Engine Vibration - Focus Fanatics
Old 02-08-2011, 10:50 AM   #1
SuperJoe
Fan#: 61213
What I Drive: 2003 Dark Grey ZTS
FF Reputation: 1 SuperJoe Good Standing Member
Engine Vibration
2003 Focus ZTS 2.0 DOHC Automatic
for about 6months now I have been trying to trouble shoot a really bad engine vibration. Here is what I have done so far:
plugs / wires
cleaned mass air sensor
cleaned throttle body
replaced vacume lines
replaced PCV valve
replaced alternator (it was bad)
replaced power steering pump (and hoses) the pulley was wobbling
replaced the harmonic balancer (just about fell to apart when i took it off
when the car is in cold loop (idling at 1000rpms) it vibrates but not really enough that i would have worried about it , but once it warms up and idles down to about 700rpms it will shake your teeth out. when you are sitting still and mash your foot on the brake, and have the parking brake set and put it in gear and rev it to about 1500rpms the vibration lessons and has a differant tone when it is under the load. than if you just rev the engine to 1500 in park or neutral. there is also a noticeable vibration hum while driving down the road too that you can feel in your feet and your rear.
I have not noticed any major engine movement under the hood except when doing the load test, it torx pretty good but only when youget it over 1000 rpms
I am really at a loss here and do not have a clue what to do. My dad (certified Deisel mechanic) is telling me that he thinks it is a cracked flex plate or loose torque converter. but i really dont want to have to drop the transmission, it is kind of a PITA in a front wheel drive car.
ANY help would be greatly appreciated. if there is anyone in the Luling / Seguin / New Braunfels / San Antonio, TX area that might be able to look at it I would be happy to meet some where to have you take a look and feel the bad vibes (that is what my son calls them).
SuperJoe is offline
Old 02-08-2011, 11:04 AM   #2
whynotthinkwhynot
Captain TMI
whynotthinkwhynot's Avatar
Fan#: 18416
What I Drive: 05 ZXW; 02 Windstar; 13 C-Max SEL
Did you check your motor mounts? There are 3. One at the front of the motor, one at the top of the transmission, and one underneath in the center of the engine compartment. We have a bunch of threads on those. Most recommend a Ford replacement for the front engine mount, poly inserts for the lower mount, and standard mount for the transmission. If you don't care about vibration much, then you can get poly mounts for all 3 that will never go bad, but do tend to transmit more engine vibration.
Also if you are missing parts or the bracket is broken on the lower mount, then you can get the bracket and mount by purchasing the Ford part for that one.
We have a 5% discount at RockAuto.com which is a fairly good source for parts. Look in our Hot Deals and Shopping Fanatics forum in Off Topic Discussions for the RockAuto thread, the directions on how to use the discount, and the latest (check dates) discount code.
Their prices on motor mounts are great- however the Anchor mount replacement for the front engine mount have been known to fail within warranty. Most people get tired of changing them.
Mounts are located in the following sections on that site:
Engine: Motor Mount = front engine mount
Engine: Torque Strut Mount = lower engine mount
Transmission: Transmission Mount = transmission mount
Be eclectic.
You're special aren't you.
whynotthinkwhynot is offline
Old 02-08-2011, 11:06 AM   #3
1bille1
Fan#: 82596
What I Drive: 2000 black zts
FF Reputation: 1 1bille1 Good Standing Member
Ever replaced any of the engine/trans mounts? Common problem that's discussed alot
1bille1 is offline
Old 02-08-2011, 11:12 AM   #4
SuperJoe
Fan#: 61213
thank you for your posts, i do have an issue with vibrations (hense the reason for the post) i will try the motor mounts, ill check the sites you mentioned, I also have a shop discount at Napa and O'Reilys so i will see waht they ahve then for too.
SuperJoe is offline
Old 02-08-2011, 12:18 PM   #5
SuperJoe
Fan#: 61213
wow those prices are insanely cheap even with my shop discount they are cheaper, i think i can wait a few days to say almost 50%
SuperJoe is offline
Old 02-08-2011, 06:28 PM   #6
genoobie
Fan#: 83007
What I Drive: 2003 Maroon SE Wagon
FF Reputation: 1 genoobie Good Standing Member
Did 3 mounts not that long ago. Helped a bit, but not a dramatic improvement.
genoobie is offline
Old 02-08-2011, 08:11 PM   #7
rzimmerman30
Fan#: 81649
What I Drive: 2007 Red Focus SES
FF Reputation: 1 rzimmerman30 Good Standing Member
I had the exact same problem. As soon as I started my car, I could feel the vibration but it wasn't terrible. Then as the engine warmed up, it would get to a point where I could barely stand to sit in the car. Then when I would give it gas, the vibration would almost completely go away, until after about 2 weeks like that then it started shaking on acceleration too. I just recently had it fixed. It was the passenger side hydraulic mount under the coolant tank. As soon as it was replaced, all the vibration completely dissapeared. The vibration was insane.
rzimmerman30 is offline
