Auto-dimming mirror does not work - Ford Focus Forum, Ford Focus ST Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum > Ford Focus Second Generation > MK2 Interior Mods & Upgrades
MK2 Interior Mods & Upgrades The place to chat about performance gauges, shifter knobs, custom interior paint, car seats or any interior upgrades for the 2008-2011 Focus.
Old 02-03-2011, 01:35 PM   #1
miklosszoke
Fan#: 83043
What I Drive: 2010 Blue SES
FF Reputation: 1 miklosszoke Good Standing Member
Hi!
I have bought a used 2010 Focus SES with auto-dimming mirror, but it does not work at all. I have tried to cover the front sensor and used a torch to beam into the rear sensor: nothing. The corresponding fuse is ok.
Do you have an idea what to check?
I am an electrical engineer so I should be able to measure the voltage on the plug if I would have a wiring diagram.
Thanks!
Miklos
miklosszoke is offline
Old 02-06-2011, 08:28 PM   #2
andrewsfm
andrewsfm's Avatar
Fan#: 70099
What I Drive: 2008 Ebony ATX SES w/ Leather & Sun
FF Reputation: 5 andrewsfm Good Standing Member
I can tell you that most electrical engineers make the worst phone line repair guys...
Anyways, at night park somewhere dark, sit in the drivers seat and look in the rearview, and get someone to hold a bright flashlight and shine it through the rear window onto the mirror.
With no light hitting the front sensor, and lots of light hitting the sensor facing the rear, it should start to darken slowly to a green colour.
The flashlight should look greenish in the rearview.
DEI 2-way Alarm & Start / DDM Ballasts + CAP 6000k 55w HIDs in Eagle Eyes Projectors / 6000k 55w HID Fogs / All INT+EXT LEDs+7W LED Reverse / K&N Air Filter / Kumho Ecsta 4X Tires / 35%/20% Tint / Black Grille / Maxxsonics MX-1 + 2500W Stereo
andrewsfm is offline
Old 02-12-2011, 05:55 PM   #3
ChrissyL
Trying to Focus
ChrissyL's Avatar
Fan#: 64813
What I Drive: '13 Performance Blue ST3
Points 1,374, Level 20
Points: 1,374, Level: 20 Points: 1,374, Level: 20 Points: 1,374, Level: 20
Level Up 74% Completed
FF Reputation: 13 ChrissyL Great Standing Member
^^Good step 1 in the process of elimination. If your mirror doesn't dim in less than a minute, step 2 should be checking the connectors on the wiring going into the mirror, both for physical connection and for voltage (with the car running, a VOM should show nominal system voltage from around 12.6 to around 14 volts).
To go to step 3, you'll need to access Ford's online shop manual (since there isn't a commercial manual out for 2008+ models yet). Talk to your dealer's parts or service techs to get the wiring diagram you'll need to go on to test the connections further upstream.
All my relations, Christine
NW Posse #17
"Straight roads are for fast cars. Curvy roads are for fast drivers."
ChrissyL is offline
Old 02-13-2011, 12:45 PM   #4
dadsWagon
dadsWagon's Avatar
Fan#: 54041
What I Drive: 2008 black SE coupe
FF Reputation: 1 dadsWagon Good Standing Member
Why not try :
Step 1 - Go to dealer and ask to check/fix it... it should still be under warranty
dadsWagon is offline
Old 02-13-2011, 02:51 PM   #5
johnkos
Fan#: 1037
What I Drive: 2002 silver se, 2009 blk ses
FF Reputation: 1 johnkos Good Standing Member
I have a 2009 and it doesn't seem to dim unless the car is moving and someone is behind.
johnkos is offline
Old 02-13-2011, 08:24 PM   #6
00CSVT
Fan#: 69872
What I Drive: 2007 ZX3
Points 1,103, Level 18
Points: 1,103, Level: 18 Points: 1,103, Level: 18 Points: 1,103, Level: 18
Level Up 3% Completed
Level up: 3% Level up: 3% Level up: 3%
FF Reputation: 1 00CSVT Good Standing Member
I installed an auto-dimming/compass mirror in my 07 and have installed several of them. Most of what you will find are manufactured by Gentex and the pinouts can be found online.
You should be able to unhook the connector and check to see if there is voltage across pins 1 and 2 easily enough. Also, if pin 3 has power it will disable the auto-dimming function (reverse).
Here's the typical pinout...
PIN 1 POWER +12 volts
PIN 2 CHASSIS, GND
PIN 3 REVERSE SIGNAL
2002 Mercury Cougar - Sport V6/MTX - Taurus 3.0L/HMS/Centerline/Koni
2007 Focus ZX3 D20/MTX - AVIC Navigation/Alpine Amp/Infinity Speakers/ OEM SVT Sub - Gunmetal CSVT E1 Wheels - FRPP Suspension - Hitch
1997 F150 - The toy hauler
00CSVT is offline
Old 01-04-2013, 01:25 PM   #7
miklosszoke
Fan#: 83043
Thank you guys! As it turned out just the fuse was blown. Still it was $110 for the "repair"...
Old 01-05-2013, 11:14 PM   #8
gsellers
Fan#: 83511
What I Drive: 2011 Sangria Red Focus SE
FF Reputation: 1 gsellers Good Standing Member
What's behind you doesn't matter...
gsellers is offline
Old 01-06-2013, 09:00 PM   #9
miklosszoke
Fan#: 83043
Very true, I wrote it only for those who would face the same issue. Check your fuses first before bringing the car to a mechanic!
