SCT Problems (User Adjustments Not working) - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 01-24-2011, 02:52 AM   #1
FocusBoy58
Sonic Mk3 Crew #03
FocusBoy58's Avatar
Fan#: 38424
What I Drive: 01 Turbo,12 SE,95 Vette 396
Points 20,537, Level 90
Points: 20,537, Level: 90 Points: 20,537, Level: 90 Points: 20,537, Level: 90
Level Up 38% Completed
Forum Activity 2%
FF Reputation: 14 FocusBoy58 Great Standing Member
Buy-Sell-Trade Rating: (16)
I adjust my settings for AFR and all my other settings for dyno tuning... and its not taking the adjustment what causes this? My 2step is set to 4k normally and default is 3500 and its loading 3500 instead of my desired 4000... Its basically just loading the default Focussport tune... Now that i changed the cams i wanted to adjust it a bit and get my AFR to 12.8-13.0 and for some odd reason non of my user adjustments work...
FocusBoy58 is offline
Old 01-24-2011, 07:57 AM   #2
Blivit
Blivit's Avatar
Fan#: 51292
What I Drive: 2013 ST
Points 2,287, Level 28
Points: 2,287, Level: 28 Points: 2,287, Level: 28 Points: 2,287, Level: 28
Level Up 92% Completed
Level up: 92% Level up: 92% Level up: 92%
FF Reputation: 118 Blivit Excellent Standing Member Blivit Excellent Standing Member
What device do you have and what firmware is on it?
The 2 step only works if it is enabled in your tune. If your tuner did not enable it then the adjustments for that will do nothing.
For the user adjustments are you going through the process correctly? When you go into the adjustment menu you scroll through the options then press select on what you want to adjust (in this case WOT air/fuel...which only changes air/fuel at wide open throttle and no other point.) You then scroll through the options of richer or leaner and press select on what you want; this will take it back to the previous menu. If that is all you want to adjust you press cancel indicating you are finished. Then press select on "begin program." If you press cancel on the value you want instead of select then the option does not apply.
Blivit is offline
Old 01-24-2011, 08:14 AM   #3
1turbofocus
FF Affiliate
1turbofocus's Avatar
Fan#: 1123
Points 51,284, Level 100
Points: 51,284, Level: 100 Points: 51,284, Level: 100 Points: 51,284, Level: 100
Level Up 0% Completed
Forum Activity 23%
Activity: 23% Activity: 23% Activity: 23%
Buy-Sell-Trade Rating: (28)
You should datalog send it to your tuner then get your tuner to make the adjustments with in your tune
Customer Support
AIM: hpdyno
Email: hpdyno@aol.com
Phone: 704-249-3745
Site: focus-power.com
Elder 1turbofocus
1turbofocus is offline
Old 01-24-2011, 08:42 AM   #4
focusmaniaczx3
I need BOOOOST!!!!!!
focusmaniaczx3's Avatar
Fan#: 55157
What I Drive: zx3 turbo, kia soul, 71 chevy c/10
Points 14,754, Level 78
Points: 14,754, Level: 78 Points: 14,754, Level: 78 Points: 14,754, Level: 78
Level Up 76% Completed
Level up: 76% Level up: 76% Level up: 76%
Forum Activity 5%
FF Reputation: 35 focusmaniaczx3 Great Standing Member
Buy-Sell-Trade Rating: (14)
ive had this same problem ever since i first got my xcal2. i finally gave up on it and just run the defaults and if i need it tweaked then ill get it tweaked. it must be a problem with the xcal itself because ive gotten tunes from focussport, focus power, and a local dyno loaded on my flasher and i got the same problem with all 3 different tuners. so it must either be the flasher or the person using it. using a flasher isnt rocket science so im leaning towards the flasher being the culprit.
focus-power P&P head $1100
focus-power DIY turbo kit $1495
tom's first time in Vegas? PRICELESS!
Originally Posted by 1turbofocus
I love this big little city HOOTERS !
Every time you drink a beer somewhere an ugly woman becomes beautiful, so get to it!
focusmaniaczx3 is offline
Old 01-24-2011, 09:58 AM   #5
FocusBoy58
Sonic Mk3 Crew #03
FocusBoy58's Avatar
Fan#: 38424
Forum Activity 2%
Xcal2, focussport, Im using correctly... It seems sometimes it accepts the programming I tell it to and sometimes it doesn't... It's really being a pita because I can't dyno it properly..
I'm saving the changes everytime... Even when I load to try installing again the changes on the tuner are still saved but the car is still running the default and the firmware is like 1.4 or something if I remember looking at it right yesterday.
Old 01-24-2011, 04:04 PM   #6
FocusBoy58
Sonic Mk3 Crew #03
FocusBoy58's Avatar
Fan#: 38424
Forum Activity 2%
I did it this morning while the car was cold and it tuned it exactly the way i wanted.. IDK if i cant tune it while the car is hot or if i cant tune it while the door is closed.. Im just confused on what the heck this things problem is..
Old 01-26-2011, 07:52 AM   #7
focusmaniaczx3
Fan#: 55157
Forum Activity 5%
it seems we are both having the same problem and in my experience thus far the car being hot or cold, the doors or lights or radio or anything else being on or open has no effect either. it seems like it just has moods. sometimes it feels like taking it and other times it doesnt. i really would like to get this straitened out myself but im thinking i may have to just bite the bullet and get an xcal3
