How To: Proper EGR Delete *now with 20% more How* - Page 9 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 05-11-2013, 12:02 PM   #81
Magus2727
Magus2727's Avatar
Fan#: 62897
Points 8,663, Level 62
Points: 8,663, Level: 62 Points: 8,663, Level: 62 Points: 8,663, Level: 62
Level Up 72% Completed
Forum Activity 46%
Activity: 46% Activity: 46% Activity: 46%
likely just have the light removed behind the dash?
2001 ZX3 2.0L Zetec-
Hatch Nation #42
Magus2727 is online now
Old 05-11-2013, 12:38 PM   #82
Autoxzx3
Fan#: 112232
What I Drive: 2003 Silver zx3
Points 797, Level 14
Points: 797, Level: 14 Points: 797, Level: 14 Points: 797, Level: 14
Level Up 97% Completed
Level up: 97% Level up: 97% Level up: 97%
Forum Activity 6%
FF Reputation: 1 Autoxzx3 Good Standing Member
I'll check it but it was on about a month ago for an o2
Autoxzx3 is offline
Old 06-09-2013, 11:11 PM   #83
joesperformance
joesperformance's Avatar
Fan#: 92411
What I Drive: 01 Focus SE Sedan, Zetec
FF Reputation: 3 joesperformance Good Standing Member
U can remove egr and egr pipe and just move the vacuum line from the top of egr valve to the test port on the square box that has 2 lines that come from egr pipe and then no codes no engine light for egr. I did it on mine to get light off. I even scanned for codes with my reader a month later and no codes at all.
Sent from my DROID RAZR using FF Mobile
http://www.firebirdnation.com/forums/uploads/1341751582/gallery_13330_2406_139330.png
Sedan Revolution #232
joesperformance is offline
Old 06-09-2013, 11:29 PM   #84
Whitebread
Fan#: 113941
What I Drive: 2002 White ZX5
FF Reputation: 1 Whitebread Good Standing Member
Thanks for the info! That seems like something i will be testing.
How does that effect mpg though?
Whitebread is offline
Old 06-10-2013, 12:16 AM   #85
joesperformance
Fan#: 92411
It didn't effect my mpg at all. I got to test mpg in 3 steps. Stock. Egr system removed. And long tube header cat delete. I'm still getting 28 to 30 mpg in town and 32 to 34 mpg on highway.
Old 06-10-2013, 10:43 AM   #86
Whitebread
Fan#: 113941
So to be sure i understand you, i'll still need
EGR delete plate
EGR gasket
A cap or bolt for the EGR bung on the header or a M22x1.5mm threaded plug for the exhaust EGR outlet (NAPA Part # 704-1048 works OK)
Basically follow the first few steps, like in the first few steps in the op.
Old 06-10-2013, 11:50 AM   #87
joesperformance
Fan#: 92411
correct, I didn't bother with a EGR block off plate, I just left my EGR valve bolted on and just moved the vacuum line from it, saved some money, as long as no vacuum going to EGR Valve then it stays closed....
do everything as stated in this post, remove EGR valve, remove EGR pipe, block off EGR valve hole on IM and block hole on Exhaust where u remove the EGR pipe..... then just move the vacuum line from the top of the EGR Valve itself over to the square box that was attached to the EGR pipe by 2 rubber hoses and your done.... ill get u a pic in a few of where to hook the vacuum line from EGR Valve to on the black box....
if there's no NAPA near you, u can also go to O Reilly or Autozone and use the part number from this pic, its what I used and had no problems....
PIC OF PLUG ITSELF, I LIKE THIS PLUG, CUZ IT USES JUST A STANDARD 3/8" DRIVE RATCHET OR EXTENSION END TO INSTALL, NO SOCKET OR WRENCH NEEDED.... NO TAP OR PASTE OR THREAD LOCKER OR ANYTHING IS NEEDED ON THE THREADS, I HAND SCREWED MINE IN AND NO LEAKS AT ALL, AND I CAN PUT IT IN AND OUT AS NEEDED WITH NO TOOLS BASICALLY....
HERE IT IS INSTALLED ON MY HEADER, ITS ON THE RIGHT HEADER TUBE, ITS THE SHINEY PLUG....
Old 06-10-2013, 11:57 AM   #88
Whitebread
Fan#: 113941
Rep for you sir, great post.
I will be completing this sometime this week.
Old 06-10-2013, 12:56 PM   #89
joesperformance
Fan#: 92411
pic of vacuum line moved from top of EGR Valve to the square box....
pic of which port to use.... very simple, remove vacuum line from top of EGR Valve and plug straight onto square box and done.... make sure u leave the harness plugged onto square box otherwise will not work....
ITS THE REF PORT THAT YOU NEED....
Old 09-04-2013, 05:50 PM   #90
Whitebread
Fan#: 113941
Just thought id update my experience with this.
I've had my egr deleted per "joesperformance" instructions and it worked flawlessly. I capped the bung on the exhaust manifold, left the valve where it was, and moved the vacuum lines off the valve and back to the reference port.
No check light, no studder, and mpg has been restored. Big thanks goes out to joesperformance for helping me get that straightened out.
