My crash bar/splitter creation/installation (kind of a how-to) - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 02-13-2011, 05:23 PM   #1
mikealicious
'Merica
mikealicious's Avatar
Fan#: 47077
What I Drive: 2002 Black SVT (gone), 2012 SEL
Points 8,576, Level 62
Points: 8,576, Level: 62 Points: 8,576, Level: 62 Points: 8,576, Level: 62
Level Up 43% Completed
FF Reputation: 8 mikealicious Good Standing Member
Buy-Sell-Trade Rating: (10)
So I've had a tow hook on my svtf for awhile now, and up until yesterday, it's been basically purely aesthetics. It was weldled to the factory bumper beam, and would flex if you put any weight on it. So I decided (with some help of a friend) to make sort of a 'crash bar' that would be attached to the frame of the car, and re-weld the tow hook to that. I've also been wanting to create a splitter for a long time, so we decided to tackle both of those in one day. I tried to take pictures along the way to show you guys how we made them in case anyone else was wanting to do the same. Not sure if this qualifies as a how-to or not. lol
but here ya go:
first off, a picture of the car with the bumper and everything in the front of the car off
we decided as part of this crash bar, we would re-make the radiator support as well. we did this because we wanted to be able to remove the crash bar/splitter if needed to. so we used the two bolts on either side of the car that the radiator support were using (red circles), for our bolts/holes for the crash bar.
next we took a thin piece of aluminum to use as a template as we created the bends needed to use those holes and have a mounting part for the support beam
after we got that how we wanted, we got used the same steel that we used for my tow hook 1/8" (I think) thick, and 3" wide.
this stuff does NOT bend easy. so after cutting it to length, we created a couple of relief slits to help us bend it.
once we applied a ton of heat and muscle to this stubborn piece of steel, we used the template to make sure the bends were accurate, then welded the relief slits for strength, and test fitted it on the car.
next we took a 1"x2" piece of square steel tubing, cut it to length, and test welded it to the pieces we just made
after that, we made little "beams" that would connect that piece to the new radiator support. you can see the radiator support on the top part of this picture. The two square holes we cut were for the rubber bushings on the bottom of the radiator. what you can't see in the pictures were the welded nuts on one end of those beams that would be used to bolt the bottom of the radiator support to those new beams.
here it is test fitted to the car. (don't mind the calipers hanging in the background. we were painting those as well. multi-tasking ftw! lol)
after that looked good, we ground the welds for my tow hook, and re-welded it to the new crash bar, test fitted it on the car, and then painted everything.
while the paint was drying for the crash bar, it was time to tackle the splitter. we laid my bumper on some cardboard, and created a design with it. once the design was created, we took the cardboard over to the car, and traced out what would need to be cut for header clearance as well as wheel clearance. once that was done, we placed the carboard template on the alumalite material, and used spray paint as a fast and easy way to trace it. we cut the template out, and took a hand held belt sander to smooth the edges. once everything looked good, we peeled back the protective film, prepped the material and painted it flat black
please ignore the fact that the cutout for the headers looks like a big penis
while the splitter was drying, we attached the crash bar/new radiator support to the car. no idea why it looks like it's still rusted in the pictures. doesn't look like that at all in person. think it was the lighting or something.
we attached an "L" (or elbow) bracket to the radiator support. this is what the front part of the splitter would be attached to. we used a rivet gun and put 5 rivets in that bracket, and 2 in the k member (to attach the rear part of the splitter). We clamped the splitter up to the car and drilled the holes for the bolts.
you can see the rivet on the k member
the splitter clamped to the car
the splitter with the mounting holes drilled in it
installed the splitter to the car, and did some final checking/measuring before we put the bumper on.
put the bumper back on, as well as the headlights and everything else. then isntalled the support beams, took a few steps back, and was loving it.
the final product (please ignore how dirty the car is. new pictures of a much cleaner car will be taken soon lol)
I'm open to any questions/comments/constructive criticism.
Let me know what you guys think!
Visit here to see fast cars and races. ---> YouTube: mikealicious2k5
mikealicious is offline
Old 02-13-2011, 05:55 PM   #2
zx360
zx360's Avatar
Fan#: 32439
What I Drive: 2005 black zx3 ses
Points 16,856, Level 83
Points: 16,856, Level: 83 Points: 16,856, Level: 83 Points: 16,856, Level: 83
Level Up 2% Completed
FF Reputation: 44 zx360 Great Standing Member
Buy-Sell-Trade Rating: (33)
it turned out great mike! nice work to the both of you
FocusFest 11' "Best in class" • Oct'11 HOTM • FITF'12 "Best Show & Shine" • July 12 ROTM
instagram @360DSGNS
zx360 is offline
Old 02-13-2011, 06:00 PM   #3
mikealicious
'Merica
Fan#: 47077
Thanks Josh! Just trying to make the car perform better and a little more visually appealing.
