Go Back   Focus Fanatics > Model Specific Discussions > MK1 Focus > MK1 Interior Mods & Upgrades
Old 09-15-2004, 04:38 PM   #1
thrill5one6
Fan#: 12215
What I Drive: infared 00 zx3 5speed
FF Reputation: 1 thrill5one6 Good Standing Member
Problem: Indiglo gauges not lighting up. Anyone know how to fix this?
i have the APC indiglo gauges that light up blue and have a switch to change it to green. i've had it for over a year and a few weeks ago it would flicker on and off. and now it doesnt work at all. Does anyone kno how to fix this? is it a loose wire? a burnt out bulb? how do u get to the problem? i didnt install these myself.
~thankyou
thrill5one6 is offline
Fan#: 1
Old 09-15-2004, 04:40 PM   #2
focuson03
Formerly Focused
focuson03's Avatar
Fan#: 556
What I Drive: 2007 Galaxy Gray Mazda3 GT
FF Reputation: 1 focuson03 Good Standing Member
Buy-Sell-Trade Rating: (9)
well it's obviously not a burnt out bulb. . . i would check your connections to make sure everything's still working right. make sure to check the ground too.
Mazda3s Grand Touring 5spd., RacingBeat Springs, F2 CAI, Corksport Rear Motor Mount, Hotchkis Sway Bars
-Josh
focuson03 is offline
Old 09-15-2004, 08:52 PM   #3
Foci_Fosho
Foci_Fosho's Avatar
Fan#: 5736
What I Drive: 2003 White zx3 2.3L
FF Reputation: 16 Foci_Fosho Great Standing Member
Buy-Sell-Trade Rating: (6)
Apc sucks, buy something that works... I was about to get APC hood latches, but i didn't want to risk my cf hood with rings that aren't properly seated in the slider...
Umm try redline racing products, that's what i got, i paid $33.77 for them... SpeedHut.com has better selection and higher quality... Ok. peace
Foci_Fosho is offline
Old 09-15-2004, 08:57 PM   #4
S2
Retired Fanatic
S2's Avatar
Fan#: 4939
What I Drive: Camaro 2SS/RS
FF Reputation: 68 S2 Excellent Standing Member
Buy-Sell-Trade Rating: (20)
Check the ground, even move it to another place, if the lights are flickering I would almost guess it's either the ground or a short somewhere in the wiring, inspect it all, check the inline fuse (assuming APC at least has something like that) and if need be, re-install (rewire) what you need to.
I am heavily leaning towards either a bad ground or a short somewhere that would most likely be a wiring issue....
Good Luck....
Chad (S2)
S2 is offline
Old 09-15-2004, 08:57 PM   #5
Foci_Fosho
Foci_Fosho's Avatar
Fan#: 5736
Oh, after re-reading your post, Take out the instrument cluster, and Check the very top connection... you should See two thin flat wires that take a sharp bend.... maybe it might have been cut or split... if it is.. scrape off the plastic overlay... until you reach the connection..
then break out the soldering tools. Too much of a hassel? Do The Above...
Old 09-15-2004, 09:10 PM   #6
S2
Retired Fanatic
S2's Avatar
Fan#: 4939
I agree with you though FOCI, the APC gauges are not made the best, same as those EL glow ones on EBAY. They work and all the the best quality ones has got to be hands down the speedhut ones.
Chad (S2)
S2 is offline
Old 09-15-2004, 09:12 PM   #7
EuroZX3
EuroZX3's Avatar
Fan#: 39
What I Drive: 05 Black Scion TC
FF Reputation: 1 EuroZX3 Good Standing Member
Buy-Sell-Trade Rating: (7)
the indiglo box could be shot.
Originally posted by darkpuppet
needs more cowbell
EuroZX3 is offline
Old 09-16-2004, 01:44 AM   #8
Foci_Fosho
Foci_Fosho's Avatar
Fan#: 5736
hmm, mine were from ebay, it's a sweet color... the only thing that's questionable is the blue color makes a high pitched frequency from the indiglo box EuroZx3 Speaks of... The green doesn't however...
Old 09-16-2004, 09:00 AM   #9
NR
NR's Avatar
Fan#: 8782
What I Drive: 2002 twilight blue zx3 5 spd
FF Reputation: 1 NR Good Standing Member
if all the connections are good, it's probably the inverter, check to see if it smells like burning plastic.
2002 zx3 5 speed
custom magnaflow cat-back(3 inch pipe), steeda lowering springs, mac shorty intake, focus firepower ignition and livewires, autolite platinum sparkplugs, reverse indiglo gauges, painted stock rims wrapped on sumitomos HTRZII, shorty antenna, mintex pads, aeroquip brake hoses, ebc rotors, no resonator, debadged, limo tinted, halo headlights, steeda short shifter, 4-2-1 race header, W-TYP sideskirts, S2 side mouldings, mazda tribute door handles
NR is offline
Old 09-17-2004, 06:04 AM   #10
bottlefedfocus
Fan#: 6374
What I Drive: 2001 Midnight Blue Zx3
FF Reputation: 1 bottlefedfocus Good Standing Member
check the wires on the back of the switch mine did thsi same thing and ther were broke off bad soldering so i just got rid of the switch all together
bottlefedfocus is offline
Similar Threads
Lighting Problem. Please Help SilverBullet89 General Technical Chat 2 11-04-2009 10:55 AM
New sympton with an old problem that no one can fix.. kndlz28 General Technical Chat 8 05-15-2007 08:11 AM
lighting problem clie General Technical Chat 5 06-09-2005 08:48 PM
Indiglo gauges raschella23 MK1 Interior Mods & Upgrades 3 08-03-2004 01:27 AM
indiglo gauges problem grover General Technical Chat 7 07-02-2004 02:01 PM
