2001 Focus Timing belt broke - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 02-03-2011, 09:49 PM   #1
astinius1
Fan#: 83053
What I Drive: 2001 white Ford Focus
FF Reputation: 1 astinius1 Good Standing Member
Have a 2001 Ford Focus, engine code P. Went out to start my car and it would not turn over, tried 6-7 times and gave up. Brother-in-law/mechanic said the timing belt broke, since this is a 2.0L NON-Interference engine, what is the likelihood that I did any additional damage? He is telling me I should buy a junkyard engine and have it installed, going to cost me $2700.00...
Any helpful input is appreciated.
Russ
astinius1 is offline
Old 02-03-2011, 10:52 PM   #2
Obocecha
Obocecha's Avatar
Fan#: 28484
What I Drive: 2002 Yellow ZX3
Points 1,641, Level 23
Points: 1,641, Level: 23 Points: 1,641, Level: 23 Points: 1,641, Level: 23
Level Up 41% Completed
Level up: 41% Level up: 41% Level up: 41%
FF Reputation: 15 Obocecha Great Standing Member
Buy-Sell-Trade Rating: (9)
The zetec is a non-interference engine meaning if the timing belt breaks the engine will not suffer any damage. You shouldn't have caused any damage by trying to start it. Just replace the broken timing belt with a new one and you should be good to go.
'02 Yellow ZX3
'85 Supra 6M-GTE
Obocecha is offline
Old 02-03-2011, 10:55 PM   #3
deezx5
deezx5's Avatar
Fan#: 72153
What I Drive: 2011 Gray Hyundai Elantra GLS
FF Reputation: 3 deezx5 Good Standing Member
You can buy a new used Focus for $2700. It is extremely likely that everything is good and you simply need a new timing belt. That is the good thing about a non interference engine. Maybe the brother in law/mechanic isn't the best person to install the new belt.
deezx5 is offline
Old 02-04-2011, 01:08 AM   #4
Kauai Guy
/人◕ ‿‿ ◕人\
Kauai Guy's Avatar
Fan#: 58297
What I Drive: Car
Points 6,484, Level 52
Points: 6,484, Level: 52 Points: 6,484, Level: 52 Points: 6,484, Level: 52
Level Up 67% Completed
FF Reputation: 17 Kauai Guy Great Standing Member
Buy-Sell-Trade Rating: (17)
Yup, no damage I bet. All you need is the timing belt component kit ($70 from RockAuto), and the tool kit ($40 from Massive Speed Systems), and about 5 hours and you're good. The tool kit is so you can put the crank at TDC and align the cams.
It's not that hard. Did my Zetec in December and my SVT this month. SVT is interference though, and I was a bit scared.
Sedan Revolution #150 Hatch Nation #26
Originally Posted by norcalfocus01 View Post
Because I'm on a boat and I just had sex
Kauai Guy is offline
Old 02-04-2011, 01:35 AM   #5
Wagamos
Stock
Wagamos's Avatar
Fan#: 21396
What I Drive: 2001 Malibu Blue ZX3; 03 ZX3 PZEV
Points 9,489, Level 65
Points: 9,489, Level: 65 Points: 9,489, Level: 65 Points: 9,489, Level: 65
Level Up 47% Completed
FF Reputation: 13 Wagamos Great Standing Member
Buy-Sell-Trade Rating: (4)
^^x w/e
Non interference = stuffs wont hit. Your timing is just totally screwed up. Just get a new belt and set the timing and you should be good to go. And in all honestly, 100 bucks to find out if you do or do not need to spend 2700, worth a shot imo. Realistically your car is totally fine though.
And you should pop down further in the forums and go to the michigan regional thread. Ive completely rebuilt a zetec and a few others have done swaps and understand the ins and outs of the engine. We might be a better choice than your bro in law. Does he know its non interference?
Bone Stock
223whp/218wtq
Wagamos is offline
Old 02-04-2011, 02:29 AM   #6
a_2000_se
a_2000_se's Avatar
Fan#: 62964
What I Drive: 2000 SE SOHC SPI, Compression @ 164
Points 4,699, Level 43
Points: 4,699, Level: 43 Points: 4,699, Level: 43 Points: 4,699, Level: 43
Level Up 75% Completed
Forum Activity 5%
FF Reputation: 15 a_2000_se Great Standing Member
Originally Posted by astinius1 View Post
..... engine code P..... it would not turn over ...... since this is a 2.0L NON-Interference engine...... junkyard engine and have it installed, going to cost me $2700.00...
Russ
It's a trick question - "engine code P" refers to the eighth digit of the VIN. Also known as "VIN P" or SOHC, SPI. A non interference engine will turn over even if the timing belt is broken. Are we sure the SOHC is non-interference?
The valves extend beyond the plane on the head but there are reliefs in the pistons - are the reliefs deep enough (why else would they put reliefs for the valves in the piston heads? Floating/stuck valves.).
So - if the engine won't turn over could it be that something is stuck between the piston and the head? Or worse - broken in the cylinder (rod/piston....)?
Have you tried to turn it over by hand? Maybe it's the starter or an electrical problem - what sounds is it making?
I won't say it (valve seat) but what is the mileage on the original engine? Was it running fine before you last shut the engine off?
Member of the Dropped Valve Seat Club.
Replaced #4 Piston, Rings, Rod+Bearings, AERA Re-Manufactured Cylinder Head and a light Hone. Then CLEANED the hell out of everything.
60k+ miles.
a_2000_se is offline
Old 02-04-2011, 09:53 AM   #7
whynotthinkwhynot
Captain TMI
whynotthinkwhynot's Avatar
Fan#: 18416
Points 27,768, Level 98
Points: 27,768, Level: 98 Points: 27,768, Level: 98 Points: 27,768, Level: 98
Level Up 42% Completed
Forum Activity 4%
NOn-interference = no damage to valves. Put a new timing belt on it and go.
Does you valve cover say "Split-Port Injection" or Zetec? That's how we identify these engines. Zetec is DOHC, and the spark plugs go through the center of the head. SPI is SOHC and the spark plugs go into the side of the head like most OHV and SOHC engines.
Be eclectic.
You're special aren't you.
whynotthinkwhynot is offline
Old 02-05-2011, 08:51 PM   #8
total_telecom
Fan#: 83049
What I Drive: 2004 se wagon 2.0L
Points 75, Level 1
Points: 75, Level: 1 Points: 75, Level: 1 Points: 75, Level: 1
Level Up 50% Completed
FF Reputation: 1 total_telecom Good Standing Member
Thumbs down
yeh sounds like the bother in law isnt very bright
total_telecom is offline
Old 02-05-2011, 09:40 PM   #9
greddy339
Fan#: 63304
What I Drive: 2k ford focus zx3
FF Reputation: 9 greddy339 Good Standing Member
this is what i would do....
buy a complete timing belt kit including the tensioner, idler pulley, and belt, and you midas well do the water pump while your in there if you car has high mileage and the pump hasn't been changed yet...
greddy339 is offline
Old 02-05-2011, 11:23 PM   #10
sailor
Elder
sailor's Avatar
Fan#: 57268
Points 12,818, Level 73
Points: 12,818, Level: 73 Points: 12,818, Level: 73 Points: 12,818, Level: 73
Level Up 92% Completed
Level up: 92% Level up: 92% Level up: 92%
Forum Activity 99%
Yah, Buying an engine just to get a new timing belt is DEFINITELY paying more than you need to....
sailor is online now
