2008 Focus radio won't work after changing battery - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 02-15-2011, 11:40 AM   #1
lzcooper
Fan#: 83311
What I Drive: 2008 Focus Silver
FF Reputation: 1 lzcooper Good Standing Member
Last night I changed the battery in my o8 Focus and now the radio does not work. I called the local dealership and they say that there isn't a code, never heard of this happening before. I googled it and it says that there are codes, of course one company needs the serial number of the radio and they will sell the code. I called another dealership and they say it probably needs to be reset but I have to bring it in and they will run diagnostics on it at $125/hr.
Really? Seriously? I have had Civics and you just open the glove compartment and there is the code you need! Is there anyway I can rest this radio myself?
I am having a seriously bad day, might go psychotic and drive this thing into a wall!
lzcooper is offline
Old 02-15-2011, 02:15 PM   #2
Jetta555
Jetta555's Avatar
Fan#: 76963
What I Drive: 2010 Ford Focus SE Metallic Grey
Points 1,024, Level 17
Points: 1,024, Level: 17 Points: 1,024, Level: 17 Points: 1,024, Level: 17
Level Up 24% Completed
Forum Activity 2%
FF Reputation: 1 Jetta555 Good Standing Member
i would make sure first that you have the right size batter, it might not have the juice to run it. also i would just pull the fuse out for the radio and plug it back in to see if it works. if this doesnt work, try pullin the radio out and unplugging it from the dash and remove the battery to let it reset its self. if none of this doesnt work i would just say go to the dealership and pay the ridiculous rates
For God so loved the world that he gave his one and only Son, that whoever believes in him shall not perish but have eternal life.
- John 3:16
Jetta555 is offline
Old 02-15-2011, 11:59 PM   #3
DrkKnight614
GO Green
DrkKnight614's Avatar
Fan#: 14522
Points 26,111, Level 96
Points: 26,111, Level: 96 Points: 26,111, Level: 96 Points: 26,111, Level: 96
Level Up 77% Completed
FF Reputation: 47 DrkKnight614 Great Standing Member
Posted via FF Mobile Agreed, pull fuse see if it's dead. Also try reseting your radio, there must be buttons you press to do so. Check your manual. Example mine I press EJ and LOAD and the thing will reset. Also try disconnecting and reconnecting the battery again. Disconnect it and leave it for 15mins. Reconnect and that will reset the cars ecu. If your radio still doesn't work after all that take it to ford.
Your not still under warranty? Your cars only an 08...they should just replace the thing for free.
DrkKnight614 is offline
Old 02-16-2011, 05:24 AM   #4
lequy
Fan#: 78319
What I Drive: 2010 focus ses coupe
FF Reputation: 1 lequy Good Standing Member
Not normal changing the battery on a 2008,
Focus ses coupe 2010
lequy is offline
Old 02-16-2011, 12:31 PM   #5
BLRich1
Nope, Chuck Testa
BLRich1's Avatar
Fan#: 22758
What I Drive: '14 TB ST3, '04 Silver SVT
Points 15,197, Level 79
Points: 15,197, Level: 79 Points: 15,197, Level: 79 Points: 15,197, Level: 79
Level Up 70% Completed
Forum Activity 2%
FF Reputation: 17 BLRich1 Great Standing Member
Buy-Sell-Trade Rating: (6)
Moved to "Ford Focus Technical Chat"
My Rides:
'14 Tuxedo Black ST3
'13 Ingot Silver Escape Titanium AWD
'04 CD Silver SVT, #877, 1 of 135 May 2011 ROTM, FF11: Best Display, Best of Show; AFN12: Best SVT, Best Audio, Finest Five, Carlisle Nifty Fifty
BLRich1 is offline
Old 02-16-2011, 02:50 PM   #6
whitefox
whitefox's Avatar
Fan#: 54401
What I Drive: 2008 Ebony CC 2dr coupe SES 5spd
Points 1,961, Level 26
Points: 1,961, Level: 26 Points: 1,961, Level: 26 Points: 1,961, Level: 26
Level Up 61% Completed
Level up: 61% Level up: 61% Level up: 61%
FF Reputation: 35 whitefox Great Standing Member
Something else must be wrong to be replacing the battery this soon in an 08. Mine is almost three years old from when I bought it and my trip back home will enter me in the 100,000 mile club. The stock battery should last at least five or six years.
Carl - whitefox -
Team Duratec # 164
Mid-Atlantic Team EXTREME
2008 Focus Ebony Clearcoat 2dr SES 5spd
whitefox is offline
Old 02-16-2011, 04:01 PM   #7
whynotthinkwhynot
Captain TMI
whynotthinkwhynot's Avatar
Fan#: 18416
Points 27,933, Level 98
Level Up 59% Completed
Forum Activity 10%
I have a factory battery- 05 model, 135k miles. Check your ground terminal wires, pull on each one of the small ones individually to be sure that their ring terminals are not damaged. If one comes loose, then there's your problem. I would expect more than a non-working radio though.
You should also check out the radio fuse. Look in the owner's manual for fuse location and descriptions. Pull the fuse to visually check it, and put it back in. That alone might help you figure out what's going on. Oh, and push on the volume button to turn it on.
Be eclectic.
You're special aren't you.
whynotthinkwhynot is offline
Old 08-09-2011, 05:17 PM   #8
magge3n
Fan#: 88679
What I Drive: Focus 2008
FF Reputation: 1 magge3n Good Standing Member
Does any one there knows how to solve this matter? or where the radio code numbers are hidden??
magge3n is offline
Old 08-10-2011, 09:18 AM   #9
magge3n
Fan#: 88679
Found the answer - the code numbers are in the glove compartment - just type them in and pressing chanel 5 to store them - and the radio works as a new one
magge3n is offline
Old 02-28-2015, 09:34 AM   #10
Juliah
Fan#: 224498
What I Drive: 2010 Silver SES
Points 4, Level 1
Points: 4, Level: 1 Points: 4, Level: 1 Points: 4, Level: 1
Level Up 7% Completed
FF Reputation: 1 Juliah Good Standing Member
I have a similar issue. Changed battery( son let battery die and it froze). Now there is no power to radio/CD player and Sync won't work. Also no power to USB outlet. Display says"Ford Focus". Any ideas?? Thanks
Juliah is offline
