Engine wont start.... - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 01-31-2011, 12:46 PM   #1
Javi686
Fan#: 82978
What I Drive: 01, yellow zx3
FF Reputation: 1 Javi686 Good Standing Member
I have a 01 se 4dr with a dohc Zetc engine that wont start it just cranks over but nothing, it turns on sometime but it will turn off and it will not turn on again and if it dose it will do the same thing.. HELP MEEEEEEE..
I just replaced the fuel pump and filter...
Javi686 is offline
Old 01-31-2011, 04:28 PM   #2
Red Jay 918
Red Jay 918's Avatar
Fan#: 79277
What I Drive: 2010 Focus SE
Points 9,427, Level 65
Points: 9,427, Level: 65 Points: 9,427, Level: 65 Points: 9,427, Level: 65
Level Up 26% Completed
Forum Activity 5%
FF Reputation: 7 Red Jay 918 Good Standing Member
check your spark plugs to see if their good..or vacuum hoses too....or even some ground connections. i was working on an old Chrylser Cirrus once and was letting it run outside for a few minutes to burn off the remaining oil off the block. i noticed there was a loose wire and moved it slightly and the whole engine just died and cut off and wouldnt start unless that connection was making contact with the part of the engine it was bolted to. just an idea.
Red Jay 918 is online now
Old 01-31-2011, 05:57 PM   #3
whynotthinkwhynot
Captain TMI
whynotthinkwhynot's Avatar
Fan#: 18416
Points 27,933, Level 98
Level Up 59% Completed
Forum Activity 10%
Check the coil pack plug-in connector- those are known to fail sometimes so that the wires will pull out of the plug.
You should also check the negative battery terminal to be sure that the main ground and the two small supplemental grounds are connected to the terminal securely. Pull and wiggle on those. It would be most likely to be the little ground wires instead of the large one because if there was a problem with the big one- it wouldn't crank.
Next time you try starting it, make sure everything that makes sound is turned off, then turn the key from OFF to ON and listen before cranking. Verify that the fuel pump is working. It is possible that whoever did the fuel pump didn't connect the fuel cut-off switch completely, or didn't push the fuse down completely. If the fuel pump is not working, then I would check those immediately. The fuse location is detailed in the owner's manual.
Be eclectic.
You're special aren't you.
whynotthinkwhynot is offline
Old 02-03-2011, 08:11 PM   #4
pasta
Fan#: 62350
What I Drive: 2003 eap svt
Points 10,262, Level 67
Points: 10,262, Level: 67 Points: 10,262, Level: 67 Points: 10,262, Level: 67
Level Up 53% Completed
Forum Activity 16%
Activity: 16% Activity: 16% Activity: 16%
FF Reputation: 5 pasta Good Standing Member
Buy-Sell-Trade Rating: (42)
check to see if u have spark just take off 1 of the wires from spark plug crank engine hold wire with pliers that are insulated of coarse so you dont get zapped
pasta is offline
Old 02-04-2011, 01:23 PM   #5
LdSiii
Fan#: 82999
What I Drive: 2002 Sangria Red SE Sedan 2.0 Zetec
FF Reputation: 1 LdSiii Good Standing Member
Hello, I just had a similar problem, that w/ the help of FF was able to get my car running.
Check the fuel pump shut-off switch, it's located in the passenger side kick panel. Make sure the ignition is OFF. Remove the cover plug in the trim press the reset button, turn the ignition to the ON position (I did a 10 count) and then return the ignition to OFF. BTW, this info is on page 214 of the owner's manual if you would like to see it in black and white like I do. Now try to start the car, it may take a few cranks for it to fire, and if it does it will more than likely run rough until the air is purged from the system.
Hope this helps
LdSiii is offline
Old 02-04-2011, 05:18 PM   #6
viney266
viney266's Avatar
Fan#: 93
What I Drive: focus ztw ,zx3,mustang, motorcycles
Points 238,851, Level 100
Points: 238,851, Level: 100 Points: 238,851, Level: 100 Points: 238,851, Level: 100
Level Up 0% Completed
FF Reputation: 112 viney266 Excellent Standing Member viney266 Excellent Standing Member
Buy-Sell-Trade Rating: (4)
Hope this helps
^^^ Nice to know we could help !!!
Speed is only a matter of money; how fast do you want to go?
viney266 is offline
Old 03-06-2011, 11:19 AM   #7
Mile30
Mile30's Avatar
Fan#: 74686
What I Drive: '03 ZX3
Points 8,095, Level 60
Points: 8,095, Level: 60 Points: 8,095, Level: 60 Points: 8,095, Level: 60
Level Up 73% Completed
Level up: 73% Level up: 73% Level up: 73%
Forum Activity 4%
FF Reputation: 7 Mile30 Good Standing Member
Buy-Sell-Trade Rating: (10)
I went to start my car last September and it turned over for a second and conked out. Every time I after that it did the same dumb chit... 'till I figured it out last night.
http://www.youtube.com/watch?v=EHPaF6gqxOQ
Mile30 is offline
Old 01-29-2013, 06:00 AM   #8
dlr47
Fan#: 109250
What I Drive: 2008 blue ford focus
FF Reputation: 1 dlr47 Good Standing Member
2008 1.6 tdci, recently had the turbo replaced, engine stripped and cleaned as it had oil caked onto everywhere, the exhaust was dry, after 2 days fuel of driving it made a loud noise which sounded like something knocking, which got faster as i reved the engine, the engine has been stripped yet again, nothing obvious!!!
engine rebuilt but now, turns over but will not run, like as if its out of fuel, tried spraying deoderant and it tried fireing but obviously didnt run, tried bleeding many many times,fuel going into the pump but then back out through the return, there is no engine cut out switch as on some models, ive pulled the switch diesel solenoid switch off and tried testing it but cant tell if its operating or not, please only had the car 8 months and its been in bits for the last 2
dlr47 is offline
Old 01-30-2013, 05:25 AM   #9
tmittelstaedt
Fan#: 108093
What I Drive: 2001 Red Focus SE Street Edition
Points 233, Level 4
Points: 233, Level: 4 Points: 233, Level: 4 Points: 233, Level: 4
Level Up 66% Completed
FF Reputation: 2 tmittelstaedt Good Standing Member
please don't resurrect old threads, start a brand new one. Do you really think that the folks from 2 years ago are still checking this thread, it is not even the same engine? And in any case, if a newly rebuilt engine won't start I would assume the cams are timed wrong and recheck that.
tmittelstaedt is offline
Old 01-30-2013, 05:53 AM   #10
dlr47
Fan#: 109250
Sorry I wasn't sure how to start a new thread!!
I don't think the cams are timed wrong and that wouldn't stop the diesel coming through.
Thanks anyway
dlr47 is offline