Old 02-13-2011, 07:34 PM   #4
Jetta555
Jetta555's Avatar
Fan#: 76963
What I Drive: 2010 Ford Focus SE Metallic Grey
Points 944, Level 16
Points: 944, Level: 16 Points: 944, Level: 16 Points: 944, Level: 16
Level Up 44% Completed
FF Reputation: 1 Jetta555 Good Standing Member
looks dam good man nice job on the fabrication neat idea
For God so loved the world that he gave his one and only Son, that whoever believes in him shall not perish but have eternal life.
- John 3:16
Jetta555 is offline
Old 02-13-2011, 07:47 PM   #5
Djzx3
WRX/Focus:)
Djzx3's Avatar
Fan#: 76864
What I Drive: 04 WRB WRX / 00 se zxw
FF Reputation: 33 Djzx3 Great Standing Member
Buy-Sell-Trade Rating: (6)
Wow really nice looking, I always wondered how to do that type of lower splash/wind deflector? How is it mounted to the car, and is it piloting so that it's adjustable by those rods?
2000 SE wagon 2.0l Zetec.
HN #17
D23 crew-#1
Djzx3 is offline
Old 02-13-2011, 07:49 PM   #6
FuhFuh Focus
Stuff about Florida
FuhFuh Focus's Avatar
Fan#: 67230
What I Drive: 2002 Mazda Protegé ES
FF Reputation: 7 FuhFuh Focus Good Standing Member
That looks pretty cool, looks like yall did a good job too.
FuhFuh Focus is offline
Old 02-13-2011, 07:51 PM   #7
2003SilverSVT
Fan#: 77592
What I Drive: Read my user name...
FF Reputation: 1 2003SilverSVT Good Standing Member
Very nice job !!!
2003 CD Silver SVT
0007 of 3985
1972 Chevelle SS Supercharged 468 BB
1991 Pontiac Formula 5.7, 2010 F250 KR V-10
2003SilverSVT is offline
Old 02-13-2011, 07:57 PM   #8
Nickgt40
Wheel King, Bow Down
Nickgt40's Avatar
Fan#: 40924
Location: Annoying the Liberals, California, United States
What I Drive: 01 Black ZX3, 09 FSWerks SEMA Coupe
FF Reputation: 19 Nickgt40 Great Standing Member
I am so envious of your lift.
Car looks great!
Feb 2011 Ride of the Month ~ 2011 Hatch Nation Hatch of the Year ~ 2011 Focus Fanatics Ride of the Year!
Hatch Nation #2
Nickgt40 is offline
Old 02-13-2011, 08:04 PM   #9
sleepyboy
FF's Night Security
sleepyboy's Avatar
Fan#: 15335
Points 138,233, Level 100
Points: 138,233, Level: 100 Points: 138,233, Level: 100 Points: 138,233, Level: 100
Level Up 0% Completed
Forum Activity 53%
Activity: 53% Activity: 53% Activity: 53%
Buy-Sell-Trade Rating: (11)
Wow nice work!
Moderator for
Technical Chat
Zetec Performance Chat
Southern Fanatics Chat
sleepyboy is online now
Old 02-13-2011, 08:12 PM   #10
mikealicious
'Merica
Fan#: 47077
thanks man! I'll have to give credit where credit is due tho. A LOT of the fabrication work on this one was done by my buddy. Dude does awesome work and is always thinking outside the box. The fab idea I had in my mind had to do with removing the factory bumper beam. He wanted to do it without removing that. And we did.
Not really sure your first two questions on this one. The wind deflector and how is it mounted to the car? It's an aerodynamic splitter. The way it works is it's smooth surface allows the air/wind to move quicker underneath the car. This creates less air pressure underneath the car and greater air pressure above the car (aka downforce). at higher speeds, it pushes the car down, giving it more traction under high speed cornering. I've road raced the car a couple of times last year, and plan to race it a lot more this year. One of the reasons I made it. Plus, I think it looks sick. ahah
but to answer your second question, yes. it is adjustable. Those rods screw/unscrew into themselves, so I can raise or lower the front of the splitter which would change the angle (change the downforce) of it.
thanks man! It came out better than I thought it would. Fully functional and looks dope!
Originally Posted by 2003SilverSVT View Post
Very nice job !!!
thanks!
Car looks great!
lol that's my buddy's lift. He's basically the "go-to" guy for virtually anything around our area. He does awesome work and does it super fast. That lift makes everything sooooo much easier. lol
Originally Posted by sleepyboy View Post
Wow nice work!
Thanks dude!
