thing I've noticed while gapping it on the first time, was some oil on the threads of two of the plugs. It did not look too suspicious to me then, so I simply wiped the threads off of the oil and put them back in. But, Today, I found out that the same two plugs are again covered in oil. Dose anyone have any insights on the issue ? Arty thinks: This is likely the a leaking cam cover gasket that will allow oil from above to drain into the spark plug well. If it is bad leak it could cause plug wire boot deterioration.
Comp Orange Coswagon /Torsen and 4.06 gear, alum. flywheel/w/Centerforce clutch. 2.3L/ 11.6 pistons, 39lb. inj. Eagle rods, Stage 2 Cosworth cams on ported street head with the Cosworth Intake and exhaust, 205NA HP., rev limit 7800 rpm. |
#136 | ||||
Hey Guys,
Brand new to the forum... I just bought an used 2007 ZX3 and replaced the plugs with the AR103's gapped at .055. I definitely felt the difference, it seems to have more power when I accelerate at higher speeds. Thanks for the info. |
#137 | ||||
Just put a set of A103's in today, the parts store didn't have AR's, gapped them out to .055 and noticed a good more responsiveness at most speeds. Will probably go with AR's next year when I change them out. Thanks for the info guys.
#139 | ||||
Great Advice!! 70k on my 2006 ZX3, old plugs were clean, showed about 050 gap. Put in 103's at .055. Mileage on first tank was mainly highway, with some city was 36MPG!! This is with the winter blend which has been giving me 30-31MPG. Can't wait for summer, I think if this holds I'll be able to break 40MPG.
Plugs were extremly easy to change. |
#140 | ||||
Fairly new to the community as well as conducting maintenance on a vehicle but this will go for the DURATEC engine that is in the 2009 Focus SE right? Sorry for the dumb question just want to get everything squared away before I replace my spark plugs! thanks |
| Thread Tools | |
| Display Modes | |
