Battery Drains - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 01-25-2011, 11:48 PM   #1
Giancarlo
Giancarlo's Avatar
Fan#: 66325
What I Drive: 2001 Street Edition Sedan
Points 3,157, Level 34
Points: 3,157, Level: 34 Points: 3,157, Level: 34 Points: 3,157, Level: 34
Level Up 72% Completed
FF Reputation: 2 Giancarlo Good Standing Member
Battery Drains
Hey guys, I got another problem with the Focus, I just charged my battery slapped in the car started it perfectly with nothing. Next day I go back nothing wants to work... I test the battery and it lost it's charge AGAIN. Everytime I put the battery back on from a full charge the speedometer and other gauges go to their max and reset back to zero is this normal? Could one of the fuses or relays causing malfunction and making the car drain battery life when the car is off?
Thanks.
'01 Ford Focus Street Edition Sedan
2.0L DOHC 16V Zetec
A Random Canadian from Sedan Revolution #196SR
Giancarlo is offline
Old 01-25-2011, 11:59 PM   #2
fhh02a
HATCH NATION
fhh02a's Avatar
Fan#: 57548
What I Drive: 2004, Pitch Black Zx3
Points 16,184, Level 81
Points: 16,184, Level: 81 Points: 16,184, Level: 81 Points: 16,184, Level: 81
Level Up 67% Completed
FF Reputation: 13 fhh02a Great Standing Member
Buy-Sell-Trade Rating: (10)
the gauge sweep is normal..
it really sounds like you have something that is draining the battery or you have a ghost nearby(watching ghosthunters right now)
but in all seriousness
do you have any aftermarket electronics in the car?
is the door shut all the way?
fhh02a is offline
Old 01-26-2011, 12:08 AM   #3
Giancarlo
Giancarlo's Avatar
Fan#: 66325
Nope, everything is stock in this car...
I have a defective trunk hook and sometimes it doesn't close properly but I don't think theres light in there and I doubt it could be the cause of the problem or is it O.o??!
2.0L DOHC 16V Zetec
Old 01-26-2011, 12:10 AM   #4
madisonHQ
Fan#: 81165
What I Drive: zx5
FF Reputation: 6 madisonHQ Good Standing Member
Could be ur alternator not returning the charge to the batt
Hatch Nation
Team Duratec
madisonHQ is offline
Old 01-26-2011, 12:11 AM   #5
fhh02a
HATCH NATION
fhh02a's Avatar
Fan#: 57548
Gian,
if i remember correctly there is a light in the trunk. if its not shutting all the way, it could be leaving the light on.
heres a trick (if there is a light) take the light out and see if your draining problem goes away
it wouldnt hurt to get the ALT checked
Madison,
if the alt was returning charge to the battery, I would think the battery light would be on.. maybe he should get the alt. checked
fhh02a is offline
Old 01-26-2011, 12:37 AM   #6
madisonHQ
Fan#: 81165
What I Drive: zx5
Gian,
Madison,
yupp exactly, that trunnk light is a clever idea also !
Hatch Nation
Team Duratec
Old 01-26-2011, 01:00 AM   #7
jetrinka
jetrinka's Avatar
Fan#: 45622
What I Drive: 88 5-speed XR4TI
FF Reputation: 180 jetrinka Excellent Standing Member jetrinka Excellent Standing Member
Buy-Sell-Trade Rating: (6)
Checking the alternator is a good idea but should be done secondly to checking the battery itself for draw. Its a simple test that only requires an amp-meter.
Disconnect the negative battery cable and connect the positive end of the meter to the battery cable and the negative end to the negative battery post. The reading on the meter will tell you the amount of draw on the battery. This should also be done while simulating the car in its "parked" state, as in all the doors closed, key out of the ignition, etc etc. You should also let the meter sit in this position on the battery for around 15 minutes because in disconnecting the battery for that short period of time and then reconnecting it through the meter it might have awoken some modules and such that would need to power down again.
I hope this makes sense.
jetrinka is offline
Old 01-26-2011, 08:45 AM   #8
239rsw
239rsw's Avatar
Fan#: 15133
What I Drive: 2002 Yellow ZX3
Points 542, Level 10
Points: 542, Level: 10 Points: 542, Level: 10 Points: 542, Level: 10
Level Up 84% Completed
FF Reputation: 3 239rsw Good Standing Member
I would take it to an autostore that would check battery and regulator with no charge. If battery and regulator are good, then go look for the unknown.
2002 ZX3 @ 333K
Last Update : 10/05/2014
239rsw is offline
