PCV Valve location on 2008 Ford Focus SE - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 02-06-2011, 01:59 PM   #1
Kingmob35
Fan#: 83108
What I Drive: 2008 Black Focus
FF Reputation: 1 Kingmob35 Good Standing Member
Hello everybody,
Can anyone tell me where the PVC valve for a 2008 Ford Focus SE is located and if it is easy to get to?
I think I know where it is, driver side engine block, on top, but I am not really car savvy, just trying to avoid a trip to the auto shop.
While I'm here, the reason I want to change the PCV valve is because I have had some rough idling for a while, and my MPG has really gone down. When I first got the car, a full tank would go for 395 miles, but know it is down to 280 and goes down more every time I fill the tank.
I have already taken it to a shop to have it looked at, but all they did was replace the fuel filter. They then told me that all cars idle a little rough in the cold weather, but it is doing way too much to be just because of the weather. Searching around on the internet suggests that the PCV valve would be the culprit, and since it's so cheap, I thought I'd try to do it myself and save a couple hundred bucks.
Any suggestions on what could be the problem?
P.S. I only have 29000 miles on it.
Thank you so much for your time.
Kingmob35 is offline
Old 02-06-2011, 03:16 PM   #2
greddy339
Fan#: 63304
What I Drive: 2k ford focus zx3
FF Reputation: 9 greddy339 Good Standing Member
http://forums.focaljet.com/spi-tunin...pi-engine.html
punch this in it will show u!
greddy339 is offline
Old 02-06-2011, 04:04 PM   #3
GO.army.1969
GO.army.1969's Avatar
Fan#: 69605
What I Drive: 2008 Vapor Silver Coupe 5 speed
Points 2,851, Level 32
Points: 2,851, Level: 32 Points: 2,851, Level: 32 Points: 2,851, Level: 32
Level Up 68% Completed
FF Reputation: 15 GO.army.1969 Great Standing Member
If you have not done so yet clean your Mass Airflow Sensor its very easy to do it helped my 08. Thay sell an aersol can cleaner just for Mass Airflow Sensor it like $5 bucks. pull it out spray it off that easy. You can get a can of Sea Foam pour it all in the gas tank then fill up it will clean the fuel system from gas tank all the way to the exhaust its like $8 bucks a can. I think those two things will make your car drive like new for under $20 bucks. You will thank me when done your PCV should just fine you dont have to many miles on it yet you well know when it starts going bad it will start burnning oil most of the time.
NW Posse#10 Team Duratec#69
F2 Header, Steath Exhaust, CAI, AR103, Tuned by Randy Fswerks, DGR Coil Overs
DOMINANT front and rear LCA DOMINANT endlinks Massive toe and camber arms
GO.army.1969 is offline
Old 02-06-2011, 05:41 PM   #4
5characters
No Mo Fo Fo
5characters's Avatar
Fan#: 78897
What I Drive: 2012 M2 Touring
FF Reputation: 2 5characters Good Standing Member
subscribed
Just bring me coffee!
5characters is offline
Old 02-06-2011, 06:03 PM   #5
GO.army.1969
Fan#: 69605
^^^^^^^^ Whats up 5characters Im from Warrensburg MO
Old 02-06-2011, 06:53 PM   #6
Kingmob35
Fan#: 83108
Thanks everyone,
Greedy339: If the PCV valve on my focus is the same location as that engine (which I think it is), then I don't think I'll have a problem changing it.
Now, I just have to wait for the part to arrive.
Go.army.1969: Good idea. I'll try that, too. Do you know where it is located? ( It's too dark and cold to look for it now)
Old 02-06-2011, 07:20 PM   #7
GO.army.1969
Fan#: 69605
Originally Posted by Kingmob35 View Post
Thanks everyone,
Its under your intake manifold a real bitch to get to. Its not like the SPI on the valve cover
Old 02-15-2011, 11:47 PM   #8
UnFocusedST
Fear the TurboSnail!
UnFocusedST's Avatar
Fan#: 40342
What I Drive: 2013 Performance Blue Focus ST
Points 6,449, Level 52
Points: 6,449, Level: 52 Points: 6,449, Level: 52 Points: 6,449, Level: 52
Level Up 50% Completed
Forum Activity 23%
Activity: 23% Activity: 23% Activity: 23%
FF Reputation: 13 UnFocusedST Great Standing Member
Buy-Sell-Trade Rating: (14)
Yep under the intake mani. By the way I'm in the middle of replacing mine. Does anyone know what size wrench to use to remove the EGR tube inside the intake mani? Thanks.
Team Duratec #17
Hatch Nation #17
Midwest Crew #55
Boosted Crew #118
UnFocusedST is online now
Old 02-16-2011, 11:04 AM   #9
whynotthinkwhynot
Captain TMI
whynotthinkwhynot's Avatar
Fan#: 18416
Points 27,933, Level 98
Level Up 59% Completed
Forum Activity 10%
PCV is under the intake manifold on a Duratec engine, which is your engine. What is connected to the top of the valve cover on those engines is the oil breather tube which runs from the valve cover to the air intake.
Be eclectic.
You're special aren't you.
whynotthinkwhynot is offline
Old 02-16-2011, 07:16 PM   #10
greddy339
Fan#: 63304
ohh ya...forgot about duratec...it's weird how duratec's are sooo hard to get to, zetec's right in the front and easy to get to, as well as the spi is on the valve cover
